Configuring LayerX and Skylar One Dashboards
This section describes how to configure LayerX and Skylar One to use the classic dashboards included in the "LayerX Integration" PowerPack.
Configuring VOSS Insights to Add Skylar One Filters to Dashboards
Before you can use the classic dashboards included in the "LayerX Integration" PowerPack or add Custom Links to the VOSS Insights dashboards, you must configure VOSS Insights to add Skylar One filters to dashboards by creating field groupings.
Creating Field Groupings in VOSS Insights to Add Skylar One Filters to Dashboards
To configure VOSS Insights to add Skylar One filters to dashboards:
  1. Log in to VOSS Insights Analytix with an administrator account.
  1. Select your username on the top-right of your VOSS Insights page and a drop-down menu appears. Select Edit Field Groupings.
  1. The Field Grouping page appears. Select the plus icon on the upper-left of the page to add a new field grouping.
  • Field Grouping Name. Enter "lxtfg_url_agentid".
  • Resource. Select "Lxt_hpstack_summary_flow" from the drop-down.
  1. Drag and drop the "agentid" field from the Fields list to the Drop Zone.
  2. Repeat steps 4 and 5 but replace the values with the following Resources and Fields:
Resource Field
lxt_hpstack_summary_topdestport agentid
lxt_hpstack_summary_topsrcipaddr agentid
lxt_hpstack_summary_srcdestcountry agentid
lxt_hpstack_summary_topsrcdestipaddr agentid
lxt_hpstack_netflow AGENTID
  1. Repeat the steps in this section but replace the Field Grouping Name, Resource, and Field fields with the following values:
Field Grouping Name Resource Field
lxtfg_url_egressint Lxt_hpstack_summary_flow egressint
lxtfg_rul_ingressint Lxt_hpstack_summary_flow ingressint
Testing the Integration and Gathering Data to Configure Skylar One Dashboards and Custom Links
The dashboards included in the "LayerX Integration" PowerPack and recommended Custom Links use the field groupings in the following VOSS Insights dashboards:
  • LayerX Netflow - Top Applications
  • LayerX Netflow - Top Talkers
To test the integration of Skylar One with VOSS Insights and gather the information you need to configure the Skylar One dashboards and custom links:
  1. Navigate to the "Top Applications" dashboard in VOSS Insights and copy the URL from the URL bar. You will need this URL when you configure Skylar One.
For example, your URL may look like this: https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=LSVKY369DH4E9ETH1569262346658JWY4JXP582Y0TE
  1. Note the IP address of a device that appears in the "Top Applications" dashboard.
  2. In the URL bar, enter "&agent_id=" and the IP address you noted to the end of the URL.
For example, if you use the above URL and the IP address is 203.0.113.243, the new URL is: https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=LSVKY369DH4E9ETH1569262346658JWY4JXP582Y0TE&agentid=203.0.113.243
  1. Enter the new URL in the URL bar and refresh the page. If your configuration is successful, "agentid" will appear in multiple filters in the "Drilldown Filters" section of the dashboard.
  1. Repeat the steps in this section using the "LayerX Netflow - Top Talkers" dashboard.
Configuring the Skylar One Classic Dashboards
The "LayerX Integration" PowerPack includes device dashboards that use Skylar One standard widgets that allow you to select a device or interface and provide summary information. Once successfully integrated, the main frame of the dashboard will display one of the two integrated VOSS Insights dashboards. The VOSS Insights dashboard that is displayed in the main frame is automatically filtered based on the device IP or interface you select.
To configure the Skylar One dashboards:
  1. In your Skylar One system, click the Dashboards tab.
  2. Select the Skylar One dashboard you want to use. You may choose from the following dashboards that are included in the PowerPack:
  • LayerX Top Applications by Device
  • LayerX Top Applications by Inbound Interface
  • LayerX Top Applications by Outbound Interface
  • LayerX Top Talkers by Device
  • LayerX Top Talkers by Inbound Interface
  • LayerX Top Talkers by Outbound Interface
  1. Select a device in the Filter by Device pane or an interface in the Top 10 pane.
  2. In the main pane that displays a VOSS Insights dashboard, hover over the arrow icon on the top right of the pane and the Options menu appears. Click the Options menu.
  3. Select Configure. The Widget Configuration modal page appears.
  1. Edit the following field:
  • Context Iframe URL. Replace the URL up to the first ampersand with the URL of the corresponding VOSS Insights dashboard. For example, use the following scenario:
  • The "LayerX Top Applications by Device" Skylar One dashboard uses the "LayerX Netflow - Top Applications" LayerX dashboard to populate the main pane.
  • The default value for the Context Iframe URL field is "https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=LSVKY369DH4E9ETH1569262346658JWY4JXP582Y0TE&agentid={context.deviceObjects.last.ip}".
  • If the URL from your "LayerX Netflow - Top Applications" dashboard is "https://layerx.example.com/dashboard/index.php#dashboard_id=ABC123XYZ", your new Context Iframe URL field should be "https://layerx.example.com/dashboard/index.php#dashboard_id=ABC123XYZ&agentid={context.deviceObjects.last.ip}"
  2. Repeat the steps in this section for all dashboards included in the "LayerX Integration" PowerPack. See the table below for each Skylar One dashboard included in the PowerPack and the aligned VOSS Insights dashboard.
