Interfaces and Networks
This section describes how to view the interfaces and networks for the routers, switches, and firewalls that Skylar One discovers.
Viewing All Interfaces Discovered by Skylar One
During discovery, Skylar One discovers all interfaces on each discovered device. The list of all interfaces is displayed in the Network Interfaces page.
The Network Interfaces page allows you to view a list of all interfaces, view details about each interface, define a monitoring policy for an interface, and view bandwidth reports for each interface.
To view a list of all interfaces discovered by Skylar One:
  2. The Network Interfaces page displays a list of all network interfaces discovered by Skylar One.
  3. The Network Interfaces page displays the following for each interface.
To sort the list of interfaces, click on a column heading. The list will be sorted by the column value, in ascending order. To sort the list by descending order, click the column heading again.
  • Device Name. Name of the device where the interface resides.
  • Port/Sub. Port and sub-port (if applicable) of the interface.
  • IF Name. The name of the network interface. The auto-name, generated by Skylar One, is device_name:interface_number. You can define a different name in the Interface Properties page.
  • Tags. Displays a comma-delimited list of descriptive tags that have been manually defined for the interface. Interface tags are used to group interfaces in an IT service policy. To add or edit the tags for an interface, click its wrench icon (wrench icon). In the Edit Network Interface Tags modal that appears, supply a comma-delimited list of tags in the Tags field, and then click the Save button.
  • Organization. Organization associated with the network interface. This can be the organization associated with the device where the interface resides, or it can be an organization that has emissary rights to the interface.
  • Alias. User-defined name assigned to the interface.
  • MAC Address. A unique number that identifies the interface. MAC Addresses are defined by the hardware manufacturer.
  • IF Index. A unique number (greater than zero) that identifies each interface on a device. These numbers are defined within the device.
  • IF Type. A string that describes the type of interface, as defined by the standards group Internet Assigned Numbers Authority (IANA).
  • Status. Consists of two parts:
  • Administration Status. Specifies how the network interface has been configured on the device. Can be one of the following:
    • Up. Network interface has been enabled.
    • Down. Network interface has been disabled.
  • Operation Status. Specifies current state of the network interface. Can be one of the following:
    • Up. Network interface is transmitting and receiving data.
    • Down. Network interface cannot transmit or receive data.
NOTE: Skylar One generates an event when a network interface has an administrative status of "up" and an operation status of "down".
  • Measure. Unit of measurement for bandwidth reports for the interface. The choices are:
  • Mega
  • Giga
  • Kilo
  • Tera
  • Peta
  • Interface Speed. The number of megabits per second that can pass through the network interface.
  • Alerting. Specifies whether or not internal collection events will be generated for the selected interfaces.
  • Yes. Skylar One monitors the network interface and generates internal collection events when the required conditions are met.
  • No. Skylar One monitors the network interface, but internal collection events are not generated for the interface.
  • Auto-Name Update. Specifies whether or not Skylar One will update and/or overwrite the interface name during auto-discovery.
  • Yes. Skylar One can update and/or overwrite the interface name during auto-discovery.
  • No. Skylar One will not update and/or overwrite the interface name during auto-discovery.
  • Collection Frequency. When you define a monitoring policy for an interface, you must specify how frequently you want Skylar One to collect data from the interface. Your choices are every:
  • 1 Minute
  • 5 Minutes
  • 10 Minutes
  • 15 Minutes
  • 30 Minutes
  • 60 Minutes
  • 120 Minutes
  • Collect Errors. Specifies whether or not Skylar One will collect data about packet errors on the interface. Packet errors can occur when packets are lost due to network outages or faulty adapter hardware. Your choices are:
  • Yes. Skylar One will collect data on packet errors that occur on the interface.
  • No. Skylar One will not collect data on packet errors that occur on the interface.
  • Collect Discards. Specifies whether or not Skylar One will collect data about interface discards. Discards can occur when an interface receives more traffic than it can handle. Discards can also occur when an interface has been specifically configured to discard packets. For example, a network administrator might configure a router's interface to discard packets from an unauthorized IP. Your choices are:
  • Yes. Skylar One will collect data about packet discards that occur on the interface.
  • No. Skylar One will not collect data about packet discards that occur on the interface.
  • Collect CBQoS. Specifies whether Skylar One will collect CBQoS (Class-Based Quality-of-Service) data for this interface. This column appears only if you have enabled the field Enable CBQoS Collection in the Behavior Settings page (System > Settings > Behavior). If Collect CBQoS is enabled for an interface, Skylar One will display the collected CBQoS data in Device Performance reports associated with the device that contains this interface. Choices are:
  • Yes. Skylar One will collect CBQoS data for this interface.
  • No. Skylar One will not collect CBQoS data for this interface.
For more information about CBQoS, see the section on Class-Based Quality of Service (CBQoS).
  • Collect Packets. Specifies whether Skylar One will collect network traffic data, in packets, for this interface. If Collect Packets is enabled for an interface, Skylar One will display the collected data in Device Performance reports associated with the device that contains this interface. Choices are:
  • Yes. Skylar One will collect packet data for this interface.
  • No. Skylar One will not collect packet data for this interface.
  • Counter Setting. Specifies whether the interface uses a 32-bit counter or a 64-bit counter to measure bandwidth on the interface.
NOTE: If an interface has a status of "down" during initial discovery, Skylar One will discover the interface but assign the interface the default Counter Setting of "32". During re-discovery or nightly auto-discovery, Skylar One will update Counter Setting to "64" if applicable.
  • State. Specifies whether Skylar One monitors the network interface and collects data about the network interface for reports. Can be either Enabled or Disabled.
  • Edit Date. Date and time the monitoring policy for the interface was created or last edited. If the interface is using the default monitoring policy, the edit date reflects the date that the interface was discovered by Skylar One.
Viewing Interfaces for a Single Device
In the Device Administration panel for a device, you can view the Device Interfaces page. The Device Interfaces page displays detailed information about each network interface on the device and allows you to define monitoring policies for interfaces on the device. When you define a monitoring policy for an interface, Skylar One will monitor the interface and gather usage data from the interface. Skylar One uses the data retrieved from the interface to generate bandwidth reports for the interface.
In the Device Reports panel for a device, you can view the Interfaces Found page. The Interfaces Found page displays detailed information about each network interface on the device. The Interfaces Found page allows you to view a list of all interfaces on the device, view details about each interface, and view bandwidth usage reports for each interface.
To view details about the network interfaces on a device:
  2. Find the device for which you want to view the list of network interfaces, then do one of the following:
  • Click its wrench icon (wrench icon), followed by the Interfaces tab, to view the Device Interfaces page.
  • Click the bar graph icon (), followed by the Interfaces tab, to view the Interfaces Found page.
  1. Both pages display icons to represent the interfaces on the device.
  2. The page displays an icon for each interface on the device. Each icon provides a visual overview of the interface.
  3. For details on interface icons, click the Legend button, or in the Actions menu, select Interface Legend. The Interface Legend modal page displays each type of interface icon with explanatory callouts.
  4. When you mouse over the icon for that interface, the Interface Details pop-up window appears. This window displays details about the interface and its current monitoring policy.
  5. The Interface Details pop-up window displays the following about an interface:
  • Port / Sub. Port and sub-port (if applicable) of the interface.
  • Interface Name. The name of the network interface. The auto-name, generated by Skylar One, is device_name:interface_number.
  • Alias. Easy-to-remember, human-readable name for the network interface.
  • Hardware Desc. Description of the network interface. Usually a description of a network-interface card.
  • MAC Address. A unique number that identifies network hardware. MAC Addresses are defined by the hardware manufacturer.
  • MAC Vendor. Manufacturer of the network interface.
  • Connection Speed. The amount of data per second that can pass through the network interface.
  • Collect State. Specifies whether or not Skylar One monitors the network interface and collects data from the network interface for reports.
  • Admin Status. Specifies how the network interface has been configured on the device. Can be one of the following:
  • Up. Network interface has been configured to be up and running.
  • Operational Status. Specifies current state of the network interface. Can be one of the following:
  • Collect Freq. Frequency at which Skylar One will poll the interface to collect data. Choices are 1 minute, 5 minutes, 10 minutes, 30 minutes, 60 minutes, and 120 minutes.
  • Collect Errors. Specifies whether or not Skylar One will collect data about packet errors on the interface. Packet errors occur when packets are lost due to hardware problems such as network outages or faulty adapter hardware.
  • Collect Discards. Specifies whether or not Skylar One will collect data about interface discards. Discards occur when an interface receives more traffic than it can handle. Discards can also occur when an interface has been specifically configured to discard. For example, a network administrator might configure a router's interface to discard packets from an unauthorized IP address.
  • Alerts. Specifies whether or not Skylar One will generate internal collection events for the interface. When disabled, the interface is monitored, but internal collection events are not generated for the interface.
  • Rollover Alerts. Specifies whether or not Skylar One will generate an event when the counter for the interface rolls over.
NOTE: Rollovers and Rollover Alerts apply only to 32-bit counters and not to 64-bit counters.
  • IP. IP address and network mask assigned to the interface.
  • Counter Type. Specifies whether the interface uses a 32-bit counter or a 64-bit counter to measure bandwidth on the interface.
NOTE: If an interface has a status of "down" during initial discovery, Skylar One will discover the interface but assign the interface the default Counter Type of "32". During re-discovery or nightly auto-discovery, Skylar One will update the Counter Type to "64" if applicable.
  • IANA Type. A string that describes the type of interface, as defined by the standards group Internet Assigned Numbers Authority.
  • Interface Index. A unique number (greater than zero) that identifies each interface on a device. These numbers are defined by the device.
  1. In the Device Interfaces page, clicking on an interface icon leads to the Interface Properties page, where you can define a monitoring policy for an interface.
  2. In the Interfaces Found page, clicking on an interface icon leads to the Network Bandwidth Usage report in the Device Performance page.
Overview of Network Records
During discovery of an SNMP-enabled device, Skylar One collects information about the network interfaces on that device using the standard IF-MIB. After collecting information about each interface, Skylar One collects information about the IP addresses associated with those interfaces using the standard IP-MIB.
After discovery, Skylar One runs a process that classifies each IP address associated with that device. The classification process calculates the network address by performing a bitwise "AND" operation using the IP address and the network mask. Skylar One determines whether the IP address for the device needs to be associated with an existing network record or whether to create a new network record.
After an IP address is associated with a network record, the interface associated with that IP address appears in the Network Browser page for that network record. To access the Network Browser page for a network record, go to the IPv4 Networks page (Registry > Networks > IPv4 Networks) and select the desired interface icon.
IPv4 Networks
The IPv4 Networks page (Registry > Networks > IPv4 Networks) lists all networks and subnets detected by ScienceLogic auto-discovery and all manually defined (new) networks.
The IPv4 Networks page allows you to easily manage networks and IP addresses. From the IPv4 Networks page, you can view detailed data about the network, keep records of subnets, and determine which IP addresses are in use and which IP addresses are available.
NOTE: Users of type "user" can view only IPv4 networks that are aligned with the same organization(s) to which the user is aligned. Users of type "administrator" can view all IPv4 networks.
Viewing the List of IPv4 Networks
The table in the IPv4 Networks page (Registry > Networks > IPv4 Networks) contains an entry for each network managed by Skylar One.
The IPv4 Networks page displays the following about each managed network:
To sort the list of networks, click on a column heading. The list will be sorted by the column value, in ascending order. To sort by descending order, click the column heading again. The Edit Date column sorts by descending order on the first click; to sort by ascending order, click the column heading again.
  • Network. IP address of the entire network.
  • Subnet Mask. Subnet mask for the subnet.
  • Bits. The number of bits used for the network address.
  • Used/Max. Number of IP addresses discovered and monitored by Skylar One and the maximum number of IP addresses allowed in the subnet.
