The following sections provide an overview of HP 3PAR: SMI-S and the "HP 3PAR: SMI-S" PowerPack:
What is SMI-S?
Storage Management Initiative Specification, or SMI-S, is a standard that allows users to manage heterogeneous storage devices in a Storage Area Network (SAN).
An HTTP server, called a provider, sends and receives XML requests to the storage devices to manage those devices and retrieve information about those devices.
Skylar One communicates with the provider to retrieve information about the SAN and its devices.
What Does the HP 3PAR: SMI-S PowerPack Monitor?
To monitor storage arrays using Skylar One, you must install the "HP 3PAR: SMI-S" PowerPack. This PowerPack enables you to discover, model, and collect data about HP 3PAR storage arrays and their component devices.
The "HP 3PAR: SMI-S" PowerPack includes:
- An example credential you can use to create Basic/Snippet credentials to connect to the SMI-S Provider
- Dynamic Applications to discover and monitor the storage arrays
- Device Classes for each type of storage array component device monitored by Skylar One
- Event Policies and corresponding alerts that are triggered when devices in the HP 3PAR system meet particular criteria
Installing the HP 3PAR: SMI-S PowerPack
Version 100 is considered the initial release of the "HP 3PAR: SMI-S" PowerPack. ScienceLogic does not support an upgrade path from version 0.7.x to version 100 of the PowerPack. If you previously installed a pre-100 version of the PowerPack, you must delete any existing HP 3PAR devices and uninstall the old version before installing version 100.
