The skyautocontrol command-line utility was called iservicecontrol and powerflowcontrol in previous release of Skylar Automation. You can use either "iservicecontrol" or "pfctl" in commands, but both options will eventually be deprecated in favor of "skyautocontrol".
What is the skyautocontrol Utility?
The skyautocontrol (skyautoctl) command-line utility included in Skylar Automationcontains automatic cluster healthcheck and autoheal actions that will verify the configuration of your cluster or single node. The utility also includes an autocluster action that performs multiple administrator-level actions on either the node or the cluster.
The skyautocontrol (skyautoctl) utility is included in the latest release of Skylar Automation. If you need a newer version, you can download the latest version from the ScienceLogic Support site at https://support.sciencelogic.com/s/.
Notes about installing the utility:
- The skyautocontrol (skyautoctl) command-line utility requires port 22 on all host nodes.
- You can use key-based authentication instead of username and password authentication for the skyautocontrol (skyautoctl) command-line utility.
- If the isadmin (host) password contains a special character, such as an "@" or "#" symbol, the password must be escaped in the iservicecontrol commands by adding single quotes, such as 'user:host_password'. For example: pfctl --host 10.10.10.100 'isadmin:testing@is' --host 10.10.10.102 'isadmin:testing@is' --host 10.10.10.105 'isadmin:testing@is' autocluster
The skyautocontrol (skyautoctl) command-line utility was updated to let any user run the utility. The default isadmin user already meets these requirements, and this update is relevant only if your Skylar Automation environment uses custom users or processes.
If yourSkylar Automation system is hosted in AWS, or if your company does not permit password-based SSH access, you can create a configuration object in Skylar Automation to use with the skyautocontrol utility. When you create the configuration object, specify the private key to use to SSH into each of the nodes. For example:
hosts:
10.2.11.101:
user: isadmin
key_file: /home/ec2-user/key
10.2.11.102:
user: isadmin
key_file: /home/ec2-user/testkey
10.2.11.103:
user: isadmin
Then you can run skyautocontrol with the --config option:
skyautoctl --config <path_to_config> autocluster
User Requirements for using the skyautocontrol utility
The user requirements for working with skyautocontrol include the following:
The user must belong to the iservices group.
The user must belong to the docker group.
The user must belong to the systemd-journal group, or have permission to view journalctl logs (to check for errors in Docker services).
The user must have sudo permission (to set Skylar Automation configuration file group ownership).
The skyautocontrol utility does not require sudo permission to execute cluster and node actions. If you do run skyautocontrol once as sudo, it is expected that you would need to continue using sudo to modify files. ScienceLogic recommends that you interact with pfctl without sudo, by using a non-root user (like isadmin) that is part of the iservices group. To reset the file ownership, clear out the files from /tmp and re-run the pfctl utility without sudo, as a user that belongs to the iservices group.
Installing the skyautocontrol utility
When updating or installing the skyautocontrol utility, you will need to do so as the root user.
To download and install the skyautocontrol utility:
Go to the ScienceLogic Support site at https://support.sciencelogic.com/s/.
Click the tab and select Downloads. The Skylar Automation page appears.
Click the link for the current release. The Release Version page appears.
In the Release Files section, click the link for the version of skyautocontrol you want to download. The Release File Details page appears.
Click the button to download the .whl file for the skyautocontrol utility.
Using WinSCP or another file-transfer utility, copy the .whl file to a directory on the Skylar Automation system.
Go to the console of the Skylar Automation system or use SSH to access the Skylar Automation system.
To install the utility, run the following command:
sudo pip3 install skyautoctl-x.x.x-py3-none-any.whl
where x.x.x is the skyautocontrol (skyautoctl) version number.
To check the version number of the utility, run the following command:
pip3 show skyautoctl
Getting Help with the skyautocontrol utility
For a detailed list of all of the actions you can run on a single node, SSH to the Skylar Automation server and run the following command:
skyautoctl node-action --help
For a detailed list of all of the actions you can run on a clustered system, run the following command:
skyautoctl cluster-action --help
To view updated and expanded help text, run the following command :
skyautoctl --help
To check the installed pfctl version, run the following command:
skyautoctl --version
NOTE: If you get the "Error: No such option: --version Did you mean --json?" error message when running skyautoctl --version, you might have an older version of skyautocontrol (previously pfctl) that was installed as a different user. To resolve this, be sure to install the most recent version of the skyautocontrol utility version as root with sudo, and remove any other versions installed by other users (isadmin or ec2-user):
su isadmin
The skyautocontrol (skyautoctl) command-line utility performs multiple administrator-level actions in a clustered Skylar Automation environment. The skyautocontrol (skyautoctl) utility contains automatic cluster healthcheck and autoheal capabilities that you can use to prevent issues with your Skylar Automation environment:
- The healthcheck action executes various commands to verify configurations, proxies, internal connectivity, queue cluster, database cluster, indexes, NTP settings, Docker versions on all clusters, and more. Any previously reported troubleshooting issues are addressed with the healthcheck action.
