Monitoring Device Logs Using theSkylar One Agent
This section describes how to use the Skylar One (formerly SL1) agent to monitor logs with Log File Monitoring policies. Skylar One supports multiple methods for ingesting log data, which you can use to generate events.
  • The logs from the file or Windows log that an agent will send to Skylar One
You can create, edit, and delete Log File Monitoring policies from the Log File Monitoring Policies page (System > Manage > Log File Monitoring Policies). After creating a Log File Monitoring policy, you must align the policy to one or more devices either from the Log File Monitoring page or by using a Device Template.
You can view logs collected by the Skylar One agent on the Logs panel on the Device Investigator page for the device on which the agent is installed. The same logs also appear on the Logs tab in the Device Properties and Device Summary pages for that device. You can define event policies that specify how logs collected by an agent will trigger events.
When running the agent as a dedicated user on Windows or Linux systems, the user requires Read access to any directories being monitored. To monitor system events on Windows, the user must be in the Event Log Readers group. See Installing a Windows Agent for more information.
The Log File Monitoring Policies page (System > Manage > Log File Monitoring Policies) displays a list of all Log File Monitoring policies. From this page, you can also create, edit, and delete Log File Monitoring policies.
  • Policy ID. Unique numeric ID, automatically assigned by Skylar One to each Log File Monitoring policy.
  • Filter. The regular expression that the agent uses to determine whether a log message is sent to Skylar One.
  • Edited By. Skylar One user who created or last edited the Log File Monitoring policy.
  2. Click Create. The Log Monitoring Policy modal appears.
      • application
      • system
      • security
      • other
    • Limit. The maximum log messages the agent sends to Skylar One per minute. If the number of matching logs exceeds this value, the agent will stop sending logs to the platform for the remainder of the minute. The limit resets at the beginning of the next minute.
    • Filter. Specify a regular expression that will be used to evaluate the log messages in the specified file or Windows log. If a log message matches this regular expression, the agent will send that log message to Skylar One. If a log message does not match this regular expression, the agent will not send that log message to Skylar One.
      For Windows event logs, the Skylar One Agent adds the Event ID to the value in the Message portion of the Windows log before applying the value in the Filter field. The agent does not apply the value in the Filter field to the Instance ID or any other property of a Windows event log entry.
      Avoid adding a leading ".*" in a filter, such as ".ERROR", as that character might increase the time it takes the agent to execute the filter, and on busy Skylar One systems, that character in the filter can negatively impact the CPU.
  2. Click Create. The Log File Monitor modal appears.
  3. In the Log File Monitor modal, supply values in the following fields:
  • Limit. The maximum log messages the agent sends to Skylar One per minute. If the number of matching logs exceeds this value, the agent will stop sending logs to the platform for the remainder of the minute. The limit resets at the beginning of the next minute. For example, suppose you set this field to 10,000. Suppose the agent monitors a device that has 30,000 log messages. The agent will retrieve 10,000 logs and then wait until the beginning of the next minute. The agent will then retrieve the next 10,000 logs and then wait until the beginning of the next minute. The agent will continue to retrieve 10,000 logs per minute until it has retrieved all the logs from the device.
  • File. Specify a regular expression that will be used to evaluate the log messages in the specified file or Windows log. If and only if a log message matches this regular expression, the agent will send the log message to Skylar One.
  2. Select the checkboxes for the devices with which you want to align Log File Monitoring policies.
  3. In the Select Action drop-down list, select MODIFY by Template.
  4. Click Go. The Device Template Editor modal appears.
  5. Click the Logs tab.
  6. Click the Add New Log Policy Sub-Template icon ().
  7. Supply values in the following fields:
  5. Click Confirm. The aligned Log File Monitoring policy will appear on the Registry > Monitors > Logs page (Registry > Monitors > Logs).
  2. Click Save.
  3. In the Select Action drop-down list, select DELETE Log File Monitoring Policies.
  4. Click Go.
  • ID. The unique numeric ID of the Log File Monitoring policy. The ID is automatically assigned by Skylar One.
  • Filter. The regular expression the agent uses to determine if a log should be sent to Skylar One.
To trigger events based on log messages collected by the agent, you must create an event policy on the Event Policies page, and then associate that event policy with a Log File Monitoring policy.
If you are using the classic user interface for Skylar One, see Creating an Event Policy for Agent Logs in the Classic User Interface.
To create an event policy that triggers based on log data collected by the agent:
  1. Go to Event Policies page (Events > Event Policies).
  2. On the Event Policies page, click the Create Event Policy button. The Event Policy Editor page appears, displaying the Basic tab.
  3. On the Basic tab, define the following fields:
  • Event Policy Name. Enter a name for the event policy
  • Enable Event Policy. Select this checkbox to enable the event policy.
  • Event Source. Select ScienceLogic Agent as the source for the event. When you do so, the fields below this field will change based on your selection.
  • Log Policy. Select the Log File Monitoring Policy the agent will use to collect the log message.
  • Type of Match. Use this dropdown to select String or Regular Expression.
  • Match String. A string used to correlate the event with a log message. Can be up to 512 characters in length. To match this event policy, the text of a log message or alert must match the value you enter in this field. Can be any combination of alpha-numeric and multi-byte characters. Skylar One's expression matching is case-sensitive. This field is required for events generated with a source of Syslog, API, and Email.
  • Second Match String (Optional). A secondary string used to match against the originating log message. Can be up to 512 characters in length. Can be any combination of alpha-numeric and multi-byte characters. To match this event policy, the text of a log message or alert must match the value you enter in this field and the value you entered in the Match String field. This field is optional.