Sl1 Dashboard LayerX Dashboard
LayerX Top Applications by Device LayerX Netflow - Top Applications
LayerX Top Applications by Inbound Interface LayerX Netflow - Top Applications
LayerX Top Applications by Outbound Interface LayerX Netflow - Top Applications
LayerX Top Talkers by Device LayerX Netflow - Top Talkers
LayerX Top Talkers by Inbound Interface LayerX Netflow - Top Talkers
LayerX Top Talkers by Outbound Interface LayerX Netflow - Top Talkers
The Skylar One dashboards above have the following default URLs that are used when editing the Widget Configuration modal page:
  • LayerX Top Applications by Device:
  • https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=LSVKY369DH4E9ETH1569262346658JWY4JXP582Y0TE&agentid={context.deviceObjects.last.ip}
  • LayerX Top Applications by Inbound Interface:
  • https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=LSVKY369DH4E9ETH1569262346658JWY4JXP582Y0TE&ingressint={context.interfaceObjects.last.device.ip} interface {context.interfaceObjects.last.ifIndex}
  • LayerX Top Applications by Outbound Interface:
  • https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=LSVKY369DH4E9ETH1569262346658JWY4JXP582Y0TE&egressint={context.interfaceObjects.last.device.ip} interface {context.interfaceObjects.last.ifIndex}
  • LayerX Top Talkers by Device:
  • https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=SDCVRDBF06KAQGI81567616683197W5IBJBML2G0B5O&agentid={context.deviceObjects.last.ip}
  • LayerX Top Talkers by Inbound Interface:
  • https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=SDCVRDBF06KAQGI81567616683197W5IBJBML2G0B5O&ingressint={context.interfaceObjects.last.device.ip} interface {context.interfaceObjects.last.ifIndex}
  • LayerX Top Talkers by Outbound Interface:
  • https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=SDCVRDBF06KAQGI81567616683197W5IBJBML2G0B5O&egressint={context.interfaceObjects.last.device.ip} interface {context.interfaceObjects.last.ifIndex}
Configuring Custom Links for LayerX
If you are using Skylar One platform version 10.2.0 or later, you can configure Custom Links from the Skylar One Toolbox to VOSS Insights dashboards. ScienceLogic recommends adding links to the "LayerX Netflow - Top Talkers" and "LayerX Netflow - Top Applications" VOSS Insights dashboards.
NOTE: For more information about custom links, see the section on Custom Links.
Defining the LayerX Dashboard Links
There are two mutations you must run in the GraphiQL interface to link both VOSS Insights dashboards to Skylar One.
Adding the LayerX Netflow - Top Application Dashboard Custom Link
To add the "LayerX Netflow - Top Application" dashboard link to Skylar One:
  1. Type the URL or IP address for Skylar One in a browser, add /gql to the end of the URL or IP address, and press Enter. The GraphiQL interface appears.
  1. In the main query pane, type the following mutation but replace the first part of the URL, up to the ampersand, with the URL of your "LayerX Netflow - Top Applications" dashboard. For example:
mutation createLXTopAppCustomLink {
	createCustomLink(entity: device, url: "https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=LSVKY369DH4E9ETH1569262346658JWY4JXP582Y0TE&agentid={ip}", name: "LayerX Top Applications") { id entity url name editedBy { user } dateEdited }
  1. Click the Execute Query (Play) button. The mutation executes, and the results appear in your Skylar One dashboards.
Adding the LayerX Netflow - Top Talkers Dashboard Custom Link
To add the "LayerX Netflow - Top Talkers" dashboard link to Skylar One:
  1. To access the GraphiQL interface, type the URL or IP address for Skylar One in a browser, add /gql to the end of the URL or IP address, and press Enter. The GraphiQL interface appears.
  1. In the main query pane, type the following mutation but replace the first part of the URL, up to the ampersand, with the URL of your "LayerX Netflow -Top Talkers" dashboard:
mutation createLXTopTalkersCustomLink {
	createCustomLink(entity: device, url: "https://layerx.sciencelogic.local/dashboard/index.php#dashboard_id=SDCVRDBF06KAQGI81567616683197W5IBJBML2G0B5O&agentid={ip}", name: "LayerX Top Talkers") { id entity url name editedBy { user } dateEdited }
Dashboards
The "LayerX IntegrationPowerPack includes dashboards that provide summary information for VOSS Insights devices. Once you have configured Skylar One and VOSS Insights, the following device dashboards in the "LayerX IntegrationPowerPack display information about your VOSS Insights devices.
The LayerX Top Applications by Device dashboard displays the following information:
  • A widget to select a device
  • The integrated LayerX Netflow - Top Applications dashboard
The LayerX Top Applications by Inbound Interface dashboard displays the following information:
  • Top ten interfaces, sorted by utilization in
The LayerX Top Applications by Outbound Interface dashboard displays the following information:
  • Top ten devices, sorted by utilization out
The LayerX Top Talkers by Device dashboard displays the following information:
  • The integrated LayerX Netflow - Top Talkers dashboard
The LayerX Top Talkers by Inbound Interface dashboard displays the following information:
  • Top ten devices, sorted by utilization in
The LayerX Top Talkers by Outbound Interface dashboard displays the following information:
