For information about the data that Skylar One collects from monitored devices, how to configure monitoring policies to collect that data, and how Skylar One displays the data in the user interface, see
What is a Device?
Devices are all networked hardware in your network. Skylar One can monitor any device on your network, even if your organization uses a geographically diverse network. For each managed device, you can monitor status, create policies, define thresholds, and receive notifications, among other features.
Some of the devices that Skylar One can monitor include bridges, copiers, firewalls, load balancers, modems, printers, routers, security devices, servers, switches, telephony, workstations, and more.
In Skylar One, devices also include component devices and virtual devices.
What is a Device Record?
As part of monitoring your network, Skylar One collects data using common networking protocols. Most collected data is associated with a device in Skylar One. A device in Skylar One can represent:
- Physical network hardware, such as servers, switches, routers, or printers
- A component of a larger system, such as a data store in a hypervisor system or a blade server
- Any other entity about which you want to collect data, but want or need to associate that data with a container that does not correspond directly to a physical device or a component. For example, you might configure a device that represents a website or a cloud service.
What is a Device Class?
Device classes determine:
- How devices are represented in the user interface
- Whether the device is a physical device or a virtual device
- How managed devices are discovered with the discovery tool
Administrators can define new or legacy device classes and customize properties of existing device classes on the Device Classes page (Devices > Device Classes), or on the Device Class Editor page (System > Customize > Device Classes) in the classic Skylar One user interface.
Most TCP/IP-compliant devices have an internally defined class ID, called the System Object ID and abbreviated as SysObjectID. This SysObjectID is an SNMP object identifier (OID) defined by the manufacturer. Each manufacturer specifies a SysObjectID for each different hardware model. In Skylar One, each SNMP device class is associated with a SysObjectID. During initial discovery, Skylar One searches each device for the SysObjectID and assigns each device to the appropriate device class.
Skylar One also includes device classes for devices that do not support SNMP. These device classes are associated with values returned by nmap. Skylar One runs nmap against each device during discovery.
The following sections describe the types of device classes used in Skylar One.
What is a Device Category?
A device category is a logical categorization of a device by primary function, such as "server", "switch", or "router". Skylar One uses device categories to group related devices in reports and views.
Device categories work with device classes to organize and describe discovered devices. Device class usually describes the manufacturer. Device category describes the function of the hardware. Each device class can include a device category.
"Reserved" device categories are those device categories required by Skylar One. You cannot edit or delete these device categories. If a device category does not display the delete icon (
), the device category is a reserved device category and cannot be deleted.
How Does Skylar One Manage Devices?
- Using discovery, Skylar One automatically locates or discovers all hardware and hardware-components in your network. Skylar One can also automatically discover most software applications running in your network.
- Using Dynamic Applications, Skylar One can automatically discover component devices.
- During discovery, each device receives a device class and a device category for quick identification. You can customize device classes and device categories. You can also define custom device classes and device categories.
- On the Skylar One Devices and Device Manager pages, you can view details about each discovered device, including IP address and MAC address, operating system, hardware components (like CPU, RAM, swap, file systems), interfaces, open ports, and installed software.
- For each device, you can use the Device Investigator page or the Device Administration panel to define configuration and policies for the device.
- For each device, you can use the Device Investigator page or the Device Reports panel to view details about the device, including graphical reports.
- Skylar One can monitor bandwidth usage for each discovered network interface. Skylar One can generate reports and billing documents for each network interface.
Skylar One includes pre-defined events (sometimes called "alerts" in other applications). An event is a message that is triggered when a specified condition is met. Among other things, an event can signal that a server has gone down, that a device is exceeding CPU or disk-space thresholds, that communication with a device has failed, or simply display the status of a device or component. You can define and customize events to best fit your infrastructure. You can view events in Skylar One. You can also receive events by email, on pagers, or on cell phones.
- You can define customized performance thresholds and hardware thresholds for a device. Skylar One can generate events based on these thresholds.
- Skylar One monitors availability and latency for each device. You can define availability and latency thresholds. Skylar One also generates graphical reports on each device's availability and latency.
