What Are Device Relationships?
Skylar One automatically defines parent and child relationships for certain devices. You can also define some types of relationships manually. Devices can have the following types of relationships:
- Layer-2 devices and their clients. Layer-2 relationships are automatically discovered by Skylar One and can be created on the Subnet Map (L2) page (Maps > Classic Maps > Topology Maps > Layer-2).
- Layer-3 devices and layer-2 devices. Layer-3 relationships are automatically discovered by Skylar One and can be created on the Layer 3 Map page (Maps > Classic Maps > Topology Maps > Layer-3).
- Network devices that use CDP (Cisco Discovery Protocol) and devices that are specified as neighbors in the CDP tables. CDP relationships are automatically discovered by Skylar One and can be created on the Subnet Map (CDP) page (Maps > Classic Maps > Topology Maps > CDP).
- Network devices that use LLDP (Link Layer Discovery Protocol) and devices that are specified as neighbors in the LLDP tables. LLDP relationships are automatically discovered by Skylar One and can be created on the Classic Maps > Topology Maps > LLDP page (Maps > Classic Maps > Topology Maps > LLDP).
- Network devices that use ARP (Address Resolution Protocol) and devices that are specified as neighbors in the ARP tables. ARP relationships are automatically discovered by Skylar One.
- Component devices and their parent devices using Dynamic Application data. For example, virtual machines and their hypervisors.
- Device relationships between root devices, parent devices, and component devices (Component Mapping).
- Device relationships created using Dynamic Application data. For example, the Dynamic Applications in the VMware vSphere and NetApp PowerPacks are configured to create relationships between VMware Datastore component devices and their associated NetApp Volume component devices.
- Generic parent-child relationships, sometimes referred to as Event Correlation relationships or ad hoc relationships, can be manually created. You can create these relationships on the Device Children modal for the parent device.
Skylar One also automatically discovers relationships between VMWare hypervisors and VMWare virtual machines using SNMP data, but only for legacy versions VMWare ESX 3.5 and VMWare ESX 4.x.
The system displays all device relationships as child and parent relationships. For example:
- A layer-2 switch is a parent device and a firewall attached to the switch is a child device.
- A layer-3 router is a parent device and a layer-2 switch attached to the router is a child device.
- A VMware ESX server is a parent device and a Linux virtual machine on that server is a child device.
The Device Relationships page displays information about every parent-child relationship that Skylar One creates automatically or that you define manually.
For example, suppose a switch has been discovered by Skylar One. Suppose that 12 interfaces on that switch are in use. Suppose that only three of those 12 interfaces are connected to child interfaces that have been discovered by Skylar One. The Device Relationships page displays whatever Address Resolution Protocol (ARP) information Skylar One can retrieve about the remaining nine child interfaces. In most cases, Skylar One can retrieve the MAC address and manufacturer associated with the child interface, even if the child interface has not been discovered by Skylar One.
The relationships on the Device Relationships page are dynamically updated. If Skylar One discovers a new relationship, Skylar One updates the Device Relationships page.
You can view information for each parent-child relationship between two devices managed by Skylar One or for a single parent device managed by Skylar One and an unknown child device.
- Go to the Device Relationships page (Registry > Networks > Device Relationships).
- The Device Relationships page displays the following information:
You can sort the list of device relationships by column. To sort by ascending column value, click a column heading. To sort by descending column value, click on the same column heading a second time.
The Device Relationships page applies multi-tenancy rules. You can view relationships on this page only if both devices belong to an organization that you are a member of.
- Child. If the child device has been discovered by Skylar One, this column contains the name of the device and a link to the Device Relationships page for the child device.
- Child IP. If the child device has been discovered by Skylar One, this column contains the IP address through which the child communicates with the parent device.
- Child Interface. If the child device has been discovered by Skylar One, this column contains the name of the interface through which the child device communicates with the parent device and a link to the Interfaces Found page for the child interface.
- Child Phys Addr. The physical address (MAC address) for the interface through which the child device communicates with the parent device.
- Child IF Manufacturer. If included in the MAC address, the manufacturer of the child interface.
- Parent. The name of the parent device and a link to the Device Relationships page for the parent device.
