Discovering SNMP Routers, Switches, and Firewalls
This section describes how to create SNMP credentials and discover SNMP network devices in Skylar One.
Prerequisites
If you configure your network device to respond to SNMP requests from Skylar One, you can discover your devices as SNMP devices. When Skylar One discovers a device as an SNMP device, Skylar One will automatically collect data supplied by the SNMP agent.
  • To configure your devices to respond to SNMP requests, see the documentation for your devices.
  • To use events in Skylar One, configure your devices to send syslog messages and traps to the Skylar One system. See the documentation for your devices to determine how to configure syslog and trap forwarding.
Creating an SNMP Credential
SNMP Credentials allow Skylar One to access SNMP data on a managed device. Skylar One uses SNMP credentials to perform discovery, run auto-discovery, and gather information from SNMP Dynamic Applications.
  2. Click the actions icon and select Create SNMP Credential. The Credential Editor page appears.
  • Timeout (ms). Time, in milliseconds, after which Skylar One will stop trying to communicate with the SNMP device. The default value is 1500.
  • Retries. Number of times Skylar One will try to authenticate and communicate with the external device. The default value is 1.
SNMP V1/V2 Settings
SNMP V3 Settings
  • SHA
  • SHA-224
  • SHA-256
  • SHA-384
  • SHA-512
The SHA option is SHA-128.
  • AES-128
  • AES-192
  • AES-256
  2. Repeat steps 1-4 for each SNMP-enabled device in your network that you want to monitor with Skylar One.
NOTE: When you define an SNMP Credential, Skylar One automatically aligns the credential with all organizations of which you are a member.
For more details on creating credentials, see the section on credentials.
Creating an SNMP Credential for Monitoring Multiple VRFs
To monitor multiple VRFs on your Nexus devices, you must create the SNMP credential with SNMP v2 or SNMPv3 settings and then manually align the "Cisco: VRF BGP Peers" Dynamic Application.
To create the SNMP credential:
  • Profile Name. Name of the credential. Can be any combination of alphanumeric characters.
  • SNMP Version. SNMP version. Select SNMP V2 or SNMP V3. SNMP v1 is not supported for monitoring multiple VRFs.
  • Port. The port Skylar One will use to communicate with the external device or application. The default value is 161.
SNMP V2 Settings
Supply values in the following field if you selected SNMP V2 in the SNMP Version field:
  • SNMP Community (Read-Only). Type the SNMP community string (password) required for read-only access of SNMP data on the remote device or application. If you are specifying more than one community string, separate them with a comma.
SNMP V3 Settings
Supply values in the following fields if you selected SNMP V3 in the SNMP Version field:
  • Authentication Protocol. Select SHA.
  • Security Level. Select Authentication and Encryption.
  • Context Name. Specify the context(s) in this field. If you are adding more than one, separate each with a comma.
  • Privacy Protocol. Select AES-128.
  • Privacy Protocol Pass Phrase. Privacy password for the credential. This field is optional.
To align the "Cisco: VRF BGP Peers" Dynamic Application:
  1. Go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface, or Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface).
  2. Locate your Cisco device and click its wrench icon (wrench icon).
  3. In the Collections tab, click the actions icon and then select Add Dynamic Application. The Dynamic Application Alignment page appears.