- The autoheal action automatically takes corrective action on your cluster.
After deploying any clusters in a Skylar Automation system, or if you are troubleshooting an existing cluster, you should first run the healthcheck action to generate immediate diagnostics of the entire cluster and all services and containers associated with the cluster. If the healthcheck action finds any issues, you can run the autoheal action to attempt to address those issues.
You can view the current Skylar Automation version and the installed skyautocontrol (skyautoctl) version if you add --json at the start of the healthcheck command.
healthcheck
The following commands show the formatting for a healthcheck action for a single node, followed by an example:
skyautoctl --host <pf_host_ip_address> <username>:<host_password> node-action --action healthcheck
skyautoctl --host 10.2.11.222 isadmin:isadmin222 node-action --action healthcheck
The following commands show the formatting for a healthcheck action for a clustered environment, followed by an example:
skyautoctl --host <pf_host_ip_address> <username>:<host_password> --host <host> <username>:<host_password> --host <pf_host_ip_address> <username>:<host_password> cluster-action --action healthcheck
skyautoctl --host 10.2.11.222 isadmin:isadmin222 --host 10.2.11.232 isadmin:isadmin232 --host 10.2.11.244 isadmin:isadminpass cluster-action --action healthcheck
As a best practice, run the healthcheck action once a day on your Skylar Automation to identify and address any potential issues with the system before those issues impact operations.
Additional Features with the healthcheck Action
Starting with version 2.7.4 of the pfctl utility, the healthcheck node-actions and cluster-actions include the following features:
- check_debug_run. Checks if you have run any debug-level runs of Skylar Automation applications in the past day and provides a notification if you have.
- check_schedule_debug_enable. Checks if you have scheduled any debug-level runs of Skylar Automation applications and provides a notification if you have.
autoheal
The following commands show the formatting for an autoheal action for a single node, followed by an example:
skyautoctl --host <host> <username>:<host_password> node-action --action autoheal
skyautoctl --host 10.2.11.222 isadmin:isadmin222 node-action --action autoheal
The following commands show the formatting for an autoheal action for a clustered environment, followed by an example:
skyautoctl --host <host> <username>:<host_password> --host <host> <username>:<host_password> --host <host> <username>:<host_password> cluster-action --action autoheal
skyautoctl --host 10.2.11.222 isadmin:isadmin222 --host 10.2.11.232 isadmin:isadmin232 --host 10.2.11.244 isadmin:isadminpass cluster-action --action autoheal
Example Output
The following section lists example healthcheck output:
verify db host for cluster 10.2.11.222...........[OK]
check dex connectivity 10.2.11.222...............[OK]
check rabbit cluster count 10.2.11.222...........[OK]
check rabbit cluster alarms 10.2.11.222..........[OK]
verify cmd in container 10.2.11.222..............[OK]
verify cmd in container 10.2.11.232..............[Skipped - iservices_steprunner not found on 10.2.11.232]
verify cmd in container 10.2.11.232..............[OK]
verify cmd in container 10.2.11.232..............[Skipped - iservices_contentapi not found on 10.2.11.232]
verify cmd in container 10.2.11.244..............[OK]
get file hash 10.2.11.222........................[OK]
get file hash 10.2.11.232........................[OK]
/etc/iservices/isconfig.yml does not match between 10.2.11.222 and 10.2.11.232
get file hash 10.2.11.244........................[OK]
/opt/iservices/scripts/docker-compose.yml does not match between 10.2.11.222 and 10.2.11.244
check cpu 10.2.11.222............................[OK]
check disk 10.2.11.222...........................[OK]
check memory 10.2.11.222.........................[Failed]
check cpu 10.2.11.232............................[OK]
check disk 10.2.11.232...........................[OK]
check memory 10.2.11.232.........................[OK]
check cpu 10.2.11.244............................[OK]
check disk 10.2.11.244...........................[OK]
check memory 10.2.11.244.........................[OK]
Utilization warnings in the cluster:
{'10.2.11.222': ['There is less than 2000mb memory available']}
verify ntp sync 10.2.11.222......................[OK]
