Devices in the SL1 User Interface
The Devices page allows you to view all of your managed devices in SL1 and also run a discovery to find more devices to monitor. You can select a device from the list on the Devices page to view detailed data on the Device Investigator page for that device.
The list of devices on the Devices page matches the list of devices on the Device Manager page (Devices > Device Manager).
Viewing Devices
The Devices page allows you to view all of your managed devices in SL1. This section explains how to gather more information about a device from this page.
To navigate to the Devices page, click the Devices icon ():
Image of the Devices page.
For each device, the Devices page displays the following information:
  • IP Address. The device's IP address.
  • Category. The category assigned to the device. Categories include servers, routers, switches, firewalls, and printers, among others. The category is automatically assigned during discovery, at the same time as the as Device Class. For more information about Device Categories, see the section on Managing Device Classes and Device Categories.
  • Class. The manufacturer and type of device. The Device Class is automatically assigned during discovery, at the same time as the Category.
  • ID. The Device ID. This is a unique number that SL1 automatically assigns to the device during discovery.
  • State. The current condition of the device, based upon events generated by the device. The device can have one of the following States:
  • Hostname. The fully qualified hostname for the device, for devices that are discovered and managed by hostname (instead of IP address). This column does not appear by default, but you can add it by clicking Grid Settings > Column Preferences.
Viewing Additional Data about a Device
On the Events page and the Devices page, you can click the Expand icon () next to an event or device to open a new Device Summary modal:
Image of the Device Detail Window
  • The Tools pane enables you to run a set of diagnostic tools or user-initiated actions in the Activity Center, or to click on custom links that will open in a separate browser window. Click the search bar to search for tools, actions, or custom links that are available for the device.
  • The Vitals pane displays graph data for the past four hours of CPU usage, memory usage, and latency for that device, where relevant. You can zoom in on a shorter time frame in the Vitals graph by clicking and dragging, and you can go back to the original time span by clicking the Reset zoom button.
Aligning a Device with a Different Organization
To align a device with a different organization:
  1. On the Devices page, click the Actions button () for the device and select Align Organization. The Align to Organization window appears.
To align more than one device to an organization, select the checkboxes to the left of those devices and click Align Organization in the blue bar at the bottom of the screen.
  1. In the Align to Organization window, use the Organization drop-down to search for and select an organization.
  2. Click the Align Organization button. The organization you selected now appears in that Info drop-down on the Device Investigator page for that device.
Adding Devices with Discovery
On the Devices page, you can click the Add Devices button to run a guided or unguided discovery session, a process that searches for and adds more devices to SL1 for monitoring.
For more information about adding devices using guided or unguided discovery, see Discovery and Credentials.
Using the Device Investigator
The Device Investigator displays a customizable, detailed set of data about a specific device.
From the Devices page, click the name of a particular device to open the Device Investigator page for that device:
Image of a new metric in the Device Investigator
The tabs on the Device Investigator page provide access to all of the data associated with the device. The tabs are similar to the tabs on the Device Administration and Device Properties panels in the classic SL1 user interface.
Only tabs relevant to the selected device are available on the Device Investigator page. For example, the Agent and Interfaces tabs do not display if the selected device does not use agents or interfaces. Also, widgets on the Investigator tab display as "Empty" where no metrics exist for that widget.
The Device Investigator page can include the following menus and buttons:
  • Info. This drawer on the Investigator tab displays additional information about the device, along with the most recently updated values for uptime and collection time.
  • Report. This button lets you generate a detailed report on the device.
  • Tools. This button opens the Activity Center, where you can run a set of diagnostic tools or user-initiated actions, or to click on custom links that will open in a separate browser window.
The Device Investigator page contains the following tabs:
  • Investigator. Displays panels that provide basic information and metric data about a device. For most devices, the default panels include an Overview panel, Events, Logs, Availability, and combined charts for metrics such as utilization, discards, and errors. You can customize the panel layout on this page to meet your specific business needs, including select additional metrics to display.
  • Settings. Lets you manage your preferences for that device, such as whether to auto-clear events, accept all logs, run daily port scans, and more. You can also set user maintenance preferences and disable or enable collection on that device.
  • Attributes. Lists the custom descriptive fields that are currently aligned with this device. On this tab, you can add and remove extended custom attributes to this device.
  • Changes. Displays active and cleared Change Events for a device.
  • Collections. Lets you align or un-align Dynamic Applications with this device, enable or disable collection for the Dynamic Applications, and run a Dynamic Application. You can also change credentials and update the poll frequency for a Dynamic Application.
