Bulk Management with Device Groups and Device Templates
This section provides an overview of the device groups and device template features in Skylar One. For more information on how to use and manage device groups and device templates, see the Device Groups & Device Templates section.
What is a Device Group?
A device group is a group of multiple devices.
You can use device groups to:
  • Use device templates to perform initial configuration for multiple devices simultaneously
  • Use device templates to make changes to the configuration for multiple devices simultaneously
  • On the Device Groups page (Devices > Device Groups), view each device group and the subgroups and devices within each device group
  • Schedule maintenance and downtime for multiple devices simultaneously
  • Suppress events on multiple devices simultaneously
  • Include the device group in an automation policy. An automation policy can trigger an automatic action if specified criteria are met on all the devices in the device group.
A device can belong to multiple device groups. For example, suppose Skylar One discovered a server. Suppose this server hosts a corporate website that you want to monitor with a web-content policy. Suppose this server also hosts a MySQL database that you want to monitor with a Dynamic Application for MySQL. You could make this server a member of two device groups, one device group for web servers and another device group for MySQL databases. You could then use a device template to apply a web-content policy to all devices in the device group for web servers and another device template to apply a Dynamic Application for MySQL to all devices in the device group for MySQL servers.
  • You can create static device groups, where you explicitly assign one or more devices to a device group.
  • You can create dynamic device groups, where you define rules for the device group. Each device that meets the criteria in the rule is automatically included in the device group. For example, suppose that you define a rule that specifies "include all devices in the System organization, with an IP address that starts with '10.100.100' ". Skylar One would automatically assign all devices from the System organization with an IP of "10.100.100.*" to the new device group. When a new device is added to the System organization with an IP that begins with "10.100.100.*", the device group also includes that device. If a device with an IP that starts with "10.100.100.*" is removed from the System organization, the device group no longer includes that device.
  • You can create a device group that includes explicitly assigned devices and a dynamic rule. This device group includes both the explicitly assigned devices and all devices that meet the criteria in the dynamic rule.
The IT Services feature in Skylar One uses device groups to define an IT Service. An IT Service contains sets of rules that define the state of that IT Service based on the state of the devices within the device group. For example, if you created an IT Service that represents the state of your email service, the associated device group might contain your DNS servers, Exchange servers, and virtual devices that are associated with email round-trip monitoring policies. For more information on IT services, see the IT Services section.
What is a Device Template?
Device templates save a device configuration so that you can apply it to one or more devices and reuse the same configuration.
A device template contains the following tabs and settings:
  • Config tab. Contains all the fields on the Device Properties page (except device name and device IP) and all the fields on the Device Thresholds page. When you apply a device template to a device group or selected devices, you do not have to manually define any settings on the Device Properties page or the Device Thresholds page for the devices that use the template. All the devices that use the template inherit the field values from the device template.
  • Interface tab. Contains all the fields on the Interface Properties page that define how Skylar One monitors one or more network interfaces and the thresholds for those network interfaces. When you apply a device template to a device group or selected devices, you do not have to manually define any settings on the Interface Properties page for the devices that use the template. All the devices that use the template inherit the field values from the device template.
  • CV Policies tab. Specifies one or more web-content policies that can be applied to all devices that use the template. These web-content policies enable Skylar One to monitor a website. Skylar One periodically checks the website for specified content. If the content cannot be found on the website, Skylar One generates an event. When you apply a device template to a device, you do not have to manually define any web-content and availability policies on the Monitoring Policies page for the devices. All the devices that use the template inherit the web-content policies from the device template; Skylar One automatically creates these web-content policies for each device that uses the template.
  • Port Policies tab. Specifies one or more TCP/IP Port policies that can be applied to all member devices. These TCP/IP Port policies tell Skylar One to monitor a specified port for availability every five minutes. Availability refers to the port's ability to accept connections and data. When you apply a device template to a device group, you do not have to manually define any TCP/IP port policies on the Monitoring Policies page for the member devices. All the devices in the device group inherit the TCP/IP port policies from the device template; Skylar One automatically creates these port policies for each device that uses the template.
  • Svc Policies tab. Specifies one or more service policies that can be applied to devices that use the template. These service policies tell Skylar One to monitor the device and look for the specified service. You can define a service policy so that Skylar One monitors whether or not the service is running and then performs an action (starts, pauses, or restarts the service, reboots or shuts down the device, triggers the execution of a remote script or program). When you apply a device template to devices, you do not have to manually define any service policies on the Monitoring Policies page for those devices. All the devices that use the template inherit the service policies from the device template; Skylar One automatically creates these service policies for each device that uses the template.
  • Proc Policies tab. Specifies one or more Process policies that can be applied to devices that use the template. These Process policies tell Skylar One to monitor the device and look for the process. You can define a process policy so that Skylar One monitors whether or not the process is running and optionally, how much memory a process can use and how many instances of a process can run simultaneously. When you apply a device template to devices, you do not have to manually define any Process policies on the Monitoring Policies page for those devices. All the devices that use the device template inherit the process policies from the device template; Skylar One automatically creates these process policies for each device that uses the template.
  • Dynamic Apps tab. Specifies one or more Dynamic Applications that can be aligned with devices that use the template. Skylar One uses the specified Dynamic Applications to retrieve data from the devices that use the template. (Note that each device that uses the template might also be aligned with additional Dynamic Applications that have been aligned with the device in other ways: for example, from the automatic alignment that occurs during discovery.) When you apply a device template to devices, you do not have to manually align Dynamic Applications in the Dynamic Application Collections page for those devices. All devices that use the device template are aligned with the Dynamic Applications specified in the device template.
  • If you select a Dynamic Application in a Device Template, and that Dynamic Application has associated thresholds, you can change one or more of those thresholds from the Device Template. The thresholds you specify in the Device Template override the thresholds defined in the Dynamic Application. When you apply a device template to devices, you do not manually have to edit the Dynamic Application thresholds on the Device Thresholds page for those devices. All devices that use the device template inherit the Dynamic Application thresholds specified in the device template.
In a device template, you are not required to define all the fields in each tab. For example, you can choose to define only one or more fields in only one tab. When you apply the device template to devices, only the fields you define in the template change on the devices. For the remaining fields, the devices keep their previous values or use the default values.
  • One or more device groups
  • One or more devices, selected from the Device Manager page
  • all the devices discovered by a specific discovery session
Device templates are not dynamic. That is, when you update or change a device template, the change does not affect devices that used the template in the past.
You can make temporary changes to a device template, apply the template to devices, and then exit the device template without saving the temporary changes. In this way, you can apply settings to a device group but not permanently save the settings in the device template.
If you make changes to a device template or apply the device template a second time, Skylar One does not create duplicate policies on the member devices. However, if you edit a device template and change a policy, the system updates the policy on the member devices.
