Creating a Physical Device without Running Discovery
Skylar One allows you to manually create physical devices without running discovery. When you do so, a device record exists in Skylar One before Skylar One can communicate with the device.
In some cases, service providers find it useful to prepopulate a Skylar One system with device records but set the status of the manually created devices to Disabled. When network and firewall work are completed, the provider can then enable the devices and use discovery to keep the device data up-to-date.
You can manually create a physical device in three ways:
  • In the user interface
  • By uploading device data via a CSV file
  • With the ScienceLogic API
Prerequisites
Before you manually create a device in Skylar One, you must have the following information:
  • Unique IP address for each device that you want to create. The IP address must be unique in Skylar One so it can be used to communicate with the device.
  • Organization ID. If you use the API to manually create a physical device or if you manually create multiple devices in bulk using a comma-separated values (CSV) file, you must supply the organization ID for an existing organization.
Using the User Interface to Create a Physical Device
Creating a Physical Device from the Devices Page
To manually create a physical device from the Devices page:
  1. Go to the Devices page.
  2. Click the down arrow icon () next to the Add Devices button and then select Create Physical Device. The Create a Physical Device modal appears.
  3. In the Create a Physical Device modal, complete the following required fields:
    • IP Address. Enter an IP address that is unique in the device's collector group and can be used to communicate with the device.
      Skylar One does not allow you to add a new device with a public IP address that is not unique system-wide or a private IP address that is not unique to the selected collector group.
    • Device Name. Enter a device name for the device.
    • SNMP Read Credential. Select from a list of SNMP credentials.
    • Organization. Select from a list of organizations.
    • Device Class. Select from a list of device classes.
    • Collector Group. Select from a list of collector groups.
  4. Click Create.
Creating a Physical Device from the Device Manager Page
To manually create a physical device from the Device Manager page:
  2. Click the Actions menu and select Create Physical Device. The Create Physical Device modal appears.
  3. In the Create Physical Device modal, complete the following fields:
  • IP Address. Required. Enter an IP address that is unique in the device's collector group and can be used to communicate with the device.
  • Device Name. Optional. Enter a device name for the device.
  • SNMP Credential. Optional. Select from a list of SNMP credentials. If you do not select a credential, the system assigns the default value of NO CREDENTIAL to the new device.
  • Organization. Optional. Select from a list of organizations. If you do not select an organization, the system assigns the default organization, System, to the new device.
  • Device Class. Optional. Select from a list of device classes. If you do not select a device class, the system assigns the default device class, Ping | ICMP, to the new device.
  • CUG. Optional. Select from a list of collector groups. If you do not select a collector group, the system assigns the collector group with the lowest ID to the new device.
  1. Click Add to add the new physical device.
Managing Physical Devices Created in the User Interface
After an administrator manually creates a physical device, the device appears on the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface).
The new device can be managed like any physical device in Skylar One. However, the following caveats apply:
  • No Dynamic Applications are automatically aligned with the device.
  • No interfaces are discovered and no interface data is included with the device.
If you want to disable Auto-Update and disable Collection for the new device, see the details in the section on Editing Device Settings.
If you want to discover the device using the Discovery tool, see the section on Manually Re-Running Discovery for a Device.
Using a CSV File to Create Multiple Physical Devices
Skylar One allows users to manually create multiple physical devices simultaneously by uploading device data in a CSV file.
The fields supported differ based on whether you are uploading the CSV file from the Devices page or from the Device Manager page.
The following fields are supported if you are uploading the file from the Devices page:
  • ip. Required. An IP address that is unique in the device's collector group and can be used to communicate with the device.
  • organization. Required. The ID of an existing organization.
  • name. Optional. A name for the device.
  • deviceClassId. Required. The Globally Unique Identifier (GUID) of the device class.
  • snmpCredId. Optional. An SNMP credential associated with the device. If no SNMP credential is included, no credential is associated with the device.
  • collectorGroupId. Optional. The collector group (CUG) assigned to the new device. If you do not include a collector group, Skylar One assigns the collector group from the top of the list of all collector groups, sorted numerically by ID.
From the Device Manager page, the same fields are instead labeled like this:
  • ip
  • organization
  • name
  • class_type
  • snmp_cred_id
  • collector_group
The explanations and examples in the rest of this section use the Devices page format. If you are uploading the CSV file from the Device Manager page, use the field labels listed here instead.
Skylar One generates an error if the CSV file excludes a required field or includes unsupported fields (for example, hostname).
The CSV file must contain a comma-separated header line that indicates the fields used, followed by comma-separated lines for each device. The CSV file must include the ip, organization, and deviceClassId fields at a minimum. The CSV file can also include additional fields. You must enter the field names with no spaces between them. Because the field names must match the corresponding parameters in the API, you must enter the field names exactly as follows:
  • ip
  • organization
  • name
  • deviceClassId (or class_type, if uploading from the Device Manager page)
  • snmpCredId (or snmp_cred_id, if uploading from the Device Manager page)
  • collectorGroupId (or collector_group, if uploading from the Device Manager page)
For example, to create two devices using only the required fields of IP address, organization, and device class ID, the CSV file must contain the following:
ip,organization,deviceClassId
10.2.9.42,1,9681
10.2.10.42,1,9681
To create "Device A" and "Device B" using all supported fields, the CSV file must contain the following:
ip,organization,name,deviceClassId,snmpCredId,collectorGroupId
10.2.9.42,1,Device A,9681,37,1
10.2.10.42,1,Device B,9681,37,1
Do not include spaces between the comma-separated values in the CSV file.
Creating Multiple Physical Devices Using a CSV File from the Devices Page
To manually create multiple physical devices using a CSV file from the Devices page:
  2. Click the down arrow icon () next to the Add Devices button and then select Create Physical Device From File. The Create a Physical Device From File modal appears.
  3. In the Create a Physical Device From File modal, click Browse Files, then select the CSV file.
  4. Click Create to import the CSV file and create the physical devices. If an error occurs, the error message appears in the Create a Physical Device From File modal. Otherwise, if the import is successful, the Devices page appears with the new devices added.
Creating Multiple Physical Devices Using a CSV File from the Device Manager Page
To manually create multiple physical devices using a CSV file from the Device Manager page:
  1. Click the Actions menu and select Create Physical Devices From File. The Bulk Physical Device modal appears.
  2. In the Bulk Physical Device modal, click Browse, then select the CSV file.
  3. Click Import to import the CSV file and create the physical devices. The Bulk Physical Device modal displays log messages as each new physical device is created or if any errors occurred while adding a device.
  4. If a device fails to import, click the wrench icon (wrench icon) for that device to edit its settings manually. For more information on how to create a single device, see Using the User Interface to Create a Physical Device.
Managing Physical Devices Created Using a CSV File
You can use the Skylar One user interface to manage the newly created devices. For more information, see Managing Physical Devices Created in the User Interface.
Using the API to Create a Physical Device
Creating a Physical Device with the API
You can use a POST request to the /device API resource to manually create a physical device in Skylar One.
The following fields are supported:
  • ip. Required. Supply an IP address that is unique in Skylar One and can be used to communicate with the device.
  • organization. Required. Supply the relative API URI for an existing organization. For example, /api/organization/0.
  • name. Optional. Supply a name for the device.
  • snmp_cred_id. Optional. Specify the relative API URI of an existing SNMP credential. If no credential is selected, no credential is assigned to the new device.
  • class_type. Optional. Specify the relative API URI of an existing device class. If no device class is selected, the default device class, Ping | ICMP, is assigned to the new device.
  • collector_group. Optional. Specify the relative API URI of an existing collector group. If no collector group is selected, the collector group with the lowest ID is assigned to the new device.
Example
The following example creates a physical device using the API:
curl -v -H 'X-em7-beautify-response:1' -H 'accept:application/json' -H 'content-type:application/json' -u 'em7admin:<password>' "http://192.168.10.205/api/device" -d '{"name": "example-device", "organization": "\/api\/organization\/0", "class_type": "\/api\/device_class\/1547", "ip": "10.20.7.31", "snmp_cred_id": "\/api\/credential\/snmp\/69","collector_group": "\/api\/collector_group\/1"}'
  • curl -v. Executes the cURL request. The -v option tells cURL to use verbose mode (displays all header information and all status and error messages). In the response, lines that start with ">" include header data returned by cURL. Lines that start with "<" include header data received by cURL.
  • -H 'X-em7-beautify-response:1'. The -H option tells cURL to include an additional header in the request. In this case, the option includes a ScienceLogic custom header that tells the API to include whitespace in the response.
  • -H 'accept:application/json'. The -H option tells cURL to include an additional header in the request. In this case, the option tells the API to return responses in JSON format.
  • -H 'content-type:application/json'. The -H option tells cURL to include an additional header in the request. In this case, the option tells the API that the incoming data is in JSON format.
  • -u 'em7admin:<password>'. The -u option tells cURL to authenticate as a specified user. In our example, the user is "em7admin". Replace <password> with the appropriate password for that user.
  • "https://192.168.10.205/api/device". Connect to the specified URL. In our example, the command connects to the API at 192.168.10.205 and accesses the resource for devices.
  • -d. Tells the API the following text is the data to submit as a POST request.
  • The device is created using the following fields.
Field Name Value
name example-device
organization /api/organization/0
class_type /api/device_class/1547
ip 10.20.7.31
snmp_cred_id /api/credential/snmp/69
collector_group /api/collector_group/1
The API returns an HTTP 201 response. The response body includes the newly created device in JSON format.
The X-EM7-status-message header includes the device ID of the newly created device.
< HTTP/1.1 201 Created:
< Server: nginx/1.10.0
< Date: Thu, 28 Jul 2016 16:50:12 GMT
< Content-Type: application/json
< Transfer-Encoding: chunked
< Connection: keep-alive
< X-EM7-Implemented-methods: GET,POST,PUT,DELETE
< X-Powered-By: ScienceLogic, Inc. - EM7 API/Integration Server
< X-EM7-Authenticated-account: /api/account/1
< Location: /api/device/33
< Cache-Control: private, no-cache, must-revalidate, no-store, max-age=0, post-check=0, pre-check=0
< X-EM7-status-message: Device :33 added successfully
< X-EM7-status-code: CREATED
< Vary: Accept-Encoding
"ip": "10.20.7.31",
"hostname": null,
"snmp_w_cred_id": null,
"collector_group": "\/api\/collector_group\/1",
The rest of the response includes a list of all device fields, each set to its default value.
Managing Physical Devices Created with the API
You can use the ScienceLogic user interface to manage the newly created device. For more information, see Managing Physical Devices Created in the User Interface.
You can also use the ScienceLogic API to manage the newly created device. For more information, ask your ScienceLogic contact for access to the ScienceLogic API documentation.
Available Actions for the Device Resource
Action URI Method
View/search/filter the list of devices. /device GET
Create a new physical device. Unlike for a virtual device, you must specify a valid IP address and the organization ID for an existing organization.
/device
POST
Create a new virtual device. /device POST
View the properties of a device. /device/X GET
Update the properties of a device. /device/X POST
Replace the properties of a device. /device/X PUT
Delete a device. /device/X DELETE
View/search/filter the list of Dynamic Applications aligned with a device. /device/X/aligned_app GET
Align a Dynamic Application with a device. /device/X/aligned_app POST
View the collection status and associated credential for a Dynamic Application aligned with a device. /device/X/aligned_app/X GET
Update the collection status and associated credential for a Dynamic Application aligned with a device. /device/X/aligned_app/X POST
Unalign a Dynamic Application from a device. /device/X/aligned_app/X DELETE
View/search/filter the list of available configuration data for a device. /device/X/config_data GET
View metadata about data collected from a device by a configuration Dynamic Application. /device/X/config_data/X GET
View data collected from a device by a configuration Dynamic Application. /device/X/config_data/X/data GET
View historical snapshots of data collected from a device by a configuration Dynamic Application. /device/X/config_data/X/snapshots GET
View general information collected from a device. /device/X/detail GET
View/search/filter the list of credentials aligned with a device. /device/X/device_app_credentials GET
View the threshold settings for a device. /device/X/device_thresholds GET
Update the threshold settings for a device. /device/X/device_thresholds POST
Replace the threshold settings for a device. /device/X/device_thresholds PUT
Revert all device thresholds to the global default values. /device/X/device_thresholds DELETE
Add an interface record to a device. /device/X/interface POST
View/search/filter the list of interfaces for a device. /device/X/interface GET
View the properties of an interface for a device. /device/X/interface/X GET
Update the properties of an interface for a device. /device/X/interface/X POST
Replace an interface record associated with a device. /device/X/interface/X PUT
Delete an interface record associated with a device. /device/X/interface/X DELETE
View data for an interface. /device/X/interface/X/interface_data/data GET
View daily normalized data for an interface. /device/X/interface/X/interface_data/normalized_daily GET
View hourly normalized data for an interface. /device/X/interface/X/interface_data/normalized_hourly GET
View/search/filter the list of logs associated with a device. /device/X/log/ GET
View a log associated with a device. /device/X/log/X GET
Add a note to a device. /device/X/note/ POST
View/search/filter the list of notes associated with a device. /device/X/note/ GET
View a note associated with a device. /device/X/note/X GET
Update a note associated with a device. /device/X/note/X POST
Replace a note associated with a device. /device/X/note/X PUT
View/search/filter the list of files associated with a device note. /device/X/note/X/media GET
Get a media file associated with a device note. /device/X/note/X/media/X GET
Add a media file to a device note. /device/X/note/X/media/X PUT
View metadata about a media file associated with a device note. /device/X/note/X/media/X/info GET
View/search/filter the list of available Dynamic Application data for a device. /device/X/performance_data GET
View data for a Dynamic Application aligned to a device. /device/X/performance_data/X/data GET
View daily normalized data for a Dynamic Application aligned to a device. /device/X/performance_data/X/normalized_daily GET
View hourly normalized data for a Dynamic Application aligned to a device. /device/X/performance_data/X/normalized_hourly GET
View/search/filter the list of available vitals data for a device. /device/X/vitals GET
View availability data for a device. /device/X/vitals/availability/data GET
View daily normalized availability data for a device. /device/X/vitals/availability/normalized_daily GET
View hourly normalized availability data for a device. /device/X/vitals/availability/normalized_hourly GET
View data for a file system on a device. /device/X/vitals/fsX/data GET
View daily normalized data for a file system on a device. /device/X/vitals/fsX/normalized_daily GET
View latency data for a device. /device/X/vitals/latency/data GET
View daily normalized latency data for a device. /device/X/vitals/latency/normalized_daily GET
View hourly normalized latency data for a device. /device/X/vitals/latency/normalized_hourly GET
Apply a device template to a device. Post a /device_template resource. /device/X POST
