Webex SyncPack Release Notes, version 1.0.0
Version 1.0.0 of the "Webex" SyncPack is the initial release of the SyncPack. This release contains Skylar Automation applications, a configuration template, and steps that you can use to send changes to Skylar One events to the corresponding Webex channel.
This SyncPack uses the "Webex Automation" PowerPack.
Included Features
The following applications are included in this SyncPack:
  • Create Room For Event. Creates a Webex room from an event.
  • Created Room Event Notification. Sends a notification when a room has been created.
  • Major Event Notification. Notifies the user of a "Major" event.
  • Sync Event Status From Webex To SL1. Syncs the status of events between Webex and SL1.
The following configuration object is included in the SyncPack:
  • Sample Webex Config. This configuration object can be used as a template after the SyncPack is installed on the Skylar Automation system.
  • Create Webex Room
  • Create SL1 Payload
  • Delete Event From SL1
  • Fetch Room ID From Name
  • Fetch User Email
  • Fetch User Input
  • Invite Users To Room
  • Post Event Card To Webex
  • Post Update To SL1
To view the latest manuals and release notes for the Skylar Automation Platform, see the Skylar Automation  docs site.
System Requirements
Version 1.0.0 of the "Webex" SyncPack requires:
  • SL1 Skylar Automation platform version 2.5.0 or later.
  • Skylar One version 11.2.0 or later. For details on upgrading Skylar One, see the relevant SL1 Platform Release Notes.
  • "Webex Automation PowerPack" version 100 or later.
The following table lists the port access required by the Skylar Automation platform and this SyncPack:
Source IP Destination Source Port Destination Port Requirement
Skylar Automation Skylar One API Any TCP 443 Skylar One API Access
Skylar Automation Webex API Any TCP 443 Webex API Access
Installing the SyncPack
A SyncPack file has the .whl file extension type. You can download the SyncPack file from the ScienceLogic Support Center.
  1. Go to the ScienceLogic Support Center at https://support.sciencelogic.com/s/.
  2. Click the Skylar Automation tab and select SyncPacks.
  3. In the Search field, type the name of this SyncPack and select it from the search results. The Release Version page appears.
After you download a SyncPack, you can import it to the Skylar Automation (formerly PowerFlow) platform using the Skylar Automation user interface.
  1. On the SyncPacks page, click Import SyncPack. The Import SyncPack page appears.
  3. Click Import. Skylar Automation registers and uploads the SyncPack. The SyncPack is added to the SyncPacks page.
  1. On the SyncPacks page, click the Actions button () for the SyncPack you want to install and select Activate & Install. The Activate & Install SyncPack modal appears.
    If you do not see the SyncPack that you want to install, click the Filter icon () on the SyncPacks page and select Toggle Inactive SyncPacks to see a list of the imported SyncPacks.
  1. Click Yes to confirm the activation and installation. When the SyncPack is activated, the SyncPacks page displays a green check mark icon for that SyncPack. If the activation or installation failed, then a red exclamation mark icon appears.
  2. For more information about the activation and installation process, click the check mark icon or the exclamation mark icon in the Activated column for that SyncPack. For a successful installation, the "Activate & Install SyncPack" Skylar Automation application appears, and you can view the Step Log for the steps. For a failed installation, the Error Logs window appears.
  3. If you have other versions of the same SyncPack on your Skylar Automation system, you can click the Actions button () for that SyncPack and select Change active version to activate a different version other than the version that is currently running.