verify ntp sync 10.2.11.232......................[OK]
verify ntp sync 10.2.11.244......................[OK]
check replica count logs 10.2.11.222.............[OK]
check replica count content 10.2.11.222..........[Failed]
Identified missing replicas on some buckets: ['Replica count for bucket: content is not the expected 2']
verify pingable addr 10.2.11.222.................[OK]
verify pingable addr 10.2.11.232.................[OK]
verify pingable addr 10.2.11.244.................[OK]
get exited container count 10.2.11.222...........[OK]
get exited container count 10.2.11.232...........[OK]
get exited container count 10.2.11.244...........[OK]
6 exited (stale) containers found cluster-wide
verify node indexes 10.2.11.222..................[Failed]
Some nodes are missing required indexes. Here are the nodes with the missing indeces:
Missing the following indexes: {'couchbase.isnet': ['idx_casbin'], 'couchbase-worker2.isnet':
['idx_content_configuration']}
Using skyautocontrol healthcheck on the docker-compose file
You can also validate the docker-compose file with the skyautocontrol healthcheck action. The action will show a message if pypiserver or dexserver services are not configured properly in the docker-compose file. You can fix these settings manually or with the skyautocontrol autoheal action, which corrects the docker-compose file and copies it to all the nodes in the clustered environment.
When using version 1.3.0 or later of the skyautocontrol (formerly powerflowcontrol) command-line utility, the autocluster action validates and fixes the pypiserver and dexserver services definitions in the docker-compose file.
The healthcheck action in the skyautocontrol (skyautoctl) command-line utility for Skylar Automationclusters will check the Docker version for each cluster to ensure that the Docker version is the same in all the hosts.
autocluster
You can use the skyautocontrol (skyautoctl) command-line utility to perform multiple administrator-level actions on your Skylar Automation cluster. You can use the autocluster action with the skyautocontrol (skyautoctl) command to automate the configuration of a three-node cluster.
If you are using another cluster configuration, the deployment process should be manual, because the skyautocontrol (skyautoctl) utility only supports the automated configuration of a three-node cluster.
The autocluster action will completely reset and remove all data from the system. When you run this action, you will get a prompt verifying that you want run the action and delete all data.
To automate the configuration of a three-node cluster, run the following command:
skyautoctl --host <sa_host1> <username>:<host_password> --host <sa_host2> <username>:<host_password> --host <sa_host3> <username>:<host_password> autocluster
skyautoctl --host 192.11.1.1 isadmin:passw0rd --host 192.11.1.2 isadmin:passw0rd --host 192.11.1.3 isadmin:passw0rd autocluster
Running this command will configure your Skylar Automation three-node cluster without any additional manual steps required.
You can use the generate_haproxy_config cluster-action in the skyautocontrol (skyautoctl) utility to create an HAProxy configuration template that lets you easily set an HAProxy load balancer for a three-node cluster.
skyautoctl --host <host_IP_1> user:host_password --host <host_IP_2> user:host_password --host <host_IP_3> user:host_password cluster-action --action generate_haproxy_config
or
skyautoctl --config skyautoctl.yml cluster-action --action generate_haproxy_config
apply_<n>GB_override, verify_<n>GB_override
The actions in this topic are available in the skyautocontrol (formerly powerflowcontrol) utility version 2.7.4 and later.
You can use the following cluster-actions to apply and verify 16 GB, 32 GB, and 64 GB overrides to SaaS Skylar Automation systems only. These actions let you control the memory allocation of the Skylar Automation nodes and ensure full replication of all services in any failover scenario. In addition, when you run these actions on a SaaS Skylar Automation system, the docker-compose.yml file is updated with deployment configurations specific to a SaaS environment.
- apply_16GB_override and verify_16GB_override. These settings support up to 25,000 to 30,000 devices, depending on the relationship depth of the devices.
- apply_32GB_override and verify_32GB_override. These settings support up to approximately 70,000 devices.
- apply_64GB_override and verify_64GB_override.
