You can use the Schedule Manager page to schedule downtime for an entire device group. This allows you to schedule maintenance and update tasks for all the devices in the device group and also inform other users of the scheduled downtime.
When the scheduled downtime occurs, each device in the device group will have a collection status of "maintenance".
You can specify whether or not you want Skylar One to collect data from the devices in the device group during the scheduled maintenance. During scheduled maintenance, no events will be triggered for the devices in the device group.
NOTE: If the definition for a device group in the Device Group Editor page does not include Device Schedules in the Visibility field, you will not be able to schedule downtime and maintenance for the device group.
Viewing the Schedule Manager
You can view, create, edit, or delete scheduled or recurring maintenance windows for specific device groups from the Schedule Manager page (Devices > Device Groups > calendar icon, or Registry > Devices > Device Groups > calendar icon in the classic user interface).
The Schedule Manager displays the following information about each scheduled or recurring device group maintenance window:
- Event ID. Displays a unique, numeric ID for the scheduled process. Skylar One automatically creates this ID for each scheduled process.
- sch id. Displays a unique, numeric ID for the schedule. Skylar One automatically creates this ID for each schedule.
- Context. Displays the area of Skylar One on which the schedule works.
- Duration. Displays the duration of the scheduled process, in minutes.
To edit a scheduled or recurring device group maintenance window, click its wrench icon (
) and update the settings as needed on the Schedule Editor modal page. (For more information, see the section Defining a Scheduled or Recurring Device Group Maintenance Window.)
You can schedule a device group maintenance window in Skylar One from the Schedule Manager page. Skylar One will automatically set the status of each device in the device group to "maintenance" at the scheduled time.
To define a scheduled or recurring device group maintenance window:
- Go to the Schedule Manager page (Devices > Device Groups > calendar icon, or Registry > Devices > Device Groups > calendar icon in the classic user interface).
- Click . The Schedule Editor modal appears.
- On the Schedule Editor modal, make entries in the following fields:
Basic Settings
- Schedule Name. Enter a name for the scheduled process.
- Preserve Schedule. Select this checkbox to keep the system from pruning this schedule after it expires.
- Description. Enter a description of the scheduled process.
Time Settings
If you want Skylar One to automatically adjust for daylight savings time (if applicable), then you must select a named region (such as America/New York) in the Time Zone field. If you select a specific time zone (such as EST) or a specific time offset (such as GMT-5), then Skylar One does not automatically adjust for daylight saving time. In addition, if you select a specific time zone, such as EST, that does not exist during daylight saving time, the system saves your schedules but runs them at unexpected times.
- Every Xth day of the Week. The scheduled process occurs at a monthly interval based on a day of the week. The day of the week displayed in this option matches the day selected in the Start Time field. For example, if you set the Start Time to Thursday, August 5th and that day is the first Thursday of the month, then the recurrence option will be Every 1st Thursday, and the scheduled process will occur monthly on the first Thursday of the month.
- If you specify "3 Months" the scheduled process recurs every three months, on the same day of the month as the Start Time.
Action Settings
- Scope. Select if the scheduled maintenance will affect only the group or both the group and children devices.
- Collection Polling. Specifies whether Skylar One should perform collection on the device during the scheduled maintenance. Choices are:
Enabled. During scheduled maintenance, Skylar One will collect data from the device, but no events will be triggered for the device.
Disabled. During scheduled maintenance, Skylar One will not collect data from the device. No events will be triggered for the device.
- Patch Window. You can specify a "patch window" within the larger maintenance period. The "patch window" allows Skylar One to limit the suppression of events to a small time-frame within the larger maintenance window. Your choices are:
- None
Suppose you have to patch a server that is monitored by Skylar One. Suppose you know you will perform this task sometime between midnight and 6:00 AM. Suppose you know that the actual patch process requires only 15 minutes of downtime for the server. In Skylar One, you would define a maintenance window of 24:00 - 6:00 and a patch window of 15 minutes. In this scenario:
- At 24:00, Skylar One generates an event saying that the server is going into maintenance mode. Because you have defined a patch window, Skylar One continues to monitor this server as normal.
- At 3:00, you apply the patch to the server. The server reboots, and Skylar One generates an event saying that the server is offline. The first event that both matches or exceeds the Patch Maintenance Minimum Severity in the Behavior Settings page (System > Settings > Behavior) and occurs within the larger maintenance window triggers the start of the patch window.
- Skylar One suppresses the event that triggered the patch maintenance window and instead generates an event "Patch Maintenance Window Opened".
- For the next 15 minutes, Skylar One will suppress all events for the device.
- At 3:15, Skylar One will generate an event for "Patch Maintenance Window Closed". This event clears the previous event "Patch Maintenance Window Opened".
- Skylar One will now generate events for the device, even though the maintenance window extends until 6:00.
NOTE: If the patch was applied at 5:50, the server was rebooted, and Skylar One generated an event saying that the server is offline, events would be suppressed only until the end of the maintenance window, 6:00, even though the patch window is 15 minutes.
Enabling or Disabling One or More Scheduled Device Group Maintenance Windows
You can enable or disable one or more scheduled or recurring device group maintenance windows from the Schedule Manager page (Devices > Device Groups > calendar icon, or Registry > Devices > Device Groups > calendar icon in the classic user interface).
If you remove a static device from a device group while the device is in maintenance mode, the device will stay in maintenance mode until you disable it. You must disable the maintenance schedule on the device itself in the Device Manager (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface by clicking on its calendar (
) icon. For more information, see
To enable or disable one or more scheduled or recurring device group maintenance windows:
- Go to the Schedule Manager page (Devices > Device Groups > calendar icon, or Registry > Devices > Device Groups > calendar icon in the classic user interface ).
- Select the checkbox for each scheduled process you want to enable or disable.
- Click the Select Action menu and select Enable Schedules or Disable Schedules.
Deleting One or More Scheduled Device Group Maintenance Windows
You can delete one or more scheduled or recurring device group maintenance windows from the Schedule Manager page (Devices > Device Groups > calendar icon, or Registry > Devices > Device Groups > calendar icon in the classic user interface). To do this:
- Select the checkbox for each scheduled process you want to delete.
- Click the Select Action menu and select Delete Schedules.