  4. In the Dynamic Applications field, select the "Cisco: VRF BGP Peers" Dynamic Application.
  5. In the Credentials field, select the SNMP credential you just created.
  6. Click the Save button.
Discovery for SNMP-Enabled Routers, Switches, and Firewalls
To maximize the data that can be collected from SNMP-enabled routers and switches, ensure that your devices include the following MIBs:
  • BRIDGE-MIB
  • CISCO-CDP-MIB
  • CISCO-ETHERNET-FABRIC-EXTENDER-MIB
  • CISCO-FCOE-MIB
  • CISCO-PORT-CHANNEL-MIB
  • CISCO-PROCESS-MIB
  • CISCO-SYSTEM-EXT-MIB
  • HOST-RESOURCES-MIB
  • IF-MIB
  • IP-MIB
  • SYSTEM-MIB
  • UCD-SNMP-MIB
During initial discovery, Skylar One automatically performs the following actions to gather information from each SNMP-enabled router and switch:
  • Uses the SYSTEM-MIB to retrieve a system description, SysObject ID, system uptime, system contact, system name, and system location
  • Uses the IF-MIB to retrieve information about all network interfaces on the device
  • Uses the IP-MIB to determine the IP address and netmask associated with each interface
  • Uses the retrieved SysObject ID to assign a device class to each device
  • Assigns a device ID, a device name, a primary IP address for use in Skylar One, and a primary credential
  • Checks each discovered device against the list of already-defined Dynamic Applications. Skylar One searches each discovered device to find "discovery objects" and aligns devices with the appropriate Dynamic Application(s).
  • Immediately after the initial discovery session is completed, Skylar One will use the aligned Dynamic Applications to collect additional data from devices.
  • Shortly after the initial discovery session, Skylar One uses internal processes to create network records for each IP address and interface.
  • Shortly after the initial discovery session, Skylar One uses the BRIDGE-MIB and the CISCO-CDP-MIB to create topology relationships for routers and switches.
For details on discovery, see the .section on Discovery.
Adding Devices Using Unguided Discovery
To run an unguided discovery:
  3. Click Select. The three-step discovery wizard appears, starting with the Basic Information page.
  1. Click Next. The Credential Selection page of the wizard appears.
  2. On the Credential Selection page, you can optionally do one of the following:
  • If the credential you need is not in the list, click the Create New button and select the credential type you want to create to open the Create Credential window, where you can specify the name and organization for the credential, the third-party username and password, and other data such as Cloud Type and Proxy information. You can also test the credential before you save using the Credential Tester panel. Click Save & Close to save the credential and return to the Credential Selection page of the guided discovery session. For more information on creating new credentials or testing credentials, see the section on Defining Credentials or Using the Credential Tester Panel.
  • To edit a credential on the Credential Selection page, click the name of the credential you would like to edit from the Name column and edit that credential as needed. You can also test the credential before you save using the Credential Tester panel. Click the Save & Close button on the Edit Credential window to save your updates.
  1. On the Credential Selection page of the Add Devices wizard, select one or more credentials to allow Skylar One to access a device's SNMP data and click Next. The Discovery Session Details page of the Add Devices wizard appears.
  • List of IPs/Hostnames. Provide a list of IP addresses, hostnames, or fully-qualified domain names for Skylar One to scan during discovery. This field is required. In this field, you can enter a combination of one or more of the following:
  • Which collector will discover these devices?. Select an existing collector group to monitor the discovered devices. Required.
When assigning devices to a collector group, Skylar One's multi-tenancy rules will validate that the collector group you select belongs to the organization you selected in the previous field. If you attempt to run a discovery session where the devices, collector group, and credentials do not all belong to the same organization, you will receive an error message and will not be able to save or execute the discovery session.
  • System Default (recommended). Use the value defined in the Behavior Settings page (System > Settings > Behavior) in the classic user interface of Skylar One.
  • 1. Model Device Only. Discovery will discover if the device is up and running and if so, collect the make and model of the device. Skylar One will then generate a device ID for the device so it can be managed by Skylar One.
If Skylar One cannot determine the appropriate Device Class, it will assign the device to the Generic SNMP Device Class.
  • System Default (recommended). Use the value defined in the Behavior Settings page (System > Settings > Behavior) in the classic user interface for Skylar One.
  • Port Scan All IPs. For the initial discovery session only, specifies whether Skylar One should scan all IP addresses on a device for open ports. The choices are:
  • Enabled. Skylar One will scan all discovered IP addresses for open ports.
  • Disabled. Skylar One will scan only the primary IP address (the one used to communicate with Skylar One) for open ports.
