Introduction
This  section describes how to monitor Pure Storage FlashArrays in Skylar One using the "Pure Storage" PowerPack.
What is Pure Storage?
Pure Storage is a Flash-based storage solution provider. Its FlashArray solution provides multi-level cell, high-performance Flash memory for applications such as server virtualization, desktop virtualization, database systems, and cloud computing.
What Does the Pure Storage PowerPack Monitor?
The "Pure Storage" PowerPack includes:
  • Dynamic Applications to discover and collect configuration and performance data for Pure Storage FlashArrays and component devices
  • Device classes for each of the Pure Storage devices monitored
  • Event policies and corresponding alerts that are triggered when Pure Storage devices meet certain status criteria
  • A sample credential for discovering Pure Storage devices
  • Dashboards that display information about Pure Storage devices
Installing the Pure Storage PowerPack
Before completing the steps in this  section, you must import and install the latest version of the "Pure Storage" PowerPack.
