Additional Features
This chapter provides a brief overview of additional features in Skylar One that can help you with incident management and workflow.
Parent & Child Tickets
Skylar One allows you to align tickets in parent-child relationships. You can create parent-child relationships when multiple tickets exist for a single issue, or if multiple tickets are related or interdependent. Keep in mind when creating parent-child relationships that:
  • When the parent ticket is resolved, all children tickets are automatically resolved.
  • Moving the parent ticket to another queue has no effect on the children tickets.
  • Changing the severity of the parent ticket has no effect on the children tickets.
  • Except for "Resolved," changing the status of the parent ticket has no effect upon the children tickets.
  • Likewise, changing the queue, severity, or status of a child ticket has no effect upon the parent ticket.
For details on parent-child relationships, see the section on Parent-Child Relationships and Chargeback Service.
Multiple Events Aligned with a Single Ticket
Skylar One allows you to associate an existing ticket with an event, even if the ticket was not originally created from an event. This is helpful when you want to automatically clear an event when a ticket has been resolved. You can also change the event associated with an existing ticket.
If a ticket addresses multiple events, you might find it helpful to align the ticket with multiple events. When the ticket is resolved, Skylar One can automatically clear the selected event or events.
For details on aligning events and tickets, see the section on Creating and Editing Tickets.
Chargeback
Skylar One includes a tool that allows you to align a ticket with a product or service and then track the hours worked on a ticket. The combination of product or service plus the number of hours worked make up a chargeback service.
To view a list of product or service offerings, see the Product Catalog page (Registry > Service Provider Utilities > Product Catalog). When you align a chargeback service with a ticket, Skylar One automatically adds a note to the Notes & Attachments pane of the ticket.
You can also generate a Quick Report on chargeback services for each organization (Reports > Create Report > Quick Report > Ticket Billing). You can use this Quick Report to create a bill for each organization.
For details on chargeback services, see the section on Parent-Child Relationships and Chargeback Service.
For details on products and services, see the product catalog section.
For more details on the Ticket Billing report, see the section on ticketing reports.
Watchers
By default, Skylar One automatically generates an email to the ticket creator and ticket assignee when:
  1. A ticket is created
  2. A ticket is assigned to a user
  3. A ticket is updated
You can also assign a watcher to the ticket. A ticket watcher is a user (in addition to the ticket's creator or assignee) who receives email updates about the ticket. If a watcher is added to a ticket, Skylar One automatically sends the watcher emails when the ticket is created, assigned to another user, or changes status.
For details on watchers, see the section on Ticket Watchers.
Scheduled Tickets
Scheduled tickets, also called recurring tickets, are tickets that are automatically generated at regular intervals. For example, recurring tickets can be defined for daily, monthly, or weekly maintenance tasks. Users can then use all the ticket tools and reports in Skylar One to track and monitor these recurring tasks.
For details on creating and managing scheduled tickets, see the section on Scheduled and Recurring Tickets.
Custom States
A custom ticket state is an additional ticket parameter. The definition of a ticket state includes logic that you can use to control workflow.
Using a custom ticket state, you can specify that tickets with the custom state always have a specified status and ticket queue. You can also specify that tickets with a custom state can be moved only to specified ticket queues and can be changed only to specified custom states.
For details on custom states, see the section on Custom Ticket States.
Ticket History
The Ticket Editor page for each ticket includes a Logs tab that leads to the Ticket Logs page. The Ticket Logs page displays a history of the selected ticket. Each change to the ticket, from its creation to the current time, is displayed in a table in the Ticket Logs page. The table lists these changes chronologically, with the oldest first.
For details on ticket logs, see the section on Viewing Tickets.
Run Book Automation
Run Book Automation is a powerful tool that allows you to define automatic actions that Skylar One performs in response to events and additional event conditions.
Using Run Book  Automation, you can have Skylar One automatically send emails, create a new ticket, update an existing ticket, or run a custom Python script (among other actions). You can use Run Book Automation to automate your workflow and ensure uniformity.
For details on Run Book Automation, see the section on Run Book Automation.
Select Objects and Form Fields
You can use Select Objects to customize the entries that appear in drop-down lists throughout Skylar One. You can use Select Objects to customize the ticketing interface and other interfaces in your workflow.
You can use Form Fields to add custom fields and custom tabbed pages. You can use Form Fields to customize the ticketing interface and other interfaces in your workflow.
For details on Select Objects and Form Fields, see the sections on Select Objects and Form Fields.