The following command is an example of a skyautocontrol (skyautoctl) command to apply the 32 GB override:
skyautoctl --host 10.10.10.100 'isadmin:testing@is' --host 10.10.10.102 'isadmin:testing@is' --host 10.10.10.105 'isadmin:testing@is' cluster-action --action apply_32GB_override
When you run the override actions listed above, the updates are applied automatically to the Skylar Automation server as well as to the docker-compose.yml file. You do not need to redeploy the whole stack.
For more information, see Recommended Memory Allocation of Skylar Automation Nodes.
check_dex_connectivity
The check_dex_connectivity action is available in the skyautocontrol (formerly powerflowcontrol) utility version 2.7.10 and later.
This node action checks if the Dex server is reachable for each node of the cluster. You can use this check to verify that all the nodes in a cluster can reach the load balancer successfully.
skyautoctl cluster-action --action check_dex_connectivity
check_docker_service_update_status
The check_docker_service_update_status action is available in the skyautocontrol (formerly powerflowcontrol) utility version 2.7.4 and later.
The check_docker_service_update_status action iterates over all the running services in Skylar Automation and checks the status of the Docker service after running a docker service update command. You can run this action as a node-action or a cluster-action.
skyautoctl --config config.yml cluster-action --action check_docker_service_update_status
In addition, you can use the --update-parallelism option with the docker service update command to along with a value of 0, to update all Docker services at once.
Use the following format for the docker service update command:
docker service update --update-parallelism <uint> <configurations_to_update><service_name>
where <uint> is the number of replicas that you want to update in parallel. Use a value of 0 to update all Docker services at once. For example:
docker service update --update-parallelism 0 iservices_couchbase-worker --env-add AUTO_REBALANCE=true
check_redis_maxmemory, fix_redis_maxmemory
You can use the skyautoctl node actions check_redis_maxmemory and fix_redis_maxmemory to verify the MAXMEMORY variable in the docker-compose.yaml file. In release of Skylar Automation before 2.7.0, the Skylar Automation (PowerFlow) Redis service expected a value of MAXMEMORY to be passed using Docker environment variables, but the override templates in the pfctl utility supplied maxmemory instead.
The check_redis_maxmemory action determines if the Redis service requires an update to the environment variable, while the fix_redis_maxmemory action applies that change. The user will need to delete and recreate the Redis service after the fix action runs.
In addition, starting with Skylar Automation version 2.7.0, the Skylar Automation (PowerFlow) Redis image can accept either MAXMEMORY or maxmemory as an environment variable.
logcollect
Starting with Skylar Automation version 2.7.0, you can use the logcollect action to collect relevant files and logs of a Skylar Automation (PowerFlow) node and Skylar Automation (PowerFlow) stack docker services to troubleshoot issues.
To collect additional logs for troubleshooting, SSH to the Skylar Automation server and run the following commands.
For clustered environments, use the logcollect cluster-action. For example:
skyautoctl --host 10.2.11.222 isadmin:isadmin222 --host 10.2.11.232 isadmin:isadmin232 --host 10.2.11.244 isadmin:isadminpass cluster-action --action logcollect
To collect logs from each node individually, use node-action instead of cluster-action. Use node-action for 1-node deployments as well. For example:
skyautoctl --host 10.2.11.222 isadmin:isadmin222 --host 10.2.11.232 isadmin:isadmin232 --host 10.2.11.244 isadmin:isadminpass node-action --action logcollect
Be aware that Skylar Automation logs will be collected in every node, and the compressed file will be located in each of them when using node-action.
You can also use the following extra arguments:
- --since or -s . This argument lets you specific when Docker and journald logs will be collected. The default value is 24 hours. Only hours are accepted.
- --includelog or -l. This argument allows including extra logs. The acceptable values are varlog, which collects and compresses the /var/log directory, healthcheck, which collects the skyautocontrol healthcheck output, and serviceslogs which collects Docker service logs for the services running in the Skylar Automation stack. These are not included by default
- --help. View additional details.
You can set the following extra environment variables for further configurations:
- PFCTL_LOGCOLLECT_ROOT_DIR. The directory where the logs compressed file will be saved. The default value is /tmp. Valid existing directories should be set for this environment variable.
- PFCTL_LOGCOLLECT_TIMEOUT. The timeout for collecting docker services logs. Its default value is 40.
logservicescollect
If you want to collect only Docker services logs, you can use the following node-action. This action also takes the --since and --includelog serviceslogs arguments, and also uses the environment variables mentioned above:
skyautoctl --host 10.2.11.222 isadmin:isadmin222 --host 10.2.11.232 isadmin:isadmin232 node-action --action logservicescollect -l serviceslogs
open_firewall_ports
To open firewall ports for a single node, SSH to the Skylar Automation server and run the following command:
skyautoctl --host <pf_host_IP_address> isadmin:<host_password> node-action --action open_firewall_ports
Increasing the Skylar AutomationDocker Swarm Heartbeat in Cluster Environments
Starting with Skylar Automation version 3.1.0, you can use the update_swarm_heartbeat_period and check_swarm_heartbeat_period cluster actions to improve control over Skylar Automation Docker Swarm heartbeat configuration.
This cluster action increases the Skylar Automation Docker Swarm heartbeat to 20 seconds. For deployments in which network disruption or timeout is present, the default timeout of five seconds can be increased using the following action:
skyautoctl --cluster-action --action update_swarm_heartbeat_period
When creating a new cluster using autocluster, the Skylar Automation Docker Swarm heartbeat will be set to 20 seconds by default. The default will also be set to 20 seconds when running autoheal.
This cluster action allows you to check the current Skylar Automation Docker Swarm heartbeat configuration. This action is also called when calling the healthcheck action.
skyautoctl --cluster-action --action check_swarm_heartbeat_period
password
This section covers how to encypt and change passwords in Skylar Automation.
Encrypting a Skylar Automation Password
To encrypt a password using the skyautocontrol (skyautoctl) command-line utility, SSH to the Skylar Automation server and run the following command:
skyautoctl password encrypt
This command displays the decrypted password on standard output. It does not alter the contents of /etc/iservices/is_pass in place, but just decrypts to stdout.
This command is used locally when the decrypted password is needed for certain tasks that are, in turn, remotely started. On certain systems where the password is encrypted, this involves decrypting the password using the encryption_key file contents. For remote nodes, the nodes must also support the same version or later of the skyautocontrol (skyautoctl) command-line utility, as that command is executed locally.
Changing the isadmin User Password
You can also use the following command to update the Skylar Automation Administrator (isadmin) user password for a node environment:
skyautoctl --host IP isadmin:host_password password set -p 'new_password'
You can use the following command to update the Skylar Automation Administrator (isadmin) user password for a cluster environment:
skyautoctl --host 10.10.10.100 'isadmin:testing@is' --host 10.10.10.102 'isadmin:testing@is' --host 10.10.10.105 'isadmin:testing@is' password set
After the password is correctly updated, make sure the stack is removed and redeployed:
Remove the stack using the following command:
docker stack rm iservices
Wait until the services are down. Check with the following command:
watch docker ps
Redeploy the stack using the following command:
docker stack deploy --resolve-image=never -c /opt/iservices/scripts/docker-compose.yml iservices
Disabling TLS Verification
To ensure optimal functionality, all Skylar Automation systems must be configured to use HTTPS certificates. For more information, see Changing the HTTPS Certificate. When making requests to the Skylar Automation system, skyautocontrol (skyautoctl) checks will now verify the certificate associated with the system. As a result, validation of the default self-signed certificate configured for Skylar Automation systems upon initial deployment and intended for temporary use will fail.
Disabling TLS verification should only be implemented temporarily while configuring the Skylar Automation system to use valid HTTPS certificates.
To allow skyautocontrol (skyautoctl) to bypass TLS verification:
Use the disable-ssl-verification argument when executing pfctl node and cluster actions:
skyautoctl --disable-ssl-verification --host <host> <username>:<host_password> node-action --action healthcheck
If a skyautocontrol configuration .yml file is in use, include the disable-ssl-verification setting in the file. For example:
disable_ssl_verification: 'true' hosts: 10.2.11.102: user: isadmin password: password
Set the environment variable in the Skylar Automation host using SKYAUTOCTL_DISABLE_SSL_VERIFICATION=true :
SKYAUTOCTL_DISABLE_SSL_VERIFICATION=true skyautoctl init-sps
For versions of skyautocontrol 2.10.0 or earlier, if you see the check verify steprunner running fail with the message Connection refused. Unable to get response from the URL https://PF/api/v1/steps/run?wait=30 it is likely that the TLS Certificate check failed, and needs to be addressed by skipping temporarily and applying valid HTTPS Certificates. Starting with version 2.11.0 or later of skyautocontrol, the TLS errors have been updated for clarity.
