What Does the vLLM Monitoring PowerPack Monitor?
To monitor vLLM deployments using Skylar One, you can install the "vLLM Monitoring" PowerPack. This PowerPack enables you to align Dynamic Applications to vLLM deployments to collect data.
The "vLLM Monitoring" PowerPack includes:
- Dynamic Applications that discover and collect data from vLLM.
Installing the vLLM Monitoring PowerPack