- Parent Interface. The name of the interface through which the parent device communicates with the child device and a link to the Interfaces Found page for the parent interface.
- Parent IF Alias. Easy-to-remember, human-readable name for the interface on the parent device.
- Parent Phys Addr. The physical address (MAC address) for the interface through which the parent device communicates with the child device.
- Parent IF Manufacturer. If included in the MAC address, the manufacturer of the parent interface.
- Type. Describes the relationship between the parent device and child device. Possible values are:
- ARP
- CDP
- Component Mapping
- Component Relationship
- Event Correlation
- Layer-2
- Layer-3
- LLDP
- VMware
You can view all links for a single device on the Relationships tab of the Device Investigator (or on the Device Relationships page in the Device Properties panel in the classic Skylar One user interface).
- Go to the Relationships tab of the Device Investigator. (Alternatively, go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface), click the wrench icon for a device (
) and then click the tab.) The Device Relationships page appears.
- The left pane of the Device Relationships page displays links to parent devices. The right pane of the Device Relationships page displays links to child devices. For each relationship, the Device Relationships page displays the following information:
- Type of relationship. Possible values are:
- ARP. Network devices that use ARP (Address Resolution Protocol) and devices that are specified as neighbors in ARP tables.
- CDP. Network devices that use CDP (Cisco Discovery Protocol) and devices that are specified as neighbors in CDP tables.
- Component Mapping. Relationships defined using Dynamic Applications.
- Event Correlation. Relationships defined manually by users through the user interface.
- Layer 2. Layer-2 devices and their clients.
- Layer 3. Layer-3 devices and layer-2 devices.
- LLDP. Network devices that use LLDP (Link Layer Discovery Protocol) and devices that are specified as neighbors in LLDP tables, including those devices that respond only to LLDP v2.
- VMware. Hypervisors and their virtual machines.
- Parent Device. The name of the parent device and a link to the Device Properties page for the parent device.
- Child Device. The name of the child device and a link to the Device Properties page for the child device.
- Child Interface. The name of the interface through which the child device communicates with the parent device and a link to the Interfaces Found page for the child interface.
If you click a device, the Device Relationshipspage reloads and the selected device becomes the primary device.
Viewing Device Topology Maps
On the tab of the Device Investigator, you can view a map of the selected device and all of the devices with which the device has relationships.
These relationships include:
- Layer-3 devices and Layer-2 devices
- Component devices and their parent devices. For example, hypervisors and their virtual machines.
- Network devices that use CDP (Cisco Discovery Protocol) and devices that are specified as neighbors in CDP tables
- Links between network devices that use CDP (Cisco Discovery Protocol) and devices that are specified as neighbors in CDP tables
- Network devices that use LLDP (Link Layer Discovery Protocol) and devices that are specified as neighbors in LLDP tables
- Links between network devices that use LLDP (Link Layer Discovery Protocol) and devices that are specified as neighbors in LLDP tables
- Device relationships created with Dynamic Applications
- Manually created parent-child relationships that affect event correlation
- Nodes. Shapes that represent Devices, Topology Elements, and Business Services defined in Skylar One. The shape of a node represents its type, and the color of its outline specifies the current state of the node.
- Edges. Lines with or without arrows that represent the relationships and hierarchies between nodes. The system displays all device relationships as child and parent relationships. If the nodes on a map contain arrows, then the arrows represent the direction of the relationship, pointing from the child node to its parent node. If a node does not contain an arrow, then the relationship is bidirectional, or undirected.
When you hover your mouse over a device icon on the map, a pop-up window appears that displays information about that device. Click the device name in the pop-up window to go to the Device Investigator for that device.
You can use the icons on the page to do the following:
- Increase the map size (
) - Decrease the map size (
) - Fit all of the map elements into the viewing pane (
) - Center the selected elements of a map in the viewing pane (
Defining Device Relationships
Use the Device Children modal to select one or more devices to become child devices of the selected device.
To add children to a device:
) and then click the tab.) The Device Relationships page appears. - Click the button and then select Device Children. The Device Children modal appears.
- In the Device Children modal, select one or more devices to be children of the current device.
Event Correlation
In Skylar One, event correlation means the ability to build parent-child relationships between devices and their events. When events are correlated, only the parent event appears on the Events page.
- On the Events page, the child events are rolled up and nested under the parent event and appear only if you click the magnifying-glass icon (
). - For the parent event, the Count column shows the number of correlated child events.
Events that Might Appear on the Events Page
In Skylar One, there are four types of events that might not appear on the Events page:
- Rolled-up events. Multiple occurrences of the same event on the same device. When the same event occurs multiple times on a single device, Skylar One does not display each occurrence on the Events page. Instead, Skylar One displays a single entry and notes the number of occurrences in the Count column.
- Suppressed Events. Suppressed events do not appear on the Events page.
- Topology Events. In Skylar One, event correlation or topology suppression means the ability to build parent-child relationships between devices and between events. When events are correlated, only the parent event is displayed on the Events page. The magnifying-glass icon (
) appears to the left of the parent event. When you click on the magnifying-glass icon, the list of child events is displayed. The child events are rolled up under the parent event and are not displayed on the Events page. For the parent event, the count column shows the number of correlated child events. Optionally, you can define event categories that allow Skylar One to more efficiently align suppressing events with suppressible events. When you align an event category to a suppressing or suppressible event, that event correlates only with events that are aligned with the same event category.
Enabling a discovered device configured with Cisco Discovery Protocol (CDP) or Link Layer Discovery Protocol (LLDP) topology in Skylar One causes the device to provide information on its neighbor. This information identifies only that there is a neighbor device, not which is the parent or the child. This might cause the parent-child relationship to switch which requires you to manually reverse the issue within the Skylar One user interface. Skylar One provides a way to manually build parent-child relationships between specific device categories. For more information, see Defining Parent and Child Devices in the Events manual.
- Event Masks. In the Device Properties page for each device, you can define an Event Mask. When a device uses the Event Mask setting, events that occur on a single device within a specified span of time are grouped together. On the Events page, masked events are displayed under a single event, the one with the highest severity. The magnifying-glass icon (
) appears to the left of the event. When you click on the magnifying-glass icon, the list of all events that are masked under the event appears.
Defining Event Correlation
To manually configure event correlation in the classic Skylar One user interface, you must define two types of events:
- Suppressing events. If this event occurs on a parent device, Skylar One searches all related child devices for suppressible events. On the child devices, all suppressible events are suppressed. Only the suppressing event appears on the Events page (or the Event Console page in the classic Skylar One user interface). The suppressible events do not appear on the Events page (or the Event Console page in the classic Skylar One user interface).
- Suppressible events. This type of event is suppressed on a child device only when a suppressing event occurs on the parent device.
If you configure event categories, the suppressing and suppressible events must be associated with the same category for correlation to occur. If you do not configure event categories, each and every suppressing event that occurs on a parent device causes Skylar One to suppress all suppressible events on the associated child devices.
To define an event as a suppressing event on the Event Policy Manager page in the classic Skylar One user interface:
- On the Event Policy Manager page, click the wrench icon (
) of the event that you want to define as the suppressing event. The Event Policy Editor page appears. - On the Event Policy Editor page, click the tab.
- In the Topology Suppression field, select Suppressing.
- Click . After you save, when this event occurs on a device, Skylar One checks if the device is a parent device. If the device is a parent device, specified events (suppressible events) with the same category are suppressed on the child devices.
To define an event as a suppressible event on the Event Policy Manager page in the classic Skylar One user interface:
) of the event that you want to define as the suppressible event. The Event Policy Editor page appears. - On the Event Policy Editor page, click the tab.
- In the Topology Suppression field, select Suppressible.
- Click . In the future, when this event occurs on a device, Skylar One checks if the device is a child device. If the device is a child device, Skylar One checks to see if a suppressing event with the same category has occurred on the parent device. If a suppressing event has occurred on the parent device, the specified event is suppressed on the child device.
Example: Child Event Suppression
For example, suppose you have the following devices and event policies defined:
- A parent device, a Cisco Catalyst switch named Boise-DMZ
- A child device to Boise-DMZ, a server named HQ-W2K3-VC01
- An event policy, "Poller: Interface operationally down", defined as a suppressing event
- A second event policy, "Poller: Device not responding", defined as a suppressible event
- Both events are associated with the same event category.