- Skylar One monitors open ports. Based on user-defined policies, Skylar One can generate an event when a new port is opened on any device in the network.
- Skylar One can monitor port-availability for each port in the network.
- Skylar One can discover and monitor the hardware components of each device.
- Skylar One can discover and monitor the software running on each device.
- Skylar One can monitor system processes and services running on a device. Based on user-defined policies, Skylar One can generate an event when a process or service is running or when a process or service is not running and should be.
- You can use device groups and device templates to automate the configuration and policies for multiple devices.
- You can create a virtual device to store data that you want to manage with Skylar One but that cannot be associated with a traditional device or that you do not want associated with a traditional device.
- You can create parent and child relationships between devices. You can use these relationships to resolve problems for the related devices with a single solution.
- You can create asset records for one, multiple, or all devices in the network. Skylar One automatically populates as many fields as possible, using information retrieved during discovery.
- Skylar One includes an exhaustive list of real-time, dynamic, graphical reports to display trends and status for individual devices, groups of devices, or the entire network. These reports can be saved in multiple formats and can be printed.
What is Discovery?
Discovery is the tool that automatically finds all the hardware-based devices, hardware components, and software applications in your network. You must provide the discovery tool with a range or list of IP addresses, a list of fully qualified domain names (hostnames), or both. The discovery tool determines if a device, hardware component, or software application exists at each IP address.
For each device, hardware component, or software application the discovery tool discovers, the discovery tool can collect a list of open ports, DNS information, SSL certificates, list of network interfaces, device classes to align with the device, topology information, and basic SNMP information about the device.
The discovery tool also determines which (if any) Dynamic Applications to align with the device. If the discovery tool finds Dynamic Applications to align with the device, the discovery tool triggers collection for each aligned Dynamic Application.
For more information on discovery, see
What is a Credential?
Credentials are access profiles that allow Skylar One to retrieve information from devices and from software applications on devices. Credentials typically include information such as a username and password, as well as any additional information required for accessing and monitoring devices. Dynamic Applications in Skylar One use credentials to retrieve SNMP information, database information, SOAP information, XML information, XSLT information, and WMI information.
Using Multiple Credentials
If necessary, a single device can use multiple credentials. If more than one agent or application is running on the device, each agent or application can be associated with its own credential. During discovery, Skylar One uses the appropriate credential for each agent.
For example, suppose you want Skylar One to discover a device that supports SNMP v2. To retrieve SNMP data from that device, Skylar One must use a valid SNMP v2 read-only community string. First, go to the device and define the SNMP read-only community string. Then return to Skylar One and create a credential in the Skylar One system, using that community string. This new credential would allow discovery to retrieve SNMP data from the device.
Now suppose this same device also includes a MySQL database. Suppose you want Skylar One to use a Dynamic Application to monitor that database. To retrieve data from the database, Skylar One must use a valid username and password for that database. First, go to the device that hosts the MySQL database and create a database username and database password for Skylar One to use. Then return to Skylar One and create a credential in the Skylar One system. The credential would include the database username and database password for the MySQL database. This credential would allow the Dynamic Application to retrieve data about the MySQL database.
For more information on credentials, see
What is a Virtual Device?
A virtual device is a container for collected data. You can use a virtual device to:
- Monitor a device or application that does not support TCP/IP, SNMP, or both. You can push the device's data to Skylar One by another method (for example, email) and store the data in a virtual device.
- Monitor multiple SNMP agents on a single device. In such a case, one of the SNMP agents (for example, a hardware agent) can be associated with the device and another SNMP agent (for example, an agent that monitors a software application) can be associated with a virtual device.
- Isolate and monitor specific parameters separately from their originating device. For example, you might want to monitor a database and keep its data separate from the hardware data you are collecting from the host device.
For more information on virtual devices, see Virtual Devices.
What are Component Devices?
Skylar One uses Dynamic Applications to retrieve data from a management device and discover each entity managed by that management device. Skylar One then uses that retrieved data to create a device for each managed entity. In some cases, the managed entities are nested.
