Monitoring Device Logs Using an Agent
This section describes how to use the Skylar One (formerly SL1) agent to monitor logs with Log File Monitoring policies. Skylar One supports multiple methods for ingesting log data, which you can use to generate events.
  • The logs from the file or Windows log that an agent will send to Skylar One
The Log File Monitoring Policies page (System > Manage > Log File Monitoring Policies) displays a list of all Log File Monitoring policies. You can create, edit, and delete Log File Monitoring policies from the Log File Monitoring Policies page (System > Manage > Log File Monitoring Policies).
After creating a Log File Monitoring policy, you must align the policy to one or more devices either from the Log File Monitoring page or by using a Device Template.
You can view logs collected by the Skylar One Agent on the Logs panel on the Device Investigator page for the device on which the agent is installed. The same logs also appear on the Logs tab in the Device Properties and Device Summary pages for that device. You can define event policies that specify how logs collected by an agent will trigger events.
The Log File Monitoring Policies page (System > Manage > Log File Monitoring Policies) displays a list of all Log File Monitoring policies. From this page, you can also create, edit, and delete Log File Monitoring policies.
  • Policy ID. Unique numeric ID, automatically assigned by Skylar One to each Log File Monitoring policy.
  • Filter. The regular expression that the agent uses to determine whether a log message is sent to Skylar One.
  • Edited By. Skylar One user who created or last edited the Log File Monitoring policy.
Filtering the List of Log File Monitoring Policies
To filter the list of credentials in the Log File Monitoring Policies page, use the search fields at the top of each column. The search fields are find-as-you-type filters; as you type, the page is filtered to match the text in the search field, including partial matches. Text matches are not case-sensitive. Additionally, you can use the following special characters in each filter:
  2. Click Create. The Log Monitoring Policy modal appears.
      • application
      • system
      • security
      • other
    • Limit. The maximum log messages the agent sends to Skylar One per minute. If the number of matching logs exceeds this value, the agent will stop sending logs to the platform for the remainder of the minute. The limit resets at the beginning of the next minute.
    • Filter. Specify a regular expression that will be used to evaluate the log messages in the specified file or Windows log. If a log message matches this regular expression, the agent will send that log message to Skylar One. If a log message does not match this regular expression, the agent will not send that log message to Skylar One.
      For Windows event logs, the Skylar One Agent adds the Event ID to the value in the Message portion of the Windows log before applying the value in the Filter field. The agent does not apply the value in the Filter field to the Instance ID or any other property of a Windows event log entry.
      Avoid adding a leading ".*" in a filter, such as ".ERROR", as that character might increase the time it takes the agent to execute the filter, and on busy Skylar One systems, that character in the filter can negatively impact the CPU.
  2. Click Save.
  3. In the Select Action drop-down list, select DELETE Log File Monitoring Policies.
  4. Click Go.
  • ID. The unique numeric ID of the Log File Monitoring policy. The ID is automatically assigned by Skylar One.
  • Filter. The regular expression the agent uses to determine if a log should be sent to Skylar One.
  • Limit. The maximum log messages the agent sends to Skylar One per minute. If the number of matching logs exceeds this value, the agent will stop sending logs to the platform for the remainder of the minute. The limit resets at the beginning of the next minute. For example, suppose you set this field to 10,000. Suppose the agent monitors a device that has 30,000 log messages. The agent will retrieve 10,000 logs and then wait until the beginning of the next minute. The agent will then retrieve the next 10,000 logs and then wait until the beginning of the next minute. The agent will continue to retrieve 10,000 logs per minute until it has retrieved all the logs from the device.
Filtering the List of Log File Monitoring Policies and Aligned Devices
You can filter the list of Log File Monitoring policies and aligned devices on the Log File Monitoring page using the search fields at the top of each column. When you type in each search field, the list of results on the page is automatically updated to match the text, including partial matches.
You can use special characters in each search field to filter. Fore more information about filtering using special characters, see the Filtering the List of Log File Monitoring Policies section.
  2. Click Create. The Log File Monitor modal appears.
  3. In the Log File Monitor modal, supply values in the following fields:
  • File. Specify a regular expression that will be used to evaluate the log messages in the specified file or Windows log. If and only if a log message matches this regular expression, the agent will send the log message to Skylar One.
  2. Select the checkboxes for the devices with which you want to align Log File Monitoring policies.
  3. In the Select Action drop-down list, select MODIFY by Template.
  4. Click Go. The Device Template Editor modal appears.
  5. Click the Logs tab.
  6. Click the Add New Log Policy Sub-Template icon ().
  7. Supply values in the following fields:
  5. Click Confirm. The aligned Log File Monitoring policy will appear on the Registry > Monitors > Logs page (Registry > Monitors > Logs).
To trigger events based on log messages collected by the agent in the classic user interface for Skylar One, you must create an event policy that is associated with a Log File Monitoring policy.
  2. In the Event Policy Manager page, click Create. The Event Policy Editor page appears.
  3. In the Event Policy Editor page and set of tabs, you can define a new event. The Event Policy Editor page contains three tabs:
    • %R. Indicates a regular expression. Surround the regular expression with %R and %/R. For example, %RFilename: .*? %/R would search for the first instance of the string "Filename: " followed by any number of any characters up to the line break. For details on the regular expression syntax allowed by Skylar One, see http://www.python.org/doc/howto/.
  • Use Modifier. If selected, when the event is triggered, Skylar One will check to see if the interface associated with this event has a custom severity modifier. If so, the event will appear in the Event Console with that custom severity modifier applied to the severity in the Event Severity field. For example, if an interface with an Event Severity Adjust setting of Sev -1 triggers an event with an Event Severity of Major and that event has the Use Modifier checkbox selected, the event will appear in the Event Console with a severity of Minor.
  1. Select the Advanced tab.
  3. Enter values in the following fields to specify specific text that must appear in the log message for the event policy to trigger:
  • First Match String. A string used to match against the originating log message. To match this event policy, the text of a log message must match the value you enter in this field. Can be any combination of alphanumeric characters. Expression matching in Skylar One is case-sensitive.
The Match Logic field specifies whether Skylar One should process First Match String and Second Match String as simple text matches or as regular expressions.
  2. Click Save.