In this scenario, if an interface goes down on the switch Boise-DMZ, Skylar One cannot communicate with the server, HQ-W2K3-VC01, attached to the switch.
With the event topology suppression defined above:
- The event "Poller: Interface operationally down" occurs on Boise-DMZ.
- The event "Poller: Device not responding" is suppressed on the server HQ-W2K3-VC01.
- On the Events page (or the Event Console page in the classic Skylar One user interface), the only event that appears in this scenario is the event "Poller: Interface operationally down" on the device Boise-DMZ.
Layer-2 Topology Collection and Processing
A Layer-2 topology record describes a direct network connection between a parent device (a network switch or network bridge) and a child device. The child device is one of the following:
- Another bridge device discovered in Skylar One
- Another type of device that is discovered in Skylar One
- A device that is not discovered in Skylar One
Every hour, Skylar One collects information from the BRIDGE-MIB from all discovered network switches and bridges. Network switches and bridges that support the BRIDGE-MIB report information about all MAC addresses for which that network switch or bridge has forwarding information.
Enable Layer-2 collection only on network devices that respond to SNMP requests for object IDs (OIDs) from the BRIDGE-MIB. Layer-2 collection is not required for the collection of MAC addresses on the interfaces of non-bridge network devices; this is done automatically as part of interface discovery.
In Skylar One 12.5.1 and later, you can enable or disable Layer-2 collection for
In version 12.5.20 and later, Skylar One automatically removes stale Layer-2 topology relationships when connections no longer exist or a parent/child device becomes inactive.
During collection, Skylar One performs the following steps:
- Compiles a list of all devices to poll. Skylar One polls devices that have a Device Category of "Network.Switches" or "Network.Bridges". The Device Category is defined in the device's device class.
- If the Enable L2 Topology Collection from all VLANs checkbox is selected on the Behavior Settings page (System > Settings > Behavior), Skylar One compiles a list of virtual local area networks (VLANs) for which data should be collected using the CISCO-VTP-MIB. A VLAN is added to the list of VLANs only if its state is 1 (operational) and its type is 1 (ethernet). If the Enable L2 Topology Collection from all VLANs checkbox is cleared, Skylar One performs collection for vLAN 1 only.
- For each VLAN on each device, Skylar One polls the BRIDGE-MIB to collect the list of all MAC addresses for which that network switch or bridge has forwarding information.
- Skylar One stores a MAC address record if:
- The status of the record is "3" (learned).
- An ifIndex value was collected successfully for the associated port index.
The information collected from the BRIDGE-MIB does not explicitly indicate which devices are directly connected to a network switch or bridge; switches and bridges report forwarding information for MAC addresses that are several network hops away from the switch or bridge. A second crunch process creates Layer-2 topology relationships by evaluating all of the collected MAC address records holistically.
Layer-2 Topology Processing
In Skylar One 12.5.1 and later, you can choose to enable standard or enhanced processing methods for specific devices or entire device classes.
Standard Layer-2 processing, which is used by default in versions of Skylar One before 12.5.1, uses the "Enterprise Database: Topology Crunch" process to determine Layer-2 topology relationships based on device category, to connect network devices to each other.
Enhanced Layer-2 processing, which is available in Skylar One 12.5.1 and later, can form Layer-2 relationships between any devices that match a MAC address from the BRIDGE-MIB or sourced from Dynamic Applications, regardless of device category.
CDP Topology Collection
Cisco Discovery Protocol (CDP) is a proprietary standard developed by Cisco that is used by networking devices to communicate configuration information to the other devices in the network. It is not supported by all network hardware. Devices that support CDP store and report information received about their immediate neighbors.
A CDP Topology record describes a direct network connection between a parent device (a network switch or network router) and a child device. If your network includes both CDP-enabled and non-CDP network switches and routers, the topology data reported by the CDP-enabled devices might not be accurate.
Suppose a network includes three switches connected in the following way.
- Switches A and C, which are both CDP-enabled, broadcast CDP messages.
- Because Switch B is not CDP-enabled, the broadcast messages from Switch A will reach Switch C. Therefore, Switch C will report that it is directly connected to Switch A.
- Conversely, the broadcast messages from Switch C will reach Switch A. Therefore, Switch A will report that it is directly connected to Switch C.
