Using the Devices Page
The Devices page allows you to view all of your managed devices in Skylar One (formerly SL1) and also run a discovery to find more devices to monitor. You can select a device from the list on the Devices page to view detailed data on the Device Investigator page for that device.
The list of devices on the Devices page matches the list of devices on the Device Manager page (Devices > Classic Devices) in the classic Skylar One user interface.
Viewing the List of All Devices
The Devices page allows you to view all of your managed devices in Skylar One. This section explains how to gather more information about a device from this page.
To navigate to the Devices page, click the Devices icon ():
The Devices page
If you do not see one of these columns, click the gear icon () and then select Column Preferences to add or remove columns. You can also drag columns to different locations on the page or click on a column heading to sort the list by the values in that column. Skylar One retains any changes you make to the columns that appear on the page and will automatically recall those changes the next time you visit the page. For more information, see the section on Editing the Settings for an Inventory Page.
By default, the Devices page footer displays the total number of devices discovered. If you apply a filter, the footer will display the total number of search returns that satisfy your filter and the total number of devices available on your machine.
For each device, the Devices page can display the following information:
If you have defined any custom attributes for your devices, you can also add those custom attributes as columns that appear on the Devices page.
Viewing Additional Data about a Device
On the Events page and the Devices page, you can click the Open icon () next to an event or device to open a Device Summary modal:
Adding Devices with Discovery
On the Devices page, you can click the Add Devices button to run a guided or unguided network discovery session, a process that searches for and adds more devices to Skylar One for monitoring.
For more information about adding devices using guided or unguided discovery, see the section on Discovering Devices.
Creating a Physical Device without Running Discovery
Skylar One (formerly SL1) allows you to manually create physical devices without running discovery. When you do so, a device record exists in Skylar One before Skylar One can communicate with the device.
In some cases, service providers find it useful to pre-populate a Skylar One system with device records but set the status of the manually created devices to Disabled. When network and firewall work are completed, the provider can then enable the devices and use discovery to keep the device data up-to-date.
You can manually create a physical device in three ways:
In the user interface, one of the places you can create a physical device without running discovery is on the Devices page. To do so, click the down arrow icon () next to the Add Devices button and then select Create Physical Device or Create Physical Device from File.
For more information, see the section Creating a Physical Device from the Devices Page.
Creating a Virtual Device
You can create a virtual device on the Devices page. To do so, click the down arrow icon () next to the Add Devices button and then select Create Virtual Device.
For more information, see the section Creating a Virtual Device from the Devices Page.
Installing an Agent
If you are using a distributed Skylar One system without the Skylar One Extended Architecture (which includes Compute Nodes, Storage Nodes, and a Management Node), you can install a Skylar One agent from the Devices page. To do so, click the down arrow next to the Add Devices button and then select Download/Install Agent.
For more information, see the section on Installing the Skylar One Agent.
Designating Favorite Devices
In Skylar One, you can select one or more devices to always display at the top of the Devices page. This process is called favoriting devices.
To make a device a favorite, click the Favorite Device star icon () to add the device to your favorites list. Click the icon () again to remove the favorite status.
With favorite devices, you can:
Aligning a Device with a Different Organization
To align a single device with a different organization:
  1. On the Devices page, click the Actions button () for the device and select Align Organization. The Align to Organization window appears.
  2. In the Align to Organization window, use the Organization drop-down to search for and select an organization.
  3. Click the Align Organization button. The organization you selected now appears in that Info drop-down on the Device Investigator page for that device.
You can also bulk-align multiple devices with an organization. For more information, see the section on Performing Bulk Actions on One or More Devices.
Assigning a New Icon to a Device
  2. Click the Actions button () for that item and select Assign Icon. The Select an Icon window appears.
  3. In the Select an Icon window, do one of the following:
    • To use an existing icon, proceed to step 7.
    • To upload a new icon from your local drive, make sure that the image file meets the following criteria, then proceed to step 4:
  1. To start the upload process, click the Add Icon button. The Add an Icon window appears.
  2. Complete the following fields in the Add an Icon window:
    • In the Icon name field, type a name for the icon you want to upload.
    • In the Add Tags field, type a short descriptor for the icon, without spaces. You can use this tag for searching later.
    • You can click the Browse or Drop area to browse for and select the icon, or you can drag and drop the icon file onto the Add an Icon window.
  3. Click the Add Icon button. The icon is added to the Select an Icon window.
  4. Select the icon from the list of icons and click the Select Icon button. The icon is assigned to the device, device class, or device category.
    You can use the Search field to search for a specific icon or narrow down the list of icons.
Deleting a Device
To delete a single device on the Devices page:
  1. On the Devices page, click the Actions button () for the device and select Delete Device.
  2. A dialog appears asking you to confirm that you want to permanently delete the device(s). To confirm, click Delete.
If you attempt to delete one or more devices that have associated asset records, you are given the option to delete those associated assets at the same time.
You can also bulk-delete multiple devices. For more information, see the section on Performing Bulk Actions on One or More Devices.
Running a Device Report
From the Devices page or from the Device Investigator page for a specific device, you can generate a detailed report for a single device. You can specify the information to include in the report and the format that Skylar One will use to generate the report, including HTML, PDF, XLS, and more.
To run a device report:
  1. Do one of the following:
    • On the Devices page, click the Actions button () for a specific device and select Device Report.
    • On the Device Investigator page for a specific device, click the Report button in the top navigation bar.
    The Device Report modal page appears.
  2. In the Type drop-down, select the type of report you want to generate. Your options include:
  1. In the Format drop-down, select the format for the report. Your options include:
Performing Bulk Actions on Multiple Devices
On the Devices page, you can select the checkboxes for one or more devices in the list and then click the Actions button to perform certain tasks on the selected devices. The following options are available when you click the Actions button:
