What is a Virtual Device?
A virtual device is a container for collected data. You can use a virtual device to:
- Monitor a device or application that does not support TCP/IP, SNMP, or both. You can push the device's data to Skylar One by another method (for example, email) and store the data in a virtual device.
- Monitor multiple SNMP agents on a single device. In such a case, one of the SNMP agents (for example, a hardware agent) can be associated with the device and another SNMP agent (for example, an agent that monitors a software application) can be associated with a virtual device.
- Isolate and monitor specific parameters separately from their originating device. For example, you might want to monitor a database and keep its data separate from the hardware data you are collecting from the host device.
Defining a Virtual Device
Before you create a virtual device, you must ensure that Skylar One includes a device class for virtual devices. These device classes must have a device category of "virtual" and a collection type of "virtual". If Skylar One does not include such a device class, you must define one on the Device Class Editor page (System > Customize > Device Classes).
Creating a Virtual Device from the Devices Page
To create a virtual device from the Devices page:
Go to the Devices page.
Click the down arrow icon (
) next to the button and then select Create Virtual Device. The Create a Virtual Device modal appears. -
In the Create a Virtual Device modal, complete the following required fields:
Device Name. Enter the name of the virtual device. This name can be any combination of alphanumeric characters, up to 32 characters in length.
Organization. Select the organization you want to associate with the virtual device.
Device Class. Select the device class you want to associate with the virtual device. Only device classes with a collection type of "virtual" appear in the list.
Collector Group. Select the collector group to which you want to assign the virtual device.
Click .
Creating a Virtual Device from the Device Manager Page
To create a virtual device from the Device Manager page:
- Click the menu and then select Create Virtual Device. The Create Virtual Device modal appears.
- Supply a value in each of the following fields:
- Device Name. Enter the name of the virtual device. The name can be any combination of alphanumeric characters, up to 32 characters in length.
- Organization. Select the organization to associate with the virtual device from the drop-down list of all organizations in Skylar One.
- Device Class. Select the device class to associate with the virtual device from the drop-down list of device classes. Only device classes with a device category of "virtual" and a collection type of "virtual" appear in the list.
- Collector. Specifies which instance of Skylar One performs nightly auto-discovery and gathers data from the device. You can also specify a "virtual" collector. Select from the drop-down list of all collectors in Skylar One.
Directing Data to a Virtual Device
After you define a virtual device, you must tell Skylar One which data to store in the virtual device.
- For data that is pushed to Skylar One, you can define the log data that you want to collect and redirect to the virtual device.
- For data that is collected via SNMP or TCP/IP, you can manually associate a Dynamic Application with the device to ensure that data collected by the Dynamic Application is stored in the virtual device.
Redirecting Log Data to a Virtual Device
Skylar One enables you to redirect log entries from one IP-based device to another IP-based device, or from an IP-based device to a virtual device.
Redirects are most useful for devices that do not support TCP/IP. With a redirect, Skylar One can push data from a device that does not support TCP/IP to another device that does, and then collect the data from the device that does support TCP/IP.
In this scenario, you can create a virtual device in Skylar One to represent the device that does not support TCP/IP. You can then move the data from the TCP/IP device that is monitored by Skylar One to the virtual device in Skylar One.
On the tab of the Device Investigator (or the Redirect Policy Editor page in the Device Administration panel), you can move data and log entries generated by inbound SNMP trap, syslog, or email messages from the TCP/IP device to the virtual device.
If you move data and log entries from a TCP/IP device to a virtual device, be aware of the following:
- Log entries that are redirected to a virtual device no longer appear in the log files for the IP-based device.
- Log entries that are redirected to a virtual device are no longer associated with the IP address of the original device.
- Log entries with a Source of Internal, Dynamic, or API that match a redirect policy are not moved from the IP-based device to the current device.
From the Devices page, click the name of the virtual or IP-based device to which you want to redirect data. The Device Investigator appears. Click the tab.
