Installing SL1 on Hardware Appliances and Virtual Appliances
This section describes how to install SL1 on hardware Appliances or on virtual machines.
Prerequisites
To perform the steps in this section:
  • You must have already performed the prerequisites for all the ScienceLogic Hardware Appliances in your SL1 stack or for all the Virtual Appliances in your SL1 stack.
  • You must have a valid customer account that allows you to download the SL1 ISO. For details, contact your Customer Success Manager.
  • You must download the SL1 ISO.
  • Mount the SL1 ISO on each virtual appliance.
  • You must have access to the files for your SSL certificate.
  • You must have a valid customer account that allows you to access the Artifactory page on the ScienceLogic Support Site. For details, contact your Customer Success Manager.
ScienceLogic does not support vmotion or VMware Snapshots for backups of data. For backup purposes, ScienceLogic supports only SL1 backups to remote storage. vmotion andVMware Snapshots can cause SL1 outages. For details on SL1 backups, see the section on Backup Management.
Upgrading
For detailed upgrade instructions, see the section on Upgrading SL1.
Installing the Database Server
The Database Server should be the first appliance you install. To do so:
  1. Boot the appliance from the SL1 ISO. The Installation window appears.
    If you are using Hyper-V, check that the ScienceLogic installation ISO mounted correctly and that the Virtual Machine displays the install screen. To do this, right-click the Virtual Machine in inventory and select Connect or View and then Connect via Console.
  2. Select Install EM7. The Model Type window appears.
  3. Select Database. Select Continue.
  4. The Military Unique Deployment window appears. Do not select [Enable] if you are not using a Military Unique Deployment.
  5. Select Continue. The Database window appears:
  6. In the Database window, select Local Database and select Continue.
  7. After the installer for the selected appliance type is loaded, the Network Configuration window appears.
  1. Enter the following information:
  • IP Address. Type the primary IP address of the appliance.
  • Netmask. Type the netmask for the primary IP address of the appliance.
  • DNS Server. Type the IP address for the primary Nameserver.
  • Hostname. Type the hostname for the appliance.
  1. Select Continue.
  2. The System Password window appears:
  1. Type the password for the em7admin user on the operating system and select Continue.
  2. Type the password for the em7admin user again and select Continue.
  3. The appliance installer runs, and the virtual machine reboots automatically.
  4. If you are using a VMware instance, after the appliance reboots, follow the instructions to install VMware tools.
  5. If the Database Server is running a version of SL1 before 11.2.0, follow the instructions to license the appliance.
Installing the Administration Portal, Data Collector and/or Message Collector
 Starting with SL1 version 11.2.0, the installation process for SL1 Collectors was updated. For detailed procedures for installing a collector, see Installing and Configuring an SL1 Collector.
After installing the Database Server, you can next install:
  1. The Administration Portal (if applicable)
  2. The Data Collectors
  3. The Message Collectors (if applicable)
You can use the following instructions to build the Administration Portal, and one or more Data Collectors and Message Collectors.
  • Select the appropriate appliance type. Select Continue.
  • The Military Unique Deployment window appears. Do not select if you are not using a Military Unique Deployment.
  1. After the installer for the selected appliance type is loaded, the Network Configuration window appears.
  1. Select Continue.
  3. If you are using a VMware instance, after the appliance reboots, follow the instructions to install VMware tools.
  4. Follow the instructions to configure the appliance in the Web Configuration Tool.
Licensing the SL1 Appliances
For details on licensing the SL1 Appliances, see the section Licensing and Configuring an Appliance.
Additional Steps for SL1 10.1
SL1 10.1.x includes an upgrade to MariaDB. The upgrade did not include a tool, jemalloc, that helps manage memory usage.
  • 10.1.0
  • 10.1.1
  • 10.1.2
  • 10.1.3
  • 10.1.4
  • 10.1.4.1
  • 10.1.4.2
  • 10.1.5
  • 10.1.5.1
    Variable Name Value
    version_malloc_library system
  4. Search for the file /usr/lib64/libjemalloc.so.1.
    If the file does not exist, contact ScienceLogic Customer Support to request the file jemalloc-3.6.0-1.el7.x86_64.rpm.
    cd /usr/lib64
    [Service]
  7. Save and close the file.
    sudo systemctl daemon-reload
      coro_config
    2. Select 1.
      sudo touch /etc/.proc_mgr_pause
      crm resource restart mysql
      sudo rm /etc/.proc_mgr_pause
      coro_config
    8. Select 1.
    Variable Name Value