- In Skylar One a managed entity is called a component device. A component device is an entity that runs under the control of a physical management device.
- In Skylar One, the root device is the physical device that manages one or more component devices.
- In Skylar One, a parent device is a device that has associated entities modeled as component devices. A parent device can be either a root device or another component device.
For example, in a Cisco Unified Computing System (UCS) system, Skylar One might discover a physical server that hosts the UCS manager. Skylar One might discover a chassis as a component device. The chassis is a child device to the physical server; the physical server is the root device. Skylar One might also discover a blade as a component device that is part of the chassis. The blade is a child device to the chassis. The chassis is the parent device.
The Device Components page (Devices > Device Components) displays all root devices and component devices in an indented view, so you can view the hierarchy and relationships between child devices, parent devices, and root devices.
Depending on your Key Privileges, you can use the Device Management tools and the Device Administration tools on this page. You can also view details about each device's interfaces, generate and print a report about a device, file a ticket about a device, view an asset record for a device, and perform bulk administrative tasks.
What is a Dynamic Application?
Dynamic Applications are the customizable policies that tell Skylar One what data to collect from devices and applications.
Skylar One includes Dynamic Applications for the most common hardware and software. You can customize these default Dynamic Applications to suit your environment. You can also create custom Dynamic Applications.
Dynamic Applications in Skylar One support a variety of protocols to ensure that Skylar One can always communicate with the devices and applications in your network and retrieve information from them. Dynamic Applications can use the following protocols to communicate with devices:
- SNMP
- SQL
- XML
- SOAP
- XSLT (uses SOAP and XSLT to convert XML data to a new format)
- WMI (Windows Management Instrumentation), including Web-Based Enterprise Management (WBEM)
- Windows PowerShell
- Custom Python applications (called "snippets") for proprietary or more complex data retrieval
What is a Skylar One Agent?
The Skylar One agent is a program that you can install on a device monitored by Skylar One. There is a Windows agent, an AIX agent, a Solaris agent, and a Linux agent. The agent collects data from the device and pushes that data back to Skylar One.
Similar to a Data Collector or Message Collector, an agent collects data about infrastructure and applications.
For more information on monitoring devices with the agent, see the
What is Virtualization?
Virtualization is when multiple virtual machines run on a single hardware platform. Each virtual machine is a software-based implementation of a computer that executes programs like a hardware-based computer. A virtual machine provides a platform on which you can run an operating system and software applications. For example, a single server could contain a virtual machine running Windows and Windows applications, another virtual machine running Linux and Linux applications, another virtual machine running BSD and BSD applications, and another running Macintosh OS and Macintosh applications.
A hypervisor is the software that allows one or more virtual machines to run on a single hardware platform. The hypervisor software allows the virtual machines to share the RAM, CPU, and disk space on the hardware platform.
Each virtual machine can run its own operating system. A virtual machine can provide an alternate instruction set from the hardware-based computer.
Virtual machines are frequently used to:
- Run multiple operating systems on a single computer
- Consolidate hardware servers and run multiple server applications on a single server
- Provide multiple, isolated development environments
What is an Asset Record?
An asset record is a collection of relevant information about an asset. In Skylar One, asset records are usually created for hardware devices.
In Skylar One, asset records can contain information about:
- The name, make, and model of a device
- The serial number of a device
- Function and status of the device
- Networking information, like host ID, IP address, and DNS server for the device
- Hardware information like amount of memory, CPU, and BIOS or EPROM version
- Physical location of the device
- Vendor information for the device, including PO or check number, warranty policy, and service policy
- Description of the network interface
- Description of each hardware component (if applicable)
- Description of installed software (if applicable)
Skylar One populates as many fields as possible automatically, using data retrieved during discovery and collections. You can enter values in all the fields or in only those fields that are required for your business processes.
You can specify which asset fields the system populates from data retrieved during discovery and collections and which fields you populate manually. To specify this behavior, go to the Asset Automation page (System > Settings > Assets).