  • Port Scan Timeout. For the initial discovery session only, specifies the length of time, in milliseconds, after which Skylar One should stop trying to scan an IP address for open ports and begin scanning the next IP address (if applicable). Choices are:
  • Interface Inventory Timeout (ms). Specifies the maximum amount of time that the discovery processes will spend polling a device for the list of interfaces. After the specified time, Skylar One will stop polling the device, will not model the device, and will continue with discovery. The default value is 600,000 ms (10 minutes).
  • During the execution of this discovery session, Skylar One uses the value in this field first. If you delete the default values and do not specify another value in this field, Skylar One uses the value in the Global Threshold Settings page (System > Settings > Thresholds).
  • If you specify a value in this field and do not apply a device template to this discovery session, the Interface Inventory Timeout setting in the Device Thresholds page (Devices > Classic Devices > wrench icon > Thresholds, or Registry > Devices > Device Manager > wrench icon > Thresholds in the classic user interface) is set to this value for each discovered device. If there is no device template applied to the discovery session and no value is supplied in this field, Skylar One uses the value in the Global Threshold Settings page (System > Settings > Thresholds).
  • Maximum Allowed Interfaces. Specifies the maximum number of interfaces per devices. If a device exceeds this number of interfaces, Skylar One will stop scanning the device, will not model the device, and will continue with discovery. The default value is 10,000.
  • During the execution of this discovery session, Skylar One uses the value in this field first. If you delete the default values and do not specify another value in this field, Skylar One uses the value in the Global Threshold Settings page.
  • If you specify a value in this field and do not apply a device template to this discovery session, the Maximum Allowed Interfaces setting in the Device Thresholds page is set to this value for each discovered device. If there is no device template applied to the discovery session and no value is supplied in this field, Skylar One uses the value in the Global Threshold Settings page.
  • Selected. Skylar One will not attempt to discover interfaces for each device in the discovery session. For each discovered device, the Bypass Interface Inventory checkbox on the Device Investigator Settings tab will be selected.
  • Not Selected. Skylar One will attempt to discover network interfaces, using the Interface Inventory Timeout value and Maximum Allowed Interfaces value.
  • Discover non-SNMP. Specifies whether or not Skylar One should discover devices that don't respond to SNMP requests.
  • Selected. Skylar One will discover devices that don't respond to the SNMP credentials selected in the SNMP Credentials field. These devices will be discovered as "pingable" devices.
  • Not Selected. Skylar One will not discover devices that don't respond to the SNMP credentials selected in the SNMP Credentials fields.
You must either select a credential for the discovery session or select the Discover Non-SNMP option. Skylar One will prevent you from proceeding with discovery if you have not met those conditions.
  • Model Devices. Determines whether or not the devices that are discovered with this discovery session can be managed through Skylar One. Choices are:
  • Selected. When a device is modeled, Skylar One creates a device ID for the device; you can then access the device through the Device Manager page and manage the device in Skylar One.
  • Not Selected. If a device is not modeled, you cannot access the device through the Device Manager page, and you cannot manage the device in Skylar One. However, each discovered device will still appear in the Discovery Session logs. For each discovered device, the discovery logs will display the IP address and device class for the device. This option is useful when performing an initial discovery of your network, to determine which devices you want to monitor and manage with Skylar One. For the amount of time specified in the Device Model Cache TTL (h) field, a user can manually model the device from the Discovery Session window.
  • Selected. Skylar One will perform a DNS lookup for the device during discovery and each time Skylar One retrieves information from the device.
  • Not Selected. Skylar One will perform normal discovery.
  • Device Model Cache TTL (h). Amount of time, in hours, that Skylar One stores information about devices that are discovered but not modeled, either because the Model Devices option is not enabled or because Skylar One cannot determine whether a duplicate device already exists. The cached data can be used to manually model the device from the Discovery Session window.
  • Log All. Specifies whether or not the discovery session should use verbose logging. When you select verbose logging, Skylar One logs details about each IP address or hostname specified in the IP Address/Hostname Discovery List field, even if the results are "No device found at this address."