  • Configs. Displays configuration information collected from the device by Dynamic Applications. If this device does not have any configuration data, this tab does not appear.
  • Events. Displays a list of active and cleared events for the device. You can acknowledge events from this tab and add event notes.
  • Journals. Displays journal entry information collected from the device by Dynamic Applications.
  • Logs. Displays all of the messages SL1 and the SL1 Agent, if applicable, have collected from the device.
  • Machine Learning. Displays a list of machine learning metrics that are enabled for the device.
  • Map. Opens a map of that device and the devices it is related to (for systems that have the Maps page enabled).
  • Monitors. This tab lets you define monitoring policies for the device.
  • Notes. Displays notes and attachments associated with the device. You can also edit and create notes.
  • Ports. Displays a list of all open ports on the device.
  • Processes. Displays a list of system processes running on the device.
  • Redirects. Allows you to redirect logs entries from an IP-based device to the current device. This is most useful when the current device is a virtual device, but you can also redirect log entries from one IP-based device to another IP-based device.
  • Relationships. Displays information about parent-child relationships between devices.
  • Schedules. Allows you to view and manage all the scheduled processes you have defined in your system.
  • Software. Displays a list of all the software installed on the device.
  • Thresholds. Lets you define space and performance thresholds for a device.
  • Tickets. Displays all open, pending, or working tickets associated with the device.
  • More. This drop-down lets you select additional tabs to display on the Device Investigator page by clicking the star icon next to the tab name. You can search for specific items on a tab, such as Device Class, Uptime, or Category, and the relevant tab will appear in the search results. You can also remove a tab by clicking the star icon again, turning it from blue to white. Your tab selections are saved and remain in place even after you log out:
Click the forward-slash button (/) to open the More drop-down. You can highlight search results using the Up and Down Arrow keys on your keyboard, and select a result by pressing Enter. To close the drop-down, click the word More.
On the Device Investigator page, you can view read-only information about the device in the Info drawer:
  • Collector. The Collector Group that was last used to collect data from the device. For All-In-One Appliances, this field will contain the name of the default, built-in Collector Group.
  • Collecting. Indicates that the device collection is "Collecting" with a green check mark icon (), meaning SL1 is periodically collecting data from the device, or "Not Collecting" with a prohibition icon (), meaning the SL1 is not currently collecting data from the device.
  • Category. The device category associated with the device. The device category usually describes the primary function of the device, such as a "server", "switch", or "router".
  • Uptime. The number of days and hours that the device has been continuously up and communicating with SL1.
Running a Device Report
On the Device Investigator page for a specific device, you can generate a detailed report on that device. You can specify the information to include in the report and the format that SL1 will use to generate the report, including HTML, PDF, XLS, and more.
  1. On the Device Investigator page, click the Report button in the top navigation bar. The Device Report modal page appears.
  1. In the Type drop-down, select the type of report you want to generate. Your options include:
  1. In the Format drop-down, select the format for the report. Your options include:
Using the Action Runner
On the Device Investigator page, you can click the Tools menu to display the Action Runner. The Action Runner enables you to run a set of diagnostic tools or user-initiated actions, or to click on custom links that will open in a separate browser window.
NOTE: For more information about user-initiated actions, see the section on User-Initiated Automations. For more information about custom links, see the section on Custom Links.
To use the Action Runner:
  • Click Activity in the navigation bar at the top of any page in SL1. Click the search bar.
  1. When you click the search bar, a list appears of the default tools, actions, or custom links that are available for the selected device. Click one of these tools, actions, or custom links, or use the search bar to search for a tool or action that is not listed. The following default tools are available in the Action Runner:
  • Ping. Displays statistics returned by the ping tool. The ping tool sends a packet to the device's IP address (the one used by SL1 to communicate with the device) and waits for a reply. SL1 then displays the number of seconds it took to receive a reply from the device and the number of bytes returned from the device. If the device has an IPv6 address, SL1 uses the appropriate IPv6 ping command.
  • Trace Route. Displays the network route between SL1 and the device. The tool provides details on each hop to the endpoint. If the device has an IPv6 address, SL1 uses the appropriate IPv6 traceroute command.
The tools found in the Action Runner can also be found in the Device Toolbox in the classic SL1 user interface.
  1. If you clicked a custom link, the link opens in a new browser window. If you clicked on a tool or action, then as it runs, its progress and results appear in a log in the Activity Center.
Image of the Activity Center
The following section provides an overview of how to use the tabs on the Device Investigator page for a selected device.
The Investigator Tab
The Investigator tab of the Device Investigator page displays a customizable set of metrics about the selected device.
The device type determines which metrics appear in the Investigator tab. For most devices, the following panels and metrics appear by default:
  • Overview. Displays a panel that includes basic information about the device, including its IP address, Device Class, organization, current state, event count, and collection status.
  • Availability. Displays a panel for the device's availability over time. Availability means a device's ability to accept connections and data from the network.
  • Latency. Displays a panel for latency for the device over time, in milliseconds. Latency means the amount of time it takes SL1 to communicate with the device.
  • Map. Displays a panel with a map of the device and all of the devices with which the device has relationships. You can also click the Map panel heading to go to the Map tab for that device. This panel is disabled by default, but can be enabled by clicking the Edit button, and then selecting the Map checkbox.
  • CPU Utilization, Physical Memory Utilization, and Swap Memory Utilization. Displays a combined chart panel with the percentage of CPU, physical memory, and swap memory used by the device over time.
  • Utilization In and Out. Displays a combined chart panel with the percentage of utilization in and out for the device's network interfaces.
  • Discards In and Out. Displays a combined chart panel with the number of discards in and out for the device's network interfaces over time.
  • Errors In and Out. Displays a combined chart panel with the number of errors in and out for the device's network interfaces over time.
  • Logs. Displays a panel with a list of the logs for the device, sorted from newest to oldest by default. You can use the Search field to search device logs for specific event messages, event IDs, date ranges, source types, and other relevant text for troubleshooting. You can also click on the column headers for Date/Time, Source, Event ID, Severity, and Message to sort by that column.
You can customize the look and feel of the Investigator tab by contracting, expanding, and resizing panels as needed. Click the contract icon () in the panel header to display only the header or click the expand icon () to display the panel's full contents. Click the Actions icon () in the panel header and then select Small, Medium, or Large to resize the panel.
You can customize the appearance of leaderboard panels for interfaces, file systems, and Dynamic Applications in the Investigator tab. Click the Leaderboard Bar Chart icon () to switch from a bar chart to a line chart, or click the Line Chart icon () to switch from a line chart to a leaderboard bar chart.
The Investigator tab panel layout is responsive. Panels are automatically resized or relocated whenever a panel is added or removed, the panels are rearranged on the page, or the browser page increases or decreases in size.
The Device Investigator page also includes the following sidebar buttons:
Select the Always display raw data checkbox at the top of the timespan selector to ensure that the metric data that appears in the panels on the Investigator tab always includes the most recent data available. If you do not select that checkbox, SL1 will still display raw data when you select a timespan of less than 2 days, but will automatically display rolled up hourly data for timespan selections of 2-45 days and rolled up daily data for timespan selections of more than 45 days.
In the right-hand pane, you can click Expand at the bottom of a panel to make that panel bigger.
Optionally, you can add metrics to the Investigator tab for Dynamic Applications, interfaces, and the SL1 Agent (if applicable), among other things. You can also remove metrics from the Investigator tab.
  1. To add a metric panel that is not currently on the Investigator tab, click the Edit button on the right sidebar to expand the layout panel, and then click the Add a metric field. A list of metrics appears:
Image of the list of metrics in the Device Investigator
  1. Select a metric from the list, or type the name of a metric and select it from the list. The metric is added to the right pane, and a corresponding widget appears in the left pane.
  2. Some metrics might require you to make additional selections, such as the network interfaces associated with a device. Click the field and add one or more additional metrics, as needed.
  1. To remove a metric panel from the Investigator tab, uncheck the corresponding box in the right panel. The metric remains listed in the right panel, but the panel is removed from the Investigator tab.
  2. To completely remove the metric and its corresponding panel from the Investigator tab, click the Remove from Layout button (Image of the Close button) for that metric in the right panel.
The Investigator tab retains any changes you made to the set of device metrics displayed for each device, on a per-user basis. To reset these changes to their default settings, click the Reset button at the bottom of the right panel. Optionally, you can apply these changes to other Device Categories, Device Classes, or devices. For more information, see the section on Applying a Custom Device Investigator Layout to Other Devices.
On the Investigator tab of the Device Investigator page, the order in which the metric panels appear in the right panel when you click the Edit button mirrors the order in which the corresponding metric panel widgets appear in the left panel. You can drag and drop the panels up or down in the right panel to edit the order in which the metric panels appear on the left panel. This enables you to prioritize the information that appears on the page.
  1. On the Investigator tab of the Device Investigator page, click the Edit button on the right sidebar to expand the layout panel.
  2. Hover your mouse over the "Panel" heading of the panel that you want to move until you see an open hand icon appear:
  1. Click and hold down the left button on your mouse to grab the panel, and then use your mouse to drag the panel to a different location in the list. When you do so, the open hand icon becomes a closed hand icon, and a blue dotted box appears around the panel.
  1. Release the left mouse button to drop the panel in your desired location. The new right-hand panel order will be reflected in the left-hand widget panel.
On the Investigator tab of the Device Investigator page, you can combine charts for different time-series metrics to see all of the combined data for those metrics in a single chart.
To combine charts:
  1. Click and hold down the left button on your mouse to grab the metric, and then use your mouse to drag the metric into the panel of a different time-series metric in the list. When you do so, the open hand icon becomes a closed hand icon, and the panel containing the combined metrics turns blue.
  1. Release the left mouse button to drop the metric into the desired panel. The newly combined metric panel will be reflected in a "Combined Charts" widget in the left-hand widget panel.
The device Investigator tab has a default layout that includes widgets such as an Overview panel, Events panel, Logs panel, and combined chart panels for utilization, discard, and error metrics. Initially, this layout is assigned to all devices.
You can also create custom Investigator tab layouts for individual devices or entire Device Classes or Device Categories, and then apply those updates either to only yourself or to all system users.
To apply a custom device Investigator layout to other devices:
  1. On the Investigator tab of the Device Investigator page, click the Edit button on the right sidebar to expand the layout panel. When you do so, the Investigator tab name will appear at the top of the layout panel, along with one of the following labels:
  • Default. Indicates the layout has not been changed from the default settings.
  • Private. Indicates the layout has been changed from the default settings but only applied to the logged in user.
  • Public. Indicates the layout has been changed from the default settings and has been applied to all system users.
  1. Make updates to the Investigator layout as needed, such as by adding or removing metrics, editing the metric panel order, or combining one or more charts into a single panel. When you do so, the label at the top of the layout panel will change to "Private", if it was not already labeled as such.
  2. To save the custom Investigator layout for other devices, Device Classes, or Device Categories, and/or to save the layout for all system users, click the Apply To... button, and then proceed to step 4. Otherwise, do one of the following:
  • To save the custom Investigator layout for only the current device and your user account, leave the page. When you do so, SL1 automatically saves the custom layout, and will display the custom layout when you return to the Investigator for that device.
  • To revert your Investigator layout changes to the default settings, click the Reset button.
  1. On the Apply "Custom Investigator" to... modal, use the following tabs and fields to specify the devices and users to which you want to apply the custom Investigator layout, as well as its name:
  • Categories, Classes, and Devices tabs. Click the appropriate tab(s) at the top of the modal page and then use the search field to locate the specific Device Categories, Device Classes, or individual devices to which you want to apply the custom Investigator layout. Select the checkbox for each category, class, or device that you want to select.
  • Name. Type a new name for the custom Investigator layout.
  • Apply Investigator for. Select one of the following options:
    • Myself. Applies the custom Investigator layout to only your user account.
    • All System Users. Applies the custom Investigator layout to all users in your SL1 system.
  1. Click Review. A summary of your selections appears.
  2. To confirm your selections, click Apply To Selected Types.
The Settings Tab
On the Settings tab of the Device Investigator page, you can manage your preferences for that device, such as whether to auto-clear events, accept all logs, run daily port scans, and more.
Image of the Settings tab in the Device Investigator
  • Collection Poller. Select the name of collector group you want to use for collection on this device.
  • Auto-Update. This checkbox specifies whether or not you want SL1 to perform a nightly discovery of the device and update records with changes to the device. If this field is unchecked, SL1 will not perform nightly discovery. Changes to the device, including newly opened ports, will not be recorded by SL1.
  • Scan All IPs. If the device uses multiple IP Addresses, SL1 will scan for open ports on all IPs during initial discovery and nightly discovery.
  • Enable User Maintenance. Specifies whether the device is in user maintenance mode. User maintenance is an option that allows a user to manually put a device in to "maintenance mode". During maintenance mode, for the selected devices, SL1 generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. If you select Enabled, the device is put in user maintenance mode, and the device will remain in this state until you or another user disables user maintenance mode.
  • Enable Collection During Maintenance . Specifies whether SL1 will poll the device when user maintenance mode is enabled. If you select Enabled, SL1 will continue to poll and collect data from this device during user maintenance mode.
  • Event Mask. Specify the time frame for masking events. When a device uses the Event Mask setting, SL1 groups together events that occur on that device within the specified span of time.
  • Always Create Latency Alert. Select this option to generate two alerts when availability and latency checks fail. Deselect to generate only an availability alert and suppress latency alerts.
  • Allow Events to Auto-Clear. Deselect this option to override an event policy's auto-clear setting for this device.
  • Critical Ping. Pings the device and creates an event if the device does not respond. When enabled you can select between 5 and 120 seconds.
  • Preserve Device Name. If selected, the name of the device in SL1 will remain the same, even if the name of the actual device is changed. If unselected, the SL1 name for the device will be updated if the name of the actual device is changed.
  • Disable Asset Update. If selected, SL1 will not automatically create a new asset record for the device or update the existing asset record for the device. For the single device, this checkbox over-rides any settings defined in the Asset Automation page (System > Settings > Assets).
  • Bypass Interface Inventory. Specifies whether or not the discovery session should discover network interfaces. Your options include:
  • Selected. SL1 will not attempt to discover interfaces for this device during re-discovery and nightly auto-discovery.
  • Not Selected. SL1 will attempt to discover network interfaces for this device during re-discovery and nightly auto-discovery using the Interface Inventory Timeout value and Maximum Allowed Interfaces value specified in the Device Thresholds page.
  • Dynamic Discovery. If selected, SL1 will automatically assign the appropriate dynamic applications to the device during discovery.
The Attributes Tab
On the Attributes tab of the Device Investigator, you can view a list of list of custom attributes that are already aligned with that device, and you can also add and remove extended custom attributes for the device:
For more information about this tab, see the section on Adding Custom Attributes for a Device.
The Changes Tab
On the Changes tab of the Device Investigator, you can view a list of the active and cleared change events for a device.
SL1 PowerFlow users can use the Changes tab to view a list of events that are created when PowerFlow pulls change data from ServiceNow and Restorepoint Synchronization PowerPacks.
Based on your third-party integrations, the tab displays the following information:
  • ServiceNow planned change events
  • ServiceNow emergency change events
  • Restorepoint configuration change events
The Collections Tab
For more information about this tab, see the section on Managing the Dynamic Applications Associated with a Device.
The Configs Tab
On the Configs tab of the Device Investigator, you can view configuration information that has been collected from the device by Dynamic Applications.
All objects of type "config" are included on the Configs tab. Usually, "config" objects contain static information about hardware and configuration settings, such as serial numbers, version numbers, and hardware status.
For more information about this tab, see the section on Viewing Device Configuration Data.
The Events Tab
For more information about this tab, see the section on Viewing Events for a Single Device.
The Interfaces Tab
For more information about this tab, see the section on Viewing Interfaces for a Single Device.
The Journals Tab
On the Journals tab of the Device Investigator, you can view journal entry information that has been collected from the device by journal Dynamic Applications:
The Logs Tab
You can view logs and messages for a device in the Logs tab of the Device Investigator page. This is the same set of logs that display on the Investigator tab for this device.
The Logs tab displays all of the messages SL1 and the SL1 Agent, if applicable, have collected from the device. You might find it helpful to view these log entries during troubleshooting or to manually check on the status of a device.
The Machine Learning Tab
For more information about machine learning and anomaly detection, see the section on Anomaly Detection. For more information about this tab, see the section on Enabling Machine Learning-based Anomaly Detection.
The Map Tab
For more information about maps, see the section on Maps.
The Monitors Tab
On the Monitors tab of the Device Investigator, you can define monitoring policies for a device.
The Monitors tab allows you to define policies that monitor:
  • System processes. Monitors the device and look for the specified system process. For more information, see the section on Monitoring Device Processes.
  • Domain-name availability and lookup speed. Monitors the availability and lookup time for a specific domain-name server and a specific record on a domain name server. For more information, see the section on Monitoring Domain Servers and DNS Records.
  • Email round-trip speed. Monitor the amount of time it takes to send an email message from SL1 to an external mail server and then back to SL1. For more information, see the section on Monitoring Email Round-Trips.
  • SOAP and XML transaction speeds. Monitors any server-to-server transactions that use HTTP and can post files or forms. (for example, SOAP/XML or email). Periodically, SL1 sends a request and some data and then examines the result of the transaction and compares it to a specified expression match. For more information, see the section on Monitoring SOAP and XML Transactions.
  • TCP/IP port availability. Monitors ports for availability every 5 minutes. If a port is not available, SL1 creates an event. The data gathered by the port policy is used to create port-availability reports. For more information, see the section on Monitoring Ports.
  • Web-content availability. Monitors a website for specific content. SL1 will periodically check the website for specified content. If the content cannot be found on the website, SL1 will generate an event. For more information, see the section on Monitoring Web Content.
  • Windows services. Monitors the device and look for the specified service. For more information, see the section on Monitoring Windows Services.
NOTE: All of these monitoring policies can generate events. SL1 uses the data collected by these policies to create performance reports and graphs.
The Notes Tab
On the Notes tab of the Device Investigator, you can add and view notes and other attachments associated with the device.
To add a note to a device:
  1. Go to the Notes tab of the Device Investigator.
  2. Click the Actions button and then select Notepad Editor. The Notepad Editor modal page appears.
  1. In the Notepad Editor modal page , you can enter notes or comments about the device.
  1. When you are finished adding content to the note, click Save. The note will appear in the Notes tab, along with any other notes about the device. Each note includes the username, date and time, and text of the comment. You can perform the following on each note entry:
  • To delete a note, click its bomb icon ().
The Ports Tab
On the Ports tab of the Device Investigator, you can view a list of all open ports on a device:
Every night, SL1 scans all the ports of each managed device. If any new ports are opened, SL1 adds the port to the list on the Ports tab.
For more information about this tab, see the section on Monitoring Ports.
The Processes Tab
A process is a program that is currently running on a monitored device or has been run in the past and is currently idle. Sometimes a process is called a task.
On the Processes tab of the Device Investigator, you can view information about the processes running on the device. The Processes tab displays a combined list of processes collected via SNMP and the agent, where applicable.
For more information about this tab, see the section on Monitoring Device Processes.
The Redirects Tab
On the Redirects tab of the Device Investigator, you can redirect log entries from one IP-based device to another IP-based device, or from an IP-based device to a virtual device.
For more information about this tab, see the section on Redirecting Logs from One Device to Another.
The Relationships Tab
On the Relationships tab of the Device Investigator, you can view information about parent-child relationships between the selected device and other devices.
The Schedules Tab
On the Schedules tab of the Device Investigator, you can manage all the scheduled process you have defined in your system. You can define scheduled tasks for a number of things, such as backup management, dashboards, devices, and Run Book Automation policies.
The Software Tab
  • Name. Name of the software.
For more information about this tab, see the section on Monitoring Hardware and Software.
The Thresholds Tab
On the Thresholds tab of the Device Investigator, you can define usage and performance thresholds and data retention thresholds for a device:
When performance thresholds are exceeded, SL1 will generate an event for the device. When space thresholds are exceeded, SL1 will remove the oldest data from the database. For each of these thresholds, SL1 defines a default value. You can edit the thresholds to meet your needs.
The Tickets Tab
On the Tickets tab of the Device Investigator, you can view all tickets associated with the device and create new tickets to associate with the device:
The Tickets tab displays critical information about each ticket. If you require more detail, you can access the Ticket Editor from this page by clicking on the ticketing icon () for that ticket.
You can also create a new ticket from this page.
To create a new ticket for a device:
  1. Go to the Tickets tab of the Device Investigator.
  1. Click the Actions button and then select Create a Ticket. The Ticket Editor page appears.
  2. On the Ticket Editor page that appears, define the basic parameters for the ticket. For information about the fields on this page, see the section on Creating and Editing Tickets.
The Description and Element fields are automatically populated with information about the device.
  1. When you are finished, click Save.
Assigning Icons to Devices
  2. Click the Actions button () for that item and select Assign Icon. The Select an Icon window appears:
Image of the Select an Icon window
To assign an icon to more than one device, device class, or device category, select the checkboxes to the left of those items and click Assign Icon in the blue bar at the bottom of the screen.
  1. To use an existing icon, select that icon from the list of icons and click the Select Icon button.
  1. To upload an icon from your local drive, make sure that the image file meets the following criteria:
Image of the Add an Icon window
  1. In the Icon name field, type a name for the icon you want to upload.
  2. In the Add Tags field, type a short descriptor for the icon, without spaces. You can use this tag for searching later.
  3. You can click the Browse or Drop area to browse for and select the icon, or you can drag and drop the icon file onto the Add an Icon window.
  4. Click the Add Icon button. The icon is added to the Select an Icon window.
  5. Click the Select Icon button to add the icon to the selected item.