In addition to the CDP data collected from the switches in this example, Skylar One might also collect Layer-2 topology data that can be used to create correct topology links. However, each discovered interface can be associated with only one topology record of any type. If a conflict exists between the collected CDP topology data and the collected Layer-2 topology data, the CDP topology data takes precedence. In the example above, the CDP topology data will be inaccurate, but the Layer-2 data might be accurate. Therefore, if your network includes both CDP-enabled and non-CDP network switches and routers, you might want to disable CDP topology collection on the Behavior Settings page (System > Settings > Behavior).
If CDP collection is enabled, Skylar One collects information from the Cisco-CDP-MIB from all discovered network switches and routers. Skylar One polls devices that have a device category of "Network.Switches" or "Network.Routers". The Device Category is defined in the device class assigned to the device. Network switches and routers that support the Cisco-CDP-MIB report the IP address and interface information for all directly connected devices that are CDP-enabled.
Although Skylar One polls all network switches and routers for CDP information, not all network switches and routers support CDP. To save system resources, enable CDP collection only on devices that respond to SNMP and have CDP configured.
Each discovered interface can be associated with only one topology record of any type. Therefore, the same "crunch" process that creates Layer-2 topology records is also responsible for creating the CDP records based on the collected data. However, unlike Layer-2 topology records, the Cisco-CDP-MIB reports only directly connected devices. Therefore, if all associated interfaces are valid and available, there is a 1:1 mapping between collected CDP relationships and the CDP relationships created by the "crunch" process.
To view CDP maps, go to the Subnet Map (CDP) page (Views > Topology Maps >CDP). For more information on viewing CDP maps, see the
CDP Topology Processing
Standard CDP processing, which is used by default in versions of Skylar One prior to 12.5.1, requires that both devices respond with CDP neighbor data, show each other as a neighbor, and be managed devices in Skylar One to form a CDP topology relationship with each other.
Enhanced CDP processing, which is available in Skylar One 12.5.1 and later, can form CDP relationships between two devices if at least one of those devices responds with CDP neighbor data and is a managed device in Skylar One. This new process also supports asynchronous collection, which increases the scale of CDP collection when devices are slow to respond or to load due to network latency.
LLDP Topology Collection
Link Layer Discovery Protocol (LLDP) is a standard used by networking devices to communicate configuration information to the other devices in the network. Devices that support LLDP store and report information received about their immediate neighbors.
An LLDP topology record describes a direct network connection between a parent device (a network switch or network router) and a child device. If your network includes both LLDP-enabled and non-LLDP network switches and routers, the topology data reported by the LLDP-enabled devices might not be accurate.
- Switches A and C, which are both LLDP-enabled, broadcast LLDP messages.
- Because switch B is not LLDP-enabled, the broadcast messages from switch A will reach switch C. Therefore, switch C will report that it is directly connected to switch A.
- Conversely, the broadcast messages from switch C will reach switch A. Therefore, switch A will report that it is directly connected to switch C.
In addition to the LLDP data collected from the switches in this example, Skylar One might also collect Layer-2 topology data that can be used to create correct topology links. However, each discovered interface can be associated with only one topology record of any type. If a conflict exists between the collected LLDP topology data and the collected Layer-2 topology data, the LLDP topology data takes precedence. In the example above, the LLDP topology data will be inaccurate, but the Layer-2 data might be accurate. Therefore, if your network includes both LLDP-enabled and non-LLDP network switches and routers, you might want to disable LLDP topology collection on the Behavior Settings page (System > Settings > Behavior).
If LLDP collection is enabled, Skylar One collects information from the LLDP MIB from all discovered network switches and routers. In Skylar One 12.5.20 and later, the system can also collect information from the LLDP-V2 MIB to discover relationships between devices that respond only to LLDP v2. Skylar One polls devices that have a device category of "Network.Switches" or "Network.Routers". The device category is defined in the device class assigned to the device. Network switches and routers that support the Cisco-LLDP-MIB report the IP address and interface information for all directly connected devices that are LLDP-enabled.
Although Skylar One polls all network switches and routers for LLDP information, not all network switches and routers support LLDP.
Each discovered interface can be associated with only one topology record of any type. Therefore, the same "crunch" process that creates Layer-2 topology records is also responsible for creating the LLDP records based on the collected data. However, unlike Layer-2 topology records, the LLDP MIB reports only directly connected devices. Therefore, if all associated interfaces are valid and available, there is a 1:1 mapping between collected LLDP relationships and the LLDP relationships created by the "crunch" process.
LLDP Topology Processing
Standard LLDP processing, which is used by default in versions of Skylar One prior to 12.5.1, requires that both devices respond with LLDP neighbor data, show each other as a neighbor, and be managed devices in Skylar One in order to form an LLDP topology relationship with each other.
Enhanced LLDP processing, which is available in Skylar One 12.5.1 and later, can form LLDP relationships between two devices so long as at least one of those devices or its network interface responds with LLDP neighbor data and is a managed device in Skylar One. This new process also supports asynchronous collection, which increases the scale of LLDP collection when devices are slow to respond or to load due to network latency.
Layer-3 Topology Collection
The system creates Layer-3 topology records by running a traceroute command from a Data Collector or the All-In-One Appliance to the discovered network hardware every two hours:
- For each hop in a traceroute that specifies an IP address associated with a discovered device, Skylar One creates a Layer-3 topology record that connects the device from the previous hop to the device for the current hop.
- Layer-3 topology records are created only when both devices are discovered; Layer-3 topology records are not created when one or both of the two devices is unknown.
- If the IP address associated with a hop is associated with an unknown device, Skylar One does not store that hop or any subsequent hops for that traceroute.
- Layer-3 topology records describe only that two devices are connected; Layer-3 topology records do not describe which interfaces on those devices are connected.
For Skylar One to create Layer-3 topology records, the following requirements must be met:
- All traceroute commands for Layer-3 topology collection originate from Data Collectors or an All-In-One Appliance. Therefore, the parent node in the Layer-3 topology is always a Data Collector or the All-In-One Appliance. For Skylar One to create Layer-3 topology records, all Data Collectors and All-In-One Appliances must be discovered.
- Skylar One performs traceroute commands to devices that have the L3 Topology option enabled. The L3 Topology option is defined in the device class assigned to a device. For Skylar One to perform Layer-3 topology collection, at least one device in your system must have the L3 Topology option enabled in the device class.
- Your network configuration must allow the traffic generated by the traceroute commands. To test whether your network allows this traffic, go to the Device Toolbox page (by clicking the tab in the Device Administration panel) for a device with the L3 Topology option enabled, and then click the Traceroute icon.
A device that has the L3 Topology option disabled can still be associated with a Layer-3 topology record. If an IP address associated with a device that has the L3 Topology option disabled appears as a "hop" in a traceroute command performed for a different device, the device with the L3 Topology option disabled will be associated with the Layer-3 topology records that represent the hops to and from that device.
Layer-3 Topology Processing
Standard processing, which is used by default in versions of Skylar One prior to 12.5.1, requires all the hops in a traceroute to respond and match devices within Skylar One. The traceroute is discarded whenever the system detects hops that fail to respond or the traceroute includes hops that do not match devices in Skylar One.
Enhanced processing, which is available in Skylar One 12.5.1 and later, does not discard incomplete traceroutes or results that include unmatched hops. Instead, the system forms relationships between any two hops that respond and match devices in Skylar One.
ARP Topology Collection
Address Resolution Protocol (ARP) is a standard networking protocol used to map a logical IP address to a physical hardware MAC address within a single local area network (LAN). It works only with IPv4 addresses. Devices that support ARP store these IP-to-MAC mappings and make it easier for devices on a local network to communicate with each other.
In versions 12.5.20 and later, Skylar One can collect and store ARP data from devices that have ARP collection enabled, either at the class or device level. These devices, which are typically switches or routers, must respond to SNMP and have network interfaces discovered for Skylar One to create the ARP relationship. Only one device needs to provide ARP data for Skylar One to form the relationship.
ARP Topology Processing
In Skylar One 12.5.20 and later, you can choose to enable standard or enhanced ARP processing methods for specific devices or entire device classes.
Standard ARP processing creates ARP relationships only when both devices are routers or switches.
Enhanced processing ignores this device type restriction and creates relationships when ARP data matches, regardless of the device class.
