Configuring Device Credentials
This section describes how to configure the credentials required by the automation actions in the Dell EMC Unity Automations PowerPack.
If you already have the Dell EMC: Unity PowerPack installed and monitoring your Dell EMC devices, you do not need to configure an additional credential.
Editing the Credential
If you do not have the Dell EMC: Unity PowerPack installed and configured, follow the steps for installation in the Installing the Dell EMC: Unity PowerPack section.
Once you have the Dell EMC: Unity PowerPack installed, you must edit the SOAP/XML credential that allows the Dynamic Applications in the Dell EMC Unity Automations PowerPack to use the Unisphere REST API.
To configure the SOAP/XML credential to access the Unisphere REST API:
  1. Locate the credential you created following the steps in the Creating a SOAP/XML Credential for Dell EMC Unity section, and then click its wrench icon (). The Edit SOAP/XML Credential page appears:
  1. Change the value in the Method field to GET.
For more information about configuring credentials in SL1, see  Credentials.
