Using the Device Investigator
The Device Investigator page provides a view of detailed data for a specific device in Skylar One (formerly SL1). This section describes the data that can be viewed on the Device Investigator page and its various tabs.
What is the Device Investigator?
The Device Investigator displays a customizable, detailed set of data about a specific device.
From the Devices page, click the name of a particular device to open the Device Investigator page for that device.
A new metric in the Device Investigator
The tabs on the Device Investigator page provide access to all of the data associated with the device. The tabs are similar to the tabs on the Device Administration and Device Properties panels in the classic Skylar One user interface.
Only tabs relevant to the selected device are available on the Device Investigator page. For example, the Agent and Machine Learning tabs do not display if the selected device does not use agents or machine learning-based anomaly detection.
The Device Investigator page can include the following menus and buttons:
  • Info. This drawer on the Investigator tab displays additional information about the device, along with the most recently updated values for uptime and collection time.
  • Report. This button lets you generate a detailed report on the device.
  • Tools. This button opens the Activity Center, where you can run a set of diagnostic tools or user-initiated actions, or to click on custom links that will open in a separate browser window.
The Device Investigator page contains the following tabs:
  • Investigator. Displays panels that provide basic information and metric data about a device. For most devices, the default panels include a Device Overview panel, Events, Logs, Availability, and combined charts for metrics such as utilization, discards, and errors. You can customize the panel layout on this page to meet your specific business needs, including select additional metrics to display.
  • Settings. Lets you manage your preferences for that device, such as whether to auto-clear events, accept all logs, run daily port scans, and more. You can also set user maintenance preferences and disable or enable collection on that device.
  • Anomaly Detection. Displays a list of anomaly detection metrics that are enabled for the device.
  • Attributes. Lists the custom descriptive fields that are currently aligned with this device. On this tab, you can add and remove extended custom attributes to this device.
  • Changes. Displays active and cleared Change Events for a device.
  • Collections. Lets you align or un-align Dynamic Applications with this device, enable or disable collection for the Dynamic Applications, and run a Dynamic Application. You can also change credentials and update the poll frequency for a Dynamic Application.
  • Configs. Displays configuration information collected from the device by Dynamic Applications. If this device does not have any configuration data, this tab does not appear.
  • Events. Displays a list of active and cleared events for the device. You can acknowledge events from this tab and add event notes.
  • Journals. Displays journal entry information collected from the device by Dynamic Applications.
  • Logs. Displays all of the messages Skylar One and the Skylar One agent, if applicable, have collected from the device.
  • Map. Opens a map of that device and the devices it is related to (for systems that have the Maps page enabled).
  • Monitors. This tab lets you define monitoring policies for the device.
  • Notes. Displays notes and attachments associated with the device. You can also edit and create notes.
  • Performance Metrics. Displays performance graphs for hardware, monitoring policies, and Dynamic Applications aligned with the device.
  • Ports. Displays a list of all open ports on the device.
  • Processes. Displays a list of system processes running on the device.
  • Redirects. Allows you to redirect logs entries from an IP-based device to the current device. This is most useful when the current device is a virtual device, but you can also redirect log entries from one IP-based device to another IP-based device.
  • Relationships. Displays information about parent-child relationships between devices.
  • Schedules. Allows you to view and manage all the scheduled processes you have defined in your system.
  • Services. Displays a list of all Windows services enabled on the device.
  • Software. Displays a list of all the software installed on the device.
  • Summary. Displays an overview of device details through device dashboards and widgets that display various metrics.
  • Thresholds. Lets you define space and performance thresholds for a device.
  • Tickets. Displays all open, pending, or working tickets associated with the device.
  • More. This drop-down lets you select additional tabs to display on the Device Investigator page by clicking the star icon next to the tab name. You can search for specific items on a tab, such as Device Class, Uptime, or Category, and the relevant tab will appear in the search results. You can also remove a tab by clicking the star icon again, turning it from blue to white. Your tab selections are saved and remain in place even after you log out:
The More drop-down menu
Click the forward-slash button (/) to open the More drop-down. You can highlight search results using the Up and Down Arrow keys on your keyboard, and select a result by pressing Enter. To close the drop-down, click the word More.
On the Device Investigator page, you can view read-only information about the device in the Info drawer:
The Device Information tab on the Device Investigator page
  • Collector. The Collector Group that was last used to collect data from the device. For All-In-One Appliances, this field will contain the name of the default, built-in Collector Group.
  • Collecting. Indicates that the device collection is "Collecting" with a green check mark icon (), meaning Skylar One is periodically collecting data from the device, or "Not Collecting" with a prohibition icon (), meaning the Skylar One is not currently collecting data from the device.
  • Category. The device category associated with the device. The device category usually describes the primary function of the device, such as a "server", "switch", or "router".
  • Uptime. The number of days and hours that the device has been continuously up and communicating with Skylar One.
Running a Device Report
From the Devices page or from the Device Investigator page for a specific device, you can generate a detailed report for a single device. You can specify the information to include in the report and the format that Skylar One will use to generate the report, including HTML, PDF, XLS, and more.
To run a device report:
  1. Do one of the following:
    • On the Devices page, click the Actions button () for a specific device and select Device Report.
    • On the Device Investigator page for a specific device, click the Report button in the top navigation bar.
    The Device Report modal page appears.
  2. In the Type drop-down, select the type of report you want to generate. Your options include:
  1. In the Format drop-down, select the format for the report. Your options include:
Using Device Tools in the Action Runner
On the Device Investigator page, you can click the Tools menu to display the Action Runner. The Action Runner enables you to run a set of diagnostic tools or user-initiated actions, or to click on custom links that will open in a separate browser window.
NOTE: For more information about user-initiated actions, see the section on User-Initiated Automations. For more information about custom links, see the section on Custom Links.
To use the Action Runner:
  • Click Activity in the navigation bar at the top of any page in Skylar One. Click the search bar.
  1. When you click the search bar, a list appears of the default tools, actions, or custom links that are available for the selected device. Click one of these tools, actions, or custom links, or use the search bar to search for a tool or action that is not listed. The following default tools are available in the Action Runner:
  • Ping. Displays statistics returned by the ping tool. The ping tool sends a packet to the device's IP address (the one used by Skylar One to communicate with the device) and waits for a reply. Skylar One then displays the number of seconds it took to receive a reply from the device and the number of bytes returned from the device. If the device has an IPv6 address, Skylar One uses the appropriate IPv6 ping command.
  • Trace Route. Displays the network route between Skylar One and the device. The tool provides details on each hop to the endpoint. If the device has an IPv6 address, Skylar One uses the appropriate IPv6 traceroute command.
The tools found in the Action Runner can also be found in the Device Toolbox in the classic Skylar One user interface.
  1. If you clicked a custom link, the link opens in a new browser window. If you clicked on a tool or action, then as it runs, its progress and results appear in a log in the Activity Center.
The Activity Center
The following section provides an overview of how to use the tabs on the Device Investigator page for a selected device.
The Investigator Tab
The Investigator tab of the Device Investigator page displays a customizable set of metrics about the selected device.
The device type determines which metrics appear in the Investigator tab. For most devices, the following panels appear by default:
  • Device Overview. Displays a panel that includes basic information about the device, including its current state, device class, IP address, uptime, collection status, unacknowledged event count, Skylar AI insights, automated actions count, and configuration changes count.
    Beginning with AP2 8.34.20 (Opera Cake), the device's Skylar AI insights count displays the sum of all open root cause analysis events (accepted, suggested, or custom) plus all open anomaly index score events plus all open predictive alert events.
  • If your device has Skylar Automated RCA suggestions, custom alerts, or accepted alerts, you can click the VIEW link on the banner that appears at the top of the Device Investigator page to go to the Events tab for that device to review the Skylar Automated RCA content.
    From the Event Investigator or Service Investigator pages, if you click the name of the device where an event has occurred, you are redirected to the Device Investigator page for that device, with an event context panel displaying at the top of the page. From this panel, you can acknowledge, clear, or view causes and resolutions relating to that specific event.
  • Logs. Displays a panel with a list of the logs for the device, sorted from newest to oldest by default. You can use the Search field to search device logs for specific event messages, event IDs, date ranges, source types, and other relevant text for troubleshooting. You can also click on the column headers for Date/Time, Source, Event ID, Severity, and Message to sort by that column.
  • Relationships and Membership. Displays a panel that includes details about the other devices that have relationships to the selected device, as well as the device groups and services to which the device belongs or has membership.
    • The Device Relationship tab displays the name, relationship type, relationship discovery method, and health for each device that has a relationship with the selected device. You can click the hyperlink in the Device Name column to go to the Device Investigator for the related device.
    • The Device Groups tab displays the name, device count, and ID for each device group to which the selected device belongs or has membership.
    • The Services tab displays the name, type, status, description, health, availability, and risk for each service to which the selected device belongs or has membership. You can click the hyperlink in the Service Name column to go to the Service Investigator for the related service.
  • Map. Displays a panel with a map of the device and all of the devices with which the device has relationships. You can also click the Map panel heading to go to the Map tab for that device. This panel is disabled by default, but can be enabled by clicking the Edit button, and then selecting the Map checkbox.
You can customize the appearance of the widgets on the page, including changing their height or width. For more information, see the section on Customizing the Appearance of Widgets on the Investigator Tab.
The Device Investigator page also includes the following sidebar buttons:
Select the Always display raw data checkbox at the top of the timespan selector to ensure that the metric data that appears in the panels on the Investigator tab always includes the most recent data available. If you do not select that checkbox, Skylar One will still display raw data when you select a timespan of less than 2 days, but will automatically display rolled up hourly data for timespan selections of 2-45 days and rolled up daily data for timespan selections of more than 45 days.
You can view Skylar Automated RCA suggestions and alerts in the A.I./M.L. section of the Device Overview pane and the Events pane of the Investigator tab. For Skylar One 12.2.0 and later, you will need to set up the connection between Skylar Automated RCA and Skylar One. For more information, see Configuring the Skylar Automated RCA Connector for Skylar One.
The Investigator tab panel layout is responsive. Panels are automatically resized or relocated whenever you add or remove a pane, rearrange the panels on the page, or change the size of the the browser window.
You can customize a widget's appearance on the Investigator tab by clicking the menu icon () for that widget and then doing one of the following:
  • To change the widget's name, select Edit Widget Name and then enter a new name.
  • To change the widget's height, select Small, Medium, or Large.
  • To change the widget's width, select either Columns or Full width.
You can also click the contract icon () in the widget header to display only the header or click the expand icon () to display the widget's full contents.
For leaderboard widgets for interfaces, file systems, and Dynamic Applications, you can click the Leaderboard Bar Chart icon () to switch from a bar chart to a line chart, or click the Line Chart icon () to switch from a line chart to a leaderboard bar chart.
Optionally, you can add metrics to the Investigator tab for Dynamic Applications, interfaces, and the Skylar One Agent (if applicable), among other things. You can also remove metrics from the Investigator tab.
  1. To add a metric panel that is not currently on the Investigator tab, click the Edit button on the right sidebar to expand the layout panel, click Edit Panels, and then click the Add a metric field. A list of metrics appears:
  2. Select a metric from the list, or type the name of a metric and select it from the list. The metric is added to the right pane, and a corresponding widget appears in the left pane.
  3. Some metrics might require you to make additional selections, such as the network interfaces associated with a device. Click the field and add one or more additional metrics, as needed.
  4. To remove a metric panel from the Investigator tab, uncheck the corresponding box in the right panel. The metric remains listed in the right panel, but the panel is removed from the Investigator tab.
  5. To completely remove the metric and its corresponding panel from the Investigator tab, click the Remove from Layout button (Image of the Close button) for that metric in the right panel.
The Investigator tab retains any changes you made to the set of device metrics displayed for each device, on a per-user basis. To reset these changes to their default settings, click the Reset button at the bottom of the right panel. Optionally, you can apply these changes to other Device Categories, Device Classes, or devices. For more information, see the section on Applying a Custom Device Investigator Layout to Other Devices.
On the Investigator tab of the Device Investigator page, the order in which the metric panels appear in the right panel when you click the Edit button mirrors the order in which the corresponding metric panel widgets appear in the left panel. You can drag and drop the panels up or down in the right panel to edit the order in which the metric panels appear on the left panel. This enables you to prioritize the information that appears on the page.
  1. On the Investigator tab of the Device Investigator page, click the Edit button on the right sidebar to expand the layout panel and then click Edit Panels.
  2. Hover your mouse over the "Panel" heading of the panel that you want to move until you see an open hand icon appear.
  3. Click and hold down the left button on your mouse to grab the panel, and then use your mouse to drag the panel to a different location in the list. When you do so, the open hand icon becomes a closed hand icon, and a blue dotted box appears around the panel.
  4. Release the left mouse button to drop the panel in your desired location. The new right-hand panel order will be reflected in the left-hand widget panel.
On the Investigator tab of the Device Investigator page, you can combine charts for different time-series metrics to see all of the combined data for those metrics in a single chart.
To combine charts:
  1. On the Investigator tab of the Device Investigator page, click the Edit button on the right sidebar to expand the layout panel, and then click Edit Panels.
  3. Click and hold down the left button on your mouse to grab the metric, and then use your mouse to drag the metric into the panel of a different time-series metric in the list. When you do so, the open hand icon becomes a closed hand icon, and the panel containing the combined metrics turns blue.
  4. Release the left mouse button to drop the metric into the desired panel. The newly combined metric panel will be reflected in a "Combined Charts" widget in the left-hand widget panel.
The device Investigator tab has a default layout that includes Device Overview, Events, and Logs widgets. Initially, this layout is assigned to all devices.
You can also create custom Investigator tab layouts and apply those layouts to individual devices, entire device classes, or entire device categories, and then apply those updates either to only yourself or to all system users.
To apply a custom device Investigator layout to other devices:
  1. On the Investigator tab of the Device Investigator page, click the Edit button on the right sidebar to expand the layout panel. When you do so, the Investigator tab name will appear at the top of the layout panel, along with one of the following labels:
  • Default. Indicates the layout has not been changed from the default settings.
  • Private. Indicates the layout has been changed from the default settings but only applied to the logged in user.
  • Public. Indicates the layout has been changed from the default settings and has been applied to all system users.
  1. From this panel, you can do one or more of the following:
Creating a New Custom Investigator Layout
To create a new custom device Investigator layout:
  2. Make updates to the Investigator layout as needed, such as by adding or removing metrics, editing the metric panel order, or combining one or more charts into a single panel. When you do so, the label at the top of the layout panel will change to "Private", if it was not already labeled as such.
  3. To save the custom Investigator layout for other devices, device classes, or device categories, and/or to save the layout for all system users, click the Apply To... button, and then proceed to step 4. Otherwise, do one of the following:
  • To save the custom Investigator layout for only the current device and your user account, leave the page. When you do so, Skylar One automatically saves the custom layout, and will display the custom layout when you return to the Investigator for that device.
  • To revert your Investigator layout changes to the default settings, click the Reset button.
  1. On the Apply "Custom Investigator" to... modal, use the following tabs and fields to specify the devices and users to which you want to apply the custom Investigator layout, as well as its name:
  • Categories, Classes, and Devices tabs. Click the appropriate tab or tabs at the top of the modal page and then use the search field to locate the specific Device Categories, Device Classes, or individual devices to which you want to apply the custom Investigator layout. Select the checkbox for each category, class, or device that you want to select.
  • Name. Type a new name for the custom Investigator layout.
  • Apply Investigator for. Select one of the following options:
    • Myself. Applies the custom Investigator layout to only your user account.
    • All System Users. Applies the custom Investigator layout to all users in your Skylar One system.
  1. Click Review. A summary of your selections appears.
  2. To confirm your selections, click Apply To Selected Types.
Selecting an Existing Custom Device Investigator Layout
To select an existing custom device Investigator layout:
  1. On the Investigator tab of the Device Investigator page, click the Edit button on the right sidebar to expand the layout panel and then click Choose Layout. The Choose Layout tab displays a list of Investigator layouts that you have access to or own.
  2. Click the radio button for the layout that you want to select. When you do, the Investigator page automatically updates to use that layout.
You can also bulk-align device Investigator layouts to multiple devices. For more information, see the section on Performing Bulk Actions on One or More Devices.
Managing Custom Device Investigator Layouts
You can view and manage the list of custom device Investigator layouts that you own or have access to on the Device Investigator Layouts page.
To view the Device Investigator Layouts page, your user account must be aligned to an access key that includes the DEV_VIEW access hook. To delete layouts from this page, your user account must have an access key that includes the DEVICE_INVESTIGATOR_REMOVE or DEVICE_DASH_EDIT access hooks.
To manage the list of custom device Investigator layouts:
  1. Go to the Device Investigator Layouts page (Devices > Device Investigator Layouts).
    You can also access this page by from the Investigator tab of the Device Investigator page by clicking the Edit button on the right sidebar and then clicking Choose Layout > Manage Layouts.
  2. For each layout, the following information displays:
    • Layout Name. The name assigned to the layout. This name displays as a hyperlink. Click the hyperlink to view or update the list of devices, device classes, and device categories to which the layout is aligned.
    • ID. The unique ID for the layout, generated by Skylar One.
    • Owner. The owner of the layout. Typically, the creator of the layout is the owner.
    • Categories. The number of device categories aligned to the layout.
    • Classes. The number of device classes aligned to the layout.
    • Devices. The number of devices aligned to the layout.
    • Alignment Last Edited By. The user who configured or last edited the layout alignment.
    • Alignment Last Edited. The date and time the layout alignment was configured or last edited.
  3. From the Device Investigator Layouts page, you can take the following actions:
    • You can view or edit the device, device class, or device category alignment for layouts that you own. Proceed to steps 4-7.
    • You can delete layouts that you own. When you do so, any devices that are currently using the selected layouts will default to the next applicable layout. Proceed to steps 8-9.
  4. To view or update the list of devices, device classes, and device categories to which a layout is aligned, click the hyperlink in the Layout Name field for that layout on the Device Investigator Layouts page. On the layout page that appears, you can click the Categories, Classes, and Devices tabs to view the layout's current alignments in read-only format.
  5. To update the layout's current alignments, click Edit and then select the checkbox next to any device category, device class, or device that you want to align to the selected layout.
    You can select the checkbox at the top of the table to select all of the rows in that table.
  6. If you are the layout owner and you want to edit the layout's name, click its name at the top of the page and then type a new name.
  7. To save your changes, click Save.
  8. To delete one or more layouts that you own, select their checkboxes on the Device Investigator Layouts page and then click Delete Layouts. When you do so, a warning appears informing you that any devices that are currently using the selected layouts will default to the next applicable layout.
  9. To confirm that you want to delete the selected layouts, click Delete.
The Settings Tab
On the Settings tab of the Device Investigator page, you can manage your preferences for that device, such as whether to auto-clear events, accept all logs, run daily port scans, and more.
The Settings tab in the Device Investigator
  • Disk Space. Specify the amount of disk space in MB that the agent can use to store data. If the agent loses connectivity to Skylar One, this disk space will be used to store collected data until the connection to Skylar One is restored. When connectivity is re-established, the agent uploads all of its stored data.
  • 60 Seconds. Upload a data summary every 60 seconds. This is the default setting starting with Skylar One version 11.1.0, and version 174 of the Linux agent and version 133 for the Windows agent. This option uses an improved data format that requires fewer Skylar One resources. The Skylar One agent continues to internally collect and poll data every 20 seconds, but the agent summarizes and uploads that data every 60 seconds. There is no data loss even though the data is uploaded less frequently.
    Starting with Skylar One version 11.3.0, if you specify 60 seconds for the upload interval, the summary upload now will include "watched" or "monitored" files, just like the snapshot upload does.
  • Collection Poller. Select the name of collector group you want to use for collection on this device.
  • Auto-Update. This checkbox specifies whether or not you want Skylar One to perform a nightly discovery of the device and update records with changes to the device. If this field is unchecked, Skylar One will not perform nightly discovery. Changes to the device, including newly opened ports, will not be recorded by Skylar One.
  • Scan All IPs. If the device uses multiple IP Addresses, Skylar One will scan for open ports on all IPs during initial discovery and nightly discovery.
Set the following Topolgy preferences:
The following topology-related fields are available if you have installed AP2 8.29.41 (Nougat) or later.
The device's topology settings are initially inherited from the system-wide topology settings that are set on the Behavior Settings page (System > Settings > Behavior), or from the topology settings for the device's class. However, you can change these settings on a per-device basis by editing one or more of the fields below. For more information about the system-wide topology settings, see the section on Global Settings for System Behavior. For more information about the device class topology settings, see the section on Device Classes and Device Categories.
  • L2. Select the Override checkbox to override the system-wide Layer-2 topology settings that are set on the Behavior Settings page (System > Settings > Behavior). When selected, this field becomes editable, and you can select from the following options:
    • Disabled. Disables Layer-2 topology collection and processing for the device.
    • Processing Enabled. Enables Layer-2 topology processing for the device using the "Enterprise Database: Topology Crunch" process to determine Layer-2 topology relationships based on device category and connects network devices to each other using methods other than the standard SNMP protocol for collection.
    • Collection and Processing Enabled. Enables Layer-2 topology collection and processing for the device using the standard SNMP collection methods and the "Enterprise Database: Topology Crunch" process to determine Layer-2 topology relationships based on device category, with the purpose of connecting network devices to each other.
    • Enhanced Processing Enabled. Enables advanced Layer-2 topology processing for the device, but using methods other than the standard SNMP for collection. This enhanced processing can form Layer-2 relationships between any devices that match a MAC address from the BRIDGE-MIB or sourced from Dynamic Applications, regardless of device category.
    • Collection and Enhanced Processing Enabled. Enables advanced Layer-2 topology processing and collection for the device using the standard SNMP collection methods. This enhanced processing can form Layer-2 relationships between any devices that match a MAC address from the BRIDGE-MIB or sourced from Dynamic Applications, regardless of device category.
  • L3. Select the Override checkbox to override the system-wide Layer-3 topology settings that are set on the Behavior Settings page (System > Settings > Behavior). When selected, this field becomes editable, and you can select from the following options:
    • Disabled. Disables Layer-3 topology collection and processing for the device.
    • Processing Enabled. Enables Layer-3 topology processing for the device using the "Enterprise Database: Topology Crunch" process to determine Layer-3 topology relationships. This option requires all hops in a traceroute to respond and match devices within Skylar One to form the relationship.
    • Collection and Processing Enabled. Enables Layer-3 topology collection and processing for the device using the "Enterprise Database: Topology Crunch" process to determine Layer-3 topology relationships. This option requires all hops in a traceroute to respond and match devices within Skylar One to form the relationship.
    • Enhanced Processing Enabled. Enables advanced Layer-3 topology processing for the device, where the system forms relationships between any two hops that respond and match devices in Skylar One rather than discarding incomplete traceroutes or results that include unmatched hops.
    • Collection and Enhanced Processing Enabled. Enables advanced Layer-3 topology processing and collection for the device, where the system forms relationships between any two hops that respond and match devices in Skylar One rather than discarding incomplete traceroutes or results that include unmatched hops.
  • CDP. Select the Override checkbox to override the system-wide Cisco Discover Protocol (CDP) topology settings that are set on the Behavior Settings page (System > Settings > Behavior). When selected, this field becomes editable, and you can select from the following options:
    • Disabled. Disables CDP topology collection and processing for the device.
    • Processing Enabled. Enables CDP topology processing for the device using the "Enterprise Database: Topology Crunch" process to determine CDP topology relationships between two devices that both respond with CDP neighbor data, show each other as neighbors, and are managed devices in Skylar One. This option uses methods other than standard SNMP for collection.
    • Collection and Processing Enabled. Enables CDP topology collection and processing for the device using standard SNMP collection methods and the "Enterprise Database: Topology Crunch" process to determine CDP topology relationships between two devices that both respond with CDP neighbor data, show each other as neighbors, and are managed devices in Skylar One.
    • Enhanced Processing Enabled. Enables advanced CDP topology processing for the device, but using methods other than standard SNMP for collection. This advanced processing can form CDP relationships between two devices if at least one of those devices responds with CDP neighbor data and is a managed device in Skylar One.
    • Collection and Enhanced Processing Enabled. Enables advanced CDP topology processing and collection for the device using standard SNMP collection methods. This enhanced processing can form CDP relationships between two devices if at least one of those devices responds with CDP neighbor data and is a managed device in Skylar One.
  • LLDP. Select the Override checkbox to override the system-wide Link Layer Discovery Protocol (LLDP) topology settings that are set on the Behavior Settings page (System > Settings > Behavior). When selected, this field becomes editable, and you can select from the following options:
    • Disabled. Disables LLDP topology collection and processing for the device.
    • Processing Enabled. Enables LLDP topology processing for the device using the "Enterprise Database: Topology Crunch" process to determine LLDP topology relationships between two devices that both respond with LLDP neighbor data, show each other as neighbors, and are managed devices in Skylar One. This option uses methods other than standard SNMP for collection.
    • Collection and Processing Enabled. Enables LLDP topology collection and processing for the device using standard SNMP collection methods and the "Enterprise Database: Topology Crunch" process to determine LLDP topology relationships between two devices that both respond with LLDP neighbor data, show each other as neighbors, and are managed devices in Skylar One.
    • Enhanced Processing Enabled. Enables advanced LLDP topology processing for the device, but using methods other than standard SNMP for collection. This enhanced processing can form LLDP relationships between two devices so long as at least one of those devices responds with LLDP neighbor data and is a managed device in Skylar One.
    • Collection and Enhanced Processing Enabled. Enables advanced LLDP topology processing and collection for the device, using the standard SNMP collection methods. This enhanced processing can form LLDP relationships between two devices so long as at least one of those devices responds with LLDP neighbor data and is a managed device in Skylar One.
  • Enable User Maintenance. Specifies whether the device is in user maintenance mode. User maintenance is an option that allows a user to manually put a device in to "maintenance mode". During maintenance mode, for the selected devices, Skylar One generate only events with a severity less than the system-wide Maintenance Minimum Severity setting. If you select Enabled, the device is put in user maintenance mode, and the device will remain in this state until you or another user disables user maintenance mode.
  • Enable Collection During Maintenance . Specifies whether Skylar One will poll the device when user maintenance mode is enabled. If you select Enabled, Skylar One will continue to poll and collect data from this device during user maintenance mode.
  • Event Mask. Specify the time frame for masking events. When a device uses the Event Mask setting, Skylar One groups together events that occur on that device within the specified span of time.
  • Always Create Latency Alert. Select this option to generate two alerts when availability and latency checks fail. Deselect to generate only an availability alert and suppress latency alerts.
  • Allow Events to Auto-Clear. Deselect this option to override an event policy's auto-clear setting for this device.
  • Critical Ping. Pings the device and creates an event if the device does not respond. When enabled you can select between 5 and 120 seconds.
  • Daily Port Scans. This checkbox specifies whether or not you want Skylar One to perform a daily scan of the device for open ports.
  • Preserve Device Name. If selected, the name of the device in Skylar One will remain the same, even if the name of the actual device is changed. If unselected, the Skylar One name for the device will be updated if the name of the actual device is changed.
  • Disable Asset Update. If selected, Skylar One will not automatically create a new asset record for the device or update the existing asset record for the device. For the single device, this checkbox over-rides any settings defined in the Asset Automation page (System > Settings > Assets).
  • Bypass Interface Inventory. Specifies whether or not the discovery session should discover network interfaces. Your options include:
  • Selected. Skylar One will not attempt to discover interfaces for this device during re-discovery and nightly auto-discovery.
  • Not Selected. Skylar One will attempt to discover network interfaces for this device during re-discovery and nightly auto-discovery using the Interface Inventory Timeout value and Maximum Allowed Interfaces value specified in the Device Thresholds page.
  • Dynamic Discovery. If selected, Skylar One will automatically assign the appropriate dynamic applications to the device during discovery.
The Anomaly Detection Tab
On the Anomaly Detection tab of the Device Investigator, you can view a list of anomaly detection metrics that are enabled for the device.
The Machine Learning tab of the Device Investigator page
For more information about this tab, see the section on Enabling Anomaly Detection Events on the Device Investigator Page.
The Attributes Tab
On the Attributes tab of the Device Investigator, you can view a list of list of custom attributes that are already aligned with that device, and you can also add and remove extended custom attributes for the device:
The Attribute tab of the Device Investigator
For more information about this tab, see the section on Adding Custom Attributes for a Device.
The Changes Tab
On the Changes tab of the Device Investigator, you can view a list of the active and cleared change events for a device.
The Changes tab of the Devices page
Skylar One PowerFlow users can use the Changes tab to view a list of events that are created when PowerFlow pulls change data from ServiceNow and Restorepoint SyncPacks.
Based on your third-party integrations, the tab displays the following information:
  • ServiceNow planned change events
  • ServiceNow emergency change events
  • Restorepoint configuration change events
About the Changes Widget
The Changes tab uses data from the Changes widget, which is also used on the Service Investigator page to show change events for Business Services.
The Changes widget is available to customers who have purchased Configuration and Change Management as part of their Skylar One Standard or Premium subscription. This widget displays a list of events that are created when PowerFlow pulls change data from ServiceNow or Restorepoint, including both active and cleared change events.
The Changes widget tile displays the number of active change events that are impacting the service. Events on the widget will automatically clear after 30 minutes.
  • Use the drop-down menu to choose which type of change events display in the widget: Active Events or Cleared Events.
  • Filter and search for events by their date; either by 5, 7, 14, 30 days, or more than 30 days.
  • For active events that are aligned to devices, click the down-arrow icon () next to the event to open the Event Drawer panel, which displays the following panes:
  • Vitals. A widget displaying the past 24 hours of CPU and memory usage for the device related to the event. You can zoom in on a shorter time frame by clicking and dragging, and you can go back to the original timespan by clicking the Reset zoom button.
  • Tools. A set of network diagnostic tools or user-initiated actions that you can run on the device associated with the event. Click the search bar to search for a tool or action to run, or click one of the default tools or actions that are available based on the device type and your user permissions.
  • View the Service Investigator or Device Investigator page for the service or device aligned with an active event by clicking the link in the Name column.
  • View the Event Investigator page for an active event by clicking the link in the Message column.
  • For ServiceNow integrations, view the ServiceNow ticket associated with an active event by clicking the link in the Ticket External Reference column.
  • For ServiceNow integrations, view the ServiceNow ticket associated with a cleared event by clicking the link in the External Ticket column.
  • Select multiple active events for action using the check boxes next to the events.
Configuring and Enabling the Changes Widget
To use the Changes widget, you must first configure and enable the widget. To do so, perform the following steps:
  1. Ensure that you are running Skylar One version 11.2.0 or later and have Business Services Base Pack PowerPack version 2.2.0 or later installed in Skylar One. For more information, see the section on Installing a PowerPack.
  2. Ensure that you are running Skylar One PowerFlow Platform version 2.2.2 or greater and one or more of the following PowerPacks, depending on your integration:
  • ServiceNow CMDB SyncPack version 3.2.0 or later installed in PowerFlow. For more information, see the section on the ServiceNow CMDB SyncPack.
  • ServiceNow Change Management SyncPack version 3.2.1 or later installed in PowerFlow. For more information, see the section on the ServiceNow Change Management SyncPack.
  • For a Restorepoint integration:
  • Restorepoint SyncPack version 1.2.0 or later installed in PowerFlow.
  • Restorepoint PowerPack version 102 or later installed in Skylar One.
  • Restorepoint Automation PowerPack version 102 or later installed in Skylar One. For more information, see the section on Restorepoint Integrations.
  1. In Skylar One, create a SOAP/XML credential to connect with PowerFlow and make note of its credential ID.
    1. In PowerFlow, sync Skylar One devices with ServiceNow and make note of the Configuration field value in the Sync Devices from Skylar One to ServiceNow application.
    2. In Skylar One, open the "ServiceNow: Send Change Request Event to PowerFlow" Run Book Action (which is included in the Business Services Base Pack PowerPack v2.1 and greater) and edit the input parameters to include the credential ID from step 3 and the Configuration field value from step 4.
  3. For a Restorepoint integration, follow the steps in sync Skylar One devices with Restorepoint in PowerFlow.
Creating a SOAP/XML Credential for Skylar Automation (PowerFlow)
To create a SOAP/XML credential to connect Skylar One with Skylar Automation (PowerFlow):
  1. Follow the steps in the section Creating a SOAP/XML Credential for Skylar Automation.
  2. After saving the credential, make note of the credential ID. This number can be found at the top of the Edit SOAP/XML Credential modal or in the ID column on the Credentials page (Manage > Credentials) or Credential Management page (System > Manage > Credentials).
Syncing Skylar One Devices with ServiceNow
To sync Skylar One devices with ServiceNow:
  1. Follow the steps in the section Running a Device Sync.
  2. In the Configuration pane of the "Sync Devices from Skylar One to ServiceNow" application, make note of the value in the Configuration field.
Editing the Run Book Action (ServiceNow Integrations only)
To edit the input parameters in the "ServiceNow: Send Change Request Event to PowerFlow" run book action:
  2. Locate the "Business Services Base Pack" PowerPack and click its wrench icon (). The Editing PowerPack modal appears.
  3. In the Editing PowerPack modal, click Run Book Actions in the left Navbar. The Embedded Run Book Actions page appears in the modal.
  4. Click the wrench icon () for the "ServiceNow: Send Change Request Event to PowerFlow" run book action. The Policy Editor modal appears.
  1. Click Save, then exit the Policy Editor modal.
  2. Exit the Editing PowerPack modal.
Syncing Skylar One Devices with Restorepoint
To sync Skylar One devices with Restorepoint:
  2. In PowerFlow, open the Configuration pane for the "Restorepoint: Sync Devices" application and select Enable for the restorepoint_config field to allow device change detection.
  3. Make a note of the restorepoint_id value on the Configuration pane for the "Restorepoint: Sync Devices" application.
  4. In Skylar One, go to the Device Investigator page for the devices synced from Restorepoint, click on the Attributes tab, and ensure that the same restorepoint_id value was added to the Values column.
To permanently enable the Changes widgetusing the NextUI configuration file, run the following steps on all appliances, including the Administration Portal, the Data Collector, the Database Server, the Data Engine, and the All-In-One Appliance.
To permanently enable the Changes widget:
  1. Start an SSH session into one of the Skylar One appliances.
  2. Using vi or another text editor, edit the /opt/em7/nextui/nextui.conf file. To do so, enter the following at the shell prompt:
  4. Save your changes, and then restart the NextUI service by running the following command:
    sudo systemctl restart nextui
  5. Repeat steps 1-4 for the remaining Skylar One appliances.
To temporarily enable the Changes widget using GraphQL:
  1. To access the GraphiQL interface, type the URL or IP address for Skylar One in a browser, add /gql to the end of the URL or IP address, and press Enter. The GraphiQL interface appears.
    	updateFeatureToggle(
    		value: "enabled"
    		id
    		value
    Click the Prettify button to format the mutation and to add syntax highlighting to make the mutation easier to read. Note that the Prettify process removes the query syntax if only one query is present in the main query pane.
    If the Changes widget does not appear in Skylar One after executing the mutation, refresh the page using the F5 key or by clicking the refresh button in your web browser.
The Collections Tab
The Collections tab of the Device Investigator
For more information about this tab, see the section on Managing the Dynamic Applications Associated with a Device.
Even if you turn off data collection for a device, that device still consumes a single ScienceLogic device license. For more information, see the Non-billable Devices section.
The Configs Tab
On the Configs tab of the Device Investigator, you can view configuration information that has been collected from the device by Dynamic Applications. You can also view a list of all changes that occurred with a Dynamic Application between two specific snapshot reference points.
All objects of type "config" are included on the Configs tab. Usually, "config" objects contain static information about hardware and configuration settings, such as serial numbers, version numbers, and hardware status.
You can also see all changes between two snapshots of a Dynamic Application in the Configs tab of the Device Investigator page. For more information, see the the section on Viewing Device Snapshot Data.
For more information about this tab, see the section on Viewing Device Configuration Data.
The Events Tab
The Events tab of the Device Investigator page
For more information about this tab, see the section on Viewing Events for a Single Device.
The Interfaces Tab
The Interfaces tab of the Device Investigator page
For more information about this tab, see the section on Viewing Interfaces for a Single Device.
The Journals Tab
On the Journals tab of the Device Investigator, you can view journal entry information that has been collected from the device by journal Dynamic Applications.
For more information about this tab, see the section on Viewing Device Journal Data.
The Logs Tab
You can view logs and messages for a device in the Logs tab of the Device Investigator page. This is the same set of logs that display on the Investigator tab for this device.
The Logs tab of the Device Investigator page
The Logs tab displays all of the messages Skylar One and the Skylar One Agent, if applicable, have collected from the device. You might find it helpful to view these log entries during troubleshooting or to manually check on the status of a device.
For more information about machine learning and anomaly detection, see the section on Anomaly Detection. For more information about this tab, see the section on Enabling Machine Learning-based Anomaly Detection.
The Map Tab
The Map tab of the Device Investigator page
For more information about this tab, see the section on Viewing Device Topology settings. For more information about maps, see the section on Maps.
The Monitors Tab
On the Monitors tab of the Device Investigator, you can define monitoring policies for a device.
The Monitors tab of the Device Investigator page
The Monitors tab allows you to define policies that monitor:
  • System processes. Monitors the device and look for the specified system process. For more information, see the section on Monitoring Device Processes.
  • Domain-name availability and lookup speed. Monitors the availability and lookup time for a specific domain-name server and a specific record on a domain name server. For more information, see the section on Monitoring Domain Servers and DNS Records.
  • Email round-trip speed. Monitor the amount of time it takes to send an email message from Skylar One to an external mail server and then back to Skylar One. For more information, see the section on Monitoring Email Round-Trips.
  • SOAP and XML transaction speeds. Monitors any server-to-server transactions that use HTTP and can post files or forms. (for example, SOAP/XML or email). Periodically, Skylar One sends a request and some data and then examines the result of the transaction and compares it to a specified expression match. For more information, see the section on Monitoring SOAP and XML Transactions.
  • TCP/IP port availability. Monitors ports for availability every 5 minutes. If a port is not available, Skylar One creates an event. The data gathered by the port policy is used to create port-availability reports. For more information, see the section on Monitoring Ports.
  • Web-content availability. Monitors a website for specific content. Skylar One will periodically check the website for specified content. If the content cannot be found on the website, Skylar One will generate an event. For more information, see the section on Monitoring Web Content.
  • Windows services. Monitors the device and look for the specified service. For more information, see the section on Monitoring Windows Services.
NOTE: All of these monitoring policies can generate events. Skylar One uses the data collected by these policies to create performance reports and graphs.
The Notes Tab
On the Notes tab of the Device Investigator, you can add and view notes and other attachments associated with the device.
To add a note to a device:
  1. Go to the Notes tab of the Device Investigator.
  2. Click the Actions button and then select Notepad Editor. The Notepad Editor modal page appears.
  3. In the Notepad Editor modal page , you can enter notes or comments about the device.
  1. When you are finished adding content to the note, click Save. The note will appear in the Notes tab, along with any other notes about the device. Each note includes the username, date and time, and text of the comment. You can perform the following on each note entry:
  • To delete a note, click its delete icon ().
For information about adding a note to a device in the classic Skylar One user interface, see the section on Adding a Note in the Device Administration Panel.
The Performance Metrics Tab
On the Performance Metrics tab of the Device Investigator, you can view performance graphs for hardware, monitoring policies, and Dynamic Applications aligned with the device.
For more information about this tab, see the section on Viewing Performance Graphs.
The Ports Tab
On the Ports tab of the Device Investigator, you can view a list of all open ports on a device:
The Ports tab of the Device Investigator page
Every night, Skylar One scans all the ports of each managed device. If any new ports are opened, Skylar One adds the port to the list on the Ports tab.
For more information about this tab, see the section on Monitoring Ports.
The Processes Tab
A process is a program that is currently running on a monitored device or has been run in the past and is currently idle. Sometimes a process is called a task.
On the Processes tab of the Device Investigator, you can view information about the processes running on the device. The Processes tab displays a combined list of processes collected via SNMP and the agent, where applicable.
The Processes tab of the Device Investigator page
For more information about this tab, see the section on Monitoring Device Processes.
The Redirects Tab
On the Redirects tab of the Device Investigator, you can redirect log entries from one IP-based device to another IP-based device, or from an IP-based device to a virtual device.
The Redirects tab of the Device Investigator page
For more information about this tab, see the section on Redirecting Logs from One Device to Another.
The Relationships Tab
On the Relationships tab of the Device Investigator, you can view information about parent-child relationships between the selected device and other devices.
For more information about this tab, see the section on Viewing Relationships for a Single Device.
The Schedules Tab
On the Schedules tab of the Device Investigator, you can manage all the scheduled process you have defined in your system. You can define scheduled tasks for a number of things, such as backup management, dashboards, devices, and Run Book Automation policies.
For more information about this tab, see the section on Scheduling Maintenance for a Single Device.
The Services Tab
On the Services tab of the Device Investigator, you can view a list of all Windows services enabled on the device.
For more information about this tab, see the section on Viewing a List of Windows Services on a Single Device.
The Software Tab
The Software tab of the Device Investigator page
  • Name. Name of the software.
For more information about this tab, see the section on Monitoring Hardware and Software.
The Summary Tab
On the Summary tab of the Device Investigator, you can view an overview of device details through device dashboards and widgets that display various metrics.
For more information about this tab, see the section on The Default Device Summary Page.
The Thresholds Tab
On the Thresholds tab of the Device Investigator, you can define usage and performance thresholds and data retention thresholds for a device.
The Thresholds tab of the Device Investigator page
When performance thresholds are exceeded, Skylar One will generate an event for the device. When space thresholds are exceeded, Skylar One will remove the oldest data from the database. For each of these thresholds, Skylar One defines a default value. You can edit the thresholds to meet your needs.
For more information about this tab, see the section on Device Thresholds.
The Tickets Tab
On the Tickets tab of the Device Investigator, you can view all tickets associated with the device and create new tickets to associate with the device.
The Tickets tab displays critical information about each ticket. If you require more detail, you can access the Ticket Editor from this page by clicking on the ticketing icon () for that ticket.
You can also create a new ticket from this page.
To create a new ticket for a device:
  1. Go to the Tickets tab of the Device Investigator.
  2. Click the Actions button and then select Create a Ticket. The Ticket Editor page appears.
  3. On the Ticket Editor page that appears, define the basic parameters for the ticket. For information about the fields on this page, see the section on Creating and Editing Tickets.
    The Description and Element fields are automatically populated with information about the device.
