Creating Credentials for SNMP Devices
This section describes how to create credentials for monitoring SNMP-enabled devices.
Creating Credentials for Monitoring SNMP-Enabled Devices
To monitor SNMP-enabled devices with Skylar One, you must first create an SNMP credential. SNMP Credentials allow Skylar One to access SNMP data on a managed device. Skylar One uses SNMP credentials to perform discovery, run auto-discovery, and gather information from SNMP Dynamic Applications.
To create SNMP credentials:
  2. Click the Create New button and select Create SNMP Credential from the drop-down list that appears.
  4. Create SNMP Credential for Cisco Unity Express
  • Timeout (ms). Enter the time, in milliseconds, after which Skylar One will stop trying to communicate with the Cisco Unity Express device. The default value is 1500. This field is required.
  • SNMP Version. Select the version of SNMP that you want to create from the drop-down list. The default value is SNMP V2.
  • SNMP Retries. Keep the default. The default value is "1".
  • Port. Keep the default. The default port is "161".
SNMP V1/V2 Settings
SNMP V3 Settings
  • SHA
  • SHA-224
  • SHA-256
  • SHA-384
  • SHA-512
The SHA option is SHA-128.
  • AES-128
  • AES-192
  • AES-256
  2. Repeat steps 1-4 for each SNMP-enabled device in your network that you want to monitor with Skylar One.
NOTE: When you define an SNMP Credential, Skylar One automatically aligns the credential with all organizations of which you are a member.
Creating Credentials for Monitoring SNMP-Enabled Devices in the Skylar One Classic User Interface
To monitor SNMP-enabled devices in the Skylar One classic user interface, you must first create an SNMP credential.
  2. Click the actions icon and select Create SNMP Credential. The Credential Editor page appears.
  • Timeout (ms). Time, in milliseconds, after which Skylar One will stop trying to communicate with the SNMP device. The default value is 1500.
  • Retries. Number of times Skylar One will try to authenticate and communicate with the external device. The default value is 1.
SNMP V1/V2 Settings
SNMP V3 Settings
  • SHA
  • SHA-224
  • SHA-256
  • SHA-384
  • SHA-512
  • AES-128
  • AES-192
  • AES-256
