This section describes how to configure and discover VOSS Insights appliances for monitoring by Skylar One using the "VOSS Insights: Appliance Monitoring" PowerPack.
Creating a SOAP/XML Credential for VOSS Insights Appliances
To configure Skylar One to monitor VOSS Insights appliances, you must first create a SOAP/XML credential. This credential allows the Dynamic Applications in the "VOSS Insights: Appliance Monitoring" PowerPack to connect with the VOSS Insights appliance.
To configure the SOAP/XML credential:
  2. Locate the VOSS Insights: Appliance Sample credential, click its Actions icon (actions icon) and select Duplicate. A copy of the credential appears.
  3. Click the Actions icon (actions icon) for the "VOSS Insights: Appliance Sample copy" credential and select Edit. The Edit Credential page appears:
  • Name. Enter a name for the VOSS Insights credential.
  • URL. Enter the IP address of the VOSS Insights appliance you want to monitor.
  • HTTP Auth User. Enter the username for a user with access to the VOSS Insights appliance.
  • HTTP Auth Password. Enter the password for the VOSS Insights account username.
If you would like to test your credential using the Credential Tester panel, click Save & Test. For detailed instructions on using the Credential Tester panel, see the Testing the VOSS Insights Credential section.
Creating a SOAP/XML Credential for VOSS Insights Appliances in the Skylar One Classic User Interface
  2. Locate the VOSS Insights: Appliance Sample credential, then click its wrench icon (wrench icon). The Edit SOAP/XML Credential modal page appears.
  • Profile Name. Enter a name for the VOSS Insights credential.
  1. Click the Save As button.
Skylar One includes a Credential Test for VOSS Insights. Credential Tests define a series of steps that Skylar One can execute on demand to validate whether a credential works as expected.
The VOSS Insights Rest Cred Tester can be used to test a SOAP/XML credential for monitoring VOSS Insights using the Dynamic Applications in the "VOSS Insights: Appliance Monitoring"  PowerPack. The "VOSS Insights Rest Cred Tester" performs the following steps:
  • Test Reachability. Checks to see if the VOSS Insights device is reachable using ICMP.
  • Test Port Availability. Checks to see if the appropriate port is open.
  • Test Silo Rest Pack. Attempts to collect data using the REST protocol collector using the given snippet argument.
To test the VOSS Insights credential:
  2. Locate the credential you wish to test, select the Actions button (actions icon) next to it and click Edit/Test. The Edit Credential modal page appears:
  1. In the Credential Tester pane on the right, supply values in the following fields:
  • Select Credential Test. Select the "VOSS Insights Rest Cred Tester".
  • Select Collector. Select the All-In-One Appliance or Data Collector that will run the test
  • IP or Hostname to test. Enter the IP address or hostname of your VOSS Insights appliance.
  • Step. The name of the step.
  • Status. The result of this step indicates whether the credential or the network environment is configured correctly (Passed) or incorrectly (Failed).
Testing the VOSS Insights Credential in the Skylar One Classic User Interface
The VOSS Insights Rest Cred Tester can be used to test a SOAP/XML credential for monitoring VOSS Insights using the Dynamic Applications in the VOSS Insights: Appliance Monitoring PowerPack. The VOSS Insights Rest Cred Tester performs the following steps:
  2. Locate the VOSS Insights Rest Cred Tester and click its lightning bolt icon (). The Credential Tester modal page appears.
Discovering the VOSS Insights Device
To monitor your VOSS Insights system, you must run a discovery session to discover the server on which VOSS Insights is installed.
To create and run a discovery session that will discover a VOSS Insights appliance:
  2. On the Credential Selection tab, locate and select the SOAP/XML credential you created for VOSS Insights appliances.
  • List of IP/Hostnames. Type the IP address for the VOSS Insights appliance.
    • Select Device Template. If you configured a VOSS Insights device template, select it here. Otherwise, leave the default selection.
Creating the VOSS Insights Virtual Device in the Skylar One Classic User Interface
To monitor your VOSS Insights appliance, you must create a virtual device that represents that appliance. A virtual device is a user-defined container that represents a device or service that cannot be discovered by Skylar One. You can use the virtual device to store information gathered by policies or Dynamic Applications.
To create a virtual device that represents your VOSS Insights appliance:
  2. Click Actions and select Create Virtual Device from the menu. The Virtual Device modal page appears.
  • Device Class. Select VOSS Insights | VOSS Insights: Arbitrator or VOSS Insights | VOSS Insights: Reporter depending on the VOSS Insights appliance you are discovering.
Manually Aligning and Verifying Dynamic Application Alignment
After creating the VOSS Insights virtual device, you must manually align the VOSS Insights Dynamic Applications to the VOSS Insights virtual device.
To manually align the VOSS Insights Dynamic Applications:
  1. Go to the Devicespage (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface).
  2. Locate your VOSS Insights virtual device and click its name.
  3. In the Device Investigator, click the Collections tab.
  4. Click the Edit button at the top of the page, then click the Align Dynamic App button.
  5. In the Align Dynamic Application modal, click Choose Dynamic Application.
Select the following Dynamic Applications to a VOSS Insights Reporter appliance:
Dynamic Application Credential Type
VOSS Insights Reporter: Configuration Snippet Configuration
VOSS Insights Reporter: CPU Snippet Performance
VOSS Insights Reporter: Memory Snippet Performance
VOSS Insights: Service Status Snippet Configuration
REST: Performance Metrics Monitor Snippet Performance
Select the following Dynamic Applications to a VOSS Insights Arbitrator appliance:
VOSS Insights Arbitrator: Configuration Snippet Configuration
VOSS Insights Arbitrator: CPU Snippet Performance
VOSS Insights Arbitrator: Disk Snippet Performance
VOSS Insights Arbitrator: Memory Snippet Performance
VOSS Insights Arbitrator: Processing Rate Snippet Performance
  1. When you have finished selecting Dynamic Applications, click Select.
  2. In the Align Dynamic Application modal, de-select the Use Device SNMP Credential box. Click the Choose Credential option that appears.
  3. Select the VOSS Insights credential you created and click Select.
  4. Click Align Dynamic App to align the Dynamic Application with the VOSS Insights virtual device.
Manually Aligning VOSS Insights Dynamic Applications in the Skylar One Classic User Interface
  1. Click the wrench icon (wrench icon) for your VOSS Insights virtual device.
  3. Click the actions icon and select Add Dynamic Application from the menu.
  1. In the Dynamic Application Alignment modal:
  • In the Dynamic Applications field, select a Dynamic Application to align. Depending on the type of VOSS Insights appliance, align Dynamic Applications according to the tables below.
Align the following Dynamic Applications to a VOSS Insights Reporter appliance:
Align the following Dynamic Applications to a VOSS Insights Arbitrator appliance:
  • In the Credentials field, select the credential you created for your appliance.
  1. Click Save to align the Dynamic Application with the VOSS Insights virtual device.
