Introduction to Monitoring Oracle Solaris Devices
This section describes how to use the "Oracle: Solaris Monitoring" PowerPack to monitor Oracle Solaris devices in Skylar One.
What Does the Oracle: Solaris Monitoring PowerPack Monitor?
The "Oracle: Solaris Monitoring" PowerPack includes:
  • Dynamic Applications to collect configuration and performance data about Oracle Solaris systems
  • Device classes for each Oracle device that the PowerPack monitors
  • A device template for aligning Oracle Solaris Dynamic Applications
  • A run book automation policy and action for classifying Oracle Solaris devices
  • A sample credential for discovering Oracle Solaris devices
  • Event policies and corresponding alerts that trigger when Oracle Solaris devices meet certain status criteria
Installing the Oracle: Solaris Monitoring PowerPack
Before you complete the steps in this section, you must import and install the latest version of the "Oracle: Solaris Monitoring" PowerPack.
