What is SMI-S?
Storage Management Initiative Specification, or SMI-S, is a standard that allows users to manage heterogeneous storage devices in a Storage Area Network (SAN).
An HTTP server, called a provider, sends and receives XML requests to the storage devices to manage those devices and retrieve information about those devices.
Skylar One communicates with the provider to retrieve information about the SAN and its devices.
What Does the SMI-S: Array PowerPack Monitor?
To monitor storage arrays using Skylar One, you must install the "SMI-S: Array" PowerPack. This PowerPack enables you to discover, model, and collect data about storage arrays and their component devices.
The "SMI-S: Array" PowerPack includes:
- An example credential you can use to create Basic/Snippet credentials to connect to the SMI-S Provider.
- Dynamic Applications to discover and monitor the storage arrays
- Device classes for each type of storage array component device monitored by Skylar One
If you are monitoring EMC VNX storage arrays, then you should install and use the "EMC: VNX" PowerPack. For more information, see
If you are monitoring EMC VMAX storage arrays, then you should install and use the "EMC: VMAX" PowerPack. For more information, see
If you are monitoring Hitachi Data Systems Virtual Storage Platform arrays, then you should install and use the "Hitachi Data Systems: VSP" PowerPack. For more information, see
Installing the SMI-S: Array PowerPack