  • % Used. Percentage of total addresses in the network that have been discovered and monitored by Skylar One. In the Account Preferences page, you can specify whether or not you want to include empty networks (networks with no devices or interfaces) in the list of networks. These networks will have 0% in the % Used column.
  • Devs. Number of devices in the subnet.
  • IFs. Number of interfaces in the subnet.
  • Collection Group. The collector group associated with the network. For All-In-One Appliances, this field displays only the built-in Collector Group (and any virtual Collector Groups).
  • Organization. Organization associated with the network.
  • Net ID. Unique network ID, assigned by Skylar One.
  • Creation Date. Date the network was discovered or manually defined.
  • Edit User. User who created or last edited the network's properties.
  • Edit Date. Date the network was created or last edited, whichever is later.
  • Tools. For each network in the table, the following tools are available:
  • View/Edit Network Properties (wrench icon). Displays the Network Properties modal page, where you can view and edit the basic properties of an IPv4 network.
  • Browse Network (). Leads to the Network Browser page. From this page, you can view a list of IP addresses (used and unused) included in a network, a list of devices included in a network, and a list of interfaces included in a network.
  • View/Edit Aligned Devices (). Leads to the Network Browser page, where you can view a list of devices associated with a network.
  • View/Edit Aligned Interfaces (). Leads to the Network Browser page, where you can view a list of interfaces associated with a network.
  • View/Edit Organization (). Leads to the Organizational Summary page, where you can view and edit information associated with the organization.
  • View Network Map (). Leads to the Layer-2 Maps page, where you can view and edit a graphical representation of a layer-2 network.
  • View a Network Report (). Opens the Report Creator modal page, where you can specify information to include in the report and the format in which to generate the report.
  • Add Network to Dynamic Discovery (). Adds the network to the dynamic-discovery queue. Skylar One will perform dynamic-discovery on all of the IP addresses in the network and gather information about any devices and interfaces in the network. Leads to the Discovery Control Panel page, with the selected network as the value in the discovery list.
  • Create a Ticket (). Leads to the Ticket Editor page, where you can create a ticket that will be associated with the selected network.
  • Delete (). To delete the network, select this checkbox and then click the Delete button. To select all the checkboxes, click the large red check icon.
Browsing a Network
From the IPv4 Networks page, you can browse a network and view the IPs, devices, and interfaces within the network. To do this:
NOTE: Users of type "user" can view only devices that are aligned with the same organization(s) to which the user is aligned. Users of type "administrator" can view all devices. Users of type "user" can view only interfaces that are aligned with the same organization(s) to which the user is aligned or have been emissaried to the user's organization(s). Users of type "administrator" can view all interfaces.
  1. Go to the IPv4 Networks page (Registry > Networks > IPv4 Networks).
  2. In the IPv4 Networks page, find the network you want to browse.
  3. Click the magnifying glass icon () for that network.
  4. The Network Browser page appears.
  5. In the drop-down menu in the upper left, you can choose to view all IP addresses in the network, all devices in the network, or all interfaces in the network.
Viewing Used and Unused IP Addresses in a Network
From the IPv4 Networks page, you can view a list of all IP addresses, used and unused, in a network. To do this:
  • Go to the IPv4 Networks page (Registry > Networks > IPv4 Networks).
  • In the IPv4 Networks page, find the network you want to view.
  • Click the magnifying glass icon () for that network.
  • The Network Browser page appears.
  • In the drop-down menu in the upper left, you can choose to view all IP addresses in the network, all devices in the network, or all interfaces in the network.
Viewing Devices Aligned with a Network
From the IPv4 Networks page, you can view a list of all devices in a network To do this:
  2. In the IPv4 Networks page, find the network you want to view.
  3. Click the devices icon () for that network.
  4. The Network Browser page appears and displays the list of devices in the network.
Viewing Interfaces Aligned with a Network
From the IPv4 Networks page, you can view a list of all interfaces in a network To do this:
  3. Click the interface icon () for that network.
  4. The Network Browser page appears and displays the list of interface in the network.