  • Select Device Template. As Skylar One discovers a device in the IP discovery list, that device is configured with the selected device template. You can select from a list of all device templates in Skylar One. For more information on device templates, see the Device Groups and Device Templates section.
Running Discovery in the Skylar One Classic User Interface
  • IP Address/Hostname Discovery List. Provide a list of IP addresses or fully-qualified domain names for Skylar One to scan during discovery. In this field, you can enter a combination of one or more of the following:
  • One or more single IPv4 addresses separated by commas. Each IP address must be in standard IP notation and cannot exceed 15 characters. For example, "10.20.30.1, 10.20.30.2, 10.20.30.3".
If you enter both the hostname and IP address of the same devices, Skylar One will discover two duplicate devices.
Skylar One will display an error if your discovery session exceeds the maximum size for optimum performance. Skylar One will display a warning message if your discovery session includes 100 or more IP addresses. The warning message will tell you that discovery with more than 100 IP addresses might "take a long time to discover".
  • SNMP Credentials. A community string that allows Skylar One to access a device's SNMP data. SNMP credentials are defined in the Credential Management page (System > Manage > Credentials). If you want to retrieve SNMP data from one or more devices, you must select one or more working SNMP credentials in this field. You can select multiple credentials from this field. Skylar One will try each selected credential when discovering devices and retrieving device data.
  • Other Credentials. A username and password pair (among other fields) that allows Skylar One to access a device's database data, SOAP data, XML data, WMI data, WBEM data, or data that is monitored with a Snippet Dynamic Application. These credentials are defined in the Credential Management page (System > Manage > Credentials). You can select multiple credentials from this field. Skylar One will try each selected credential when searching for Dynamic Applications to align with each discovered device.
  • 0. Model Device Only. Discovery will discover if the device is up and running and if so, collect the make and model of the device. Skylar One will then generate a device ID for the device so it can be managed by Skylar One.
  • 0. Disabled. Skylar One will scan only the primary IP address (the one used to communicate with Skylar One) for open ports.
  • 1. Enabled. Skylar One will scan all discovered IP addresses for open ports.
  • Detection Method & Port. During discovery, Skylar One will scan the list of ports selected in this field to determine if the range of devices is up and running and which ports are open on each discovered device. If a device does not respond to SNMP or ICMP, Skylar One uses an open port to collect availability data for that device. If you are not sure which ports are used by the range of devices, select the entry Default Method. Skylar One will check ICMP (ping), FTP, SSH, Telnet, SMTP, and HTTP ports.
  • Selected. Skylar One will not attempt to discover interfaces for each device in the discovery session. For each discovered device, the Bypass Interface Inventory checkbox in the Device Properties page will be selected.
  • Discover Non-SNMP Devices. Specifies whether or not Skylar One should discover devices that don't respond to SNMP requests.
  • Enabled. When a device is modeled, Skylar One creates a device ID for the device; you can then access the device through the Device Manager page and manage the device in Skylar One.
  • Disabled. If a device is not modeled, you cannot access the device through the Device Manager page, and you cannot manage the device in Skylar One. However, each discovered device will still appear in the Discovery Session logs. For each discovered device, the discovery logs will display the IP address and device class for the device. This option is useful when performing an initial discovery of your network, to determine which devices you want to monitor and manage with Skylar One. For the amount of time specified in the Device Model Cache TTL (h) field, a user can manually model the device from the Discovery Session window.
  • For Skylar One appliances, only the name of the appliance will appear in this field.
  • Organization. This field contains a list of all organizations defined in Skylar One. Devices discovered during the discovery session will be assigned to the selected organization.
  • Add Devices to Device Group(s). When Skylar One discovers a device in the IP discovery list, that device is added to each selected device group. You can select one or more device groups from a list of device groups in Skylar One that have "Discovery" selected in the Visibility field. For more information on device groups, see the Device Groups and Device Templates section.
  • Apply Device Template. As Skylar One discovers a device in the IP discovery list, that device is configured with the selected device template. You can select from a list of all device templates in Skylar One. For more information on device templates, see the Device Groups and Device Templates section.