  • Event Auto Expiration. If selected, enter the time in which an active event will be cleared automatically if there is no reoccurrence of the event in the fields that appear. You can enter time in minutes or hours.
  • Multiple Matches Required to Trigger Event. If selected, enter the number of alerts and the time in which an event requires multiple triggers to occur in the fields that appear. You can enter time in minutes or hours.
  • Detection Weight. If two event definitions are very similar, this field specifies the order in which Skylar One should match messages against the similar event definitions. The event definition with the lowest weight will be matched first. This field is most useful for events that use expression matching. Options range from 0 (first) - 20 (last).
  • Multi Match.By default, Skylar One will match a log message or alert to only one event policy. If a log message or alert matches multiple event polices, Skylar One will use the Detection Weight setting to determine which event policy the log message or alert will match. If you select the Multimatch checkbox in all event policies that can match the same log message or alert, Skylar One will generate an event for every event policy that matches that single log message or alert.
  • Message Match. If Skylar One has generated an event and then a second log message or alert matches the same event policy for the same entity, Skylar One will not generate a second event, but will increase the count value for the original event on the Events page and in the Viewing Events page. By default, this behavior occurs regardless of whether the two log messages or alerts contain the same message. If you select the Message Match checkbox, this behavior will occur only if the log messages or alerts contain the same message.
  • Event Message. The message that appears in the Event Console page or the Viewing Events page when this event occurs. This field defaults to "%M" for new event policies upon creation. The message can be any combination of alphanumeric and multi-byte characters. Variables include the characters "%" (percent) and "|" (bar). You can also use regular expressions and variables that represent text from the original log message to create the Event Message:
  • To include regular expressions in the event message, surround the regular expression with %R and %/R. For example:
    %RFilename: .*? %/R
    This example would search for the first instance of the string "Filename: " (Filename-colon-space) followed by any number of any characters up to the line break. The %R indicates the beginning of a regular expression. The %/R indicates the end of a regular expression.
    Skylar One will use the regular expression to search the log message and use the matching text in the event message.
    For details on regular expression syntax, see the documentation at http://www.python.org.
  • You can also use the following variables in this field:
    • %I (capital "eye"). Depending on the context, this variable contains one of the following:
    • For events with a source of "dynamic", this variable contains the index value from SNMP; this index value will be displayed in the Event Message. For Dynamic Applications, %I maps to the raw index that comes back from SNMP. For example, a walk of the MIB at .1.3.6.1.4.1.999.3.2.1 might return the following OIDs, in which case %I would return .1.1, .2.1, and .3.1, respectively:
      1.3.6.1.4.1.999.3.2.1.1.1
      1.3.6.1.4.1.999.3.2.1.2.1,
      1.3.6.1.4.1.999.3.2.1.3.1.
    • For events with a source of "syslog" or "trap", this variable contains the value that matches the Identifier Pattern field in the Advanced tab.
    • For events with a source of "internal", this variable contains the "yName" (sub-entity name) value that matches the Identifier Pattern field in the Advanced tab.
    • %V. Data Value from log file will be displayed in the Event Message field.
  • Healthy. Healthy events indicate that a device or condition has returned to a healthy state. Frequently, a healthy event is generated after a problem has been fixed.
  • Notice. Notice events indicate a condition that does not affect service but about which users should be aware.
  • Minor. Minor events indicate a condition that does not currently impair service, but the condition needs to be corrected before it becomes more severe.
  • Major. Major events indicate a condition that impacts service and requires immediate investigation.
  • Critical. Critical events indicate a condition that can seriously impair or curtail service and requires immediate attention (i.e., service or system outages).
  • Use Interface Severity Modifier. If selected, when the event is triggered, Skylar One will check to see if the interface associated with this event has a custom severity modifier. If so, the event will appear in the Event Console with that custom severity modifier applied to the severity in the Event Severity field. For example, if an interface with an Event Severity Adjust setting of Sev -1 triggers an event with an Event Severity of Major and that event has the Use Interface Severity Modifier checkbox selected, the event will appear in the Event Console with a severity of Minor.
  1. Optionally, supply values in the other fields on this page. For more information on the remaining fields, as well as the Advanced tab, see Defining an Event Policy.
  2. Click Save.
To trigger events based on log messages collected by the agent in the classic user interface for Skylar One, you must create an event policy that is associated with a Log File Monitoring policy.
  2. In the Event Policy Manager page, click Create. The Event Policy Editor page appears.
  3. In the Event Policy Editor page and set of tabs, you can define a new event. The Event Policy Editor page contains three tabs:
    • %R. Indicates a regular expression. Surround the regular expression with %R and %/R. For example, %RFilename: .*? %/R would search for the first instance of the string "Filename: " followed by any number of any characters up to the line break. For details on the regular expression syntax allowed by Skylar One, see http://www.python.org/doc/howto/.
  • Use Modifier. If selected, when the event is triggered, Skylar One will check to see if the interface associated with this event has a custom severity modifier. If so, the event will appear in the Event Console with that custom severity modifier applied to the severity in the Event Severity field. For example, if an interface with an Event Severity Adjust setting of Sev -1 triggers an event with an Event Severity of Major and that event has the Use Modifier checkbox selected, the event will appear in the Event Console with a severity of Minor.
  1. Select the Advanced tab.
  3. Enter values in the following fields to specify specific text that must appear in the log message for the event policy to trigger:
  • First Match String. A string used to match against the originating log message. To match this event policy, the text of a log message must match the value you enter in this field. Can be any combination of alphanumeric characters. Expression matching in Skylar One is case-sensitive.
The Match Logic field specifies whether Skylar One should process First Match String and Second Match String as simple text matches or as regular expressions.
  2. Click Save.