Alternatively, you can do this in the classic Skylar One user interface by going to the Redirect Policy Editor page in the Device Administration panel. To do so, go to the Device Manager page Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface), find the device to which you want to direct data, click its wrench icon (
), and then click the tab. -
To move SNMP trap, syslog, or email log messages from an IP-based device to the current device, provide values in each of the following fields:
Source Device. This is the TCP/IP device from which you want to redirect log messages. The data from this device moves to the current device. Select from a drop-down list of all IP-based devices discovered by Skylar One.
Expression Match. A regular expression used to locate the log entry to redirect. This can be any combination of alphanumeric and multi-byte characters, up to 64 characters in length. Skylar One uses case-sensitive expression matching. For details on the regular-expression syntax allowed by Skylar One, see http://www.python.org/doc/howto/.
Active State. Specifies whether or not Skylar One executes the redirection policy. The choices are:
Enable. Skylar One executes the redirection policy.
Disable. Skylar One does not execute the redirection policy.
- You can repeat steps 2 and 3 to redirect data from more than one device or from more than one type of log message.
Aligning a Dynamic Application with a Virtual Device
You can associate data that is collected by a Dynamic Application with a virtual device. Any data collected by the Dynamic Application is stored in the virtual device.
You cannot align SNMP Dynamic Applications with a virtual device. You can align all other types of Dynamic Applications with a virtual device.
You can align a Dynamic Application with a virtual device from the Device Investigator or from the Device Administration panel.
Aligning a Dynamic Application with a Virtual Device from the Device Investigator
To align a Dynamic Application with a device from the Device Investigator:
From the Devices page, click the name of the virtual device that you want to align with a Dynamic Application. The Device Investigator appears. Click the tab.
Click .
Click . The Align Dynamic Application modal appears.
Click . The Choose Dynamic Application modal appears.
Select the radio button of the Dynamic Application you want to align with the virtual device, and then click . The Align Dynamic Application modal appears with the selected Dynamic Application.
You can use the search field or filter fields to narrow down the list of Dynamic Applications.
In the Align Dynamic Application modal, an SNMP credential is automatically selected. To align the Dynamic Application using that SNMP credential, proceed to step 8. Otherwise, clear the credential checkbox and then click . The Choose Credential modal appears.
Select the radio button of the credential you want to align with the Dynamic Application, and then click . The Align Dynamic Application modal appears with the selected credential.
You can use the search field or filter fields to narrow down the list of credentials.
Click . The tab appears with the selected Dynamic Application aligned to the virtual device.
To run the Dynamic Application immediately, click . Otherwise, proceed to step 10 and the Dynamic Application runs automatically based on its Poll Frequency.
Click .
Aligning a Dynamic Application with a Virtual Device from the Device Administration Panel
To align a Dynamic Application with a device from the Device Administration panel:
- Find the device you want to associate with a Dynamic Application and then click its wrench icon (
). The Device Administration panel appears. - In the Device Administration panel, click the tab.
- On the Dynamic Application Collections page, click the menu and select Add Dynamic Application.
- The Dynamic Application Alignment modal page appears.
- To associate an additional Dynamic Application with the device, select it in the Dynamic Applications field. You can filter the list of Dynamic Applications using the search field above the Dynamic Applications field.
- After you select a Dynamic Application, you must select a credential. Select a credential in the Credentials field. You can filter the list of credentials using the search field above the Credentials field.
Your organization membership might affect the list of credentials you can see in the Credentials field.
- Click the button in the Dynamic Application Alignment modal to align the Dynamic Application and the credential to the device.
- Skylar One associates the Dynamic Application with the device and immediately attempts to collect the data specified in the Dynamic Application using the selected credential.
- After the first, immediate collection, Skylar One collects the data at the frequency defined in the Polling Frequency field on the Application Configuration Editor page for the Dynamic Application.
