SL1 Workflow Automation PowerPack Documentation: Current
The following tables contain links to release notes and manuals in PDF format for SL1 PowerFlow Synchronization PowerPacks and Automation PowerPacks, in alphabetical order.
You can download the latest version of all Synchronization PowerPacks and PowerPacks from the PowerPacks page of the ScienceLogic Support Site.
The last three releases of a PowerPack are considered to be current. To access older versions, see SL1 PowerPack Documentation: Archived.
Click the expand button or the PowerPack name to view the corresponding table.
Required Synchronization PowerPacks
You must install the following Synchronization PowerPacks before you can install any other Synchronization PowerPacks. When you install PowerFlow, these Synchronization PowerPacks are added to the SyncPacks page by default:
![Closed](../../../Skins/Default/Stylesheets/Images/transparent.gif)
PowerPack Version | Link to Release Notes PDF | Link to Manual PDF |
Base Steps Synchronization PowerPack 1.4.2 | ![]() |
N/A |
Base Steps Synchronization PowerPack 1.4.1 | ![]() |
N/A |
Base Steps Synchronization PowerPack 1.4.0 | ![]() |
N/A |
Archived versions |
Synchronization PowerPack Version | Link to Release Notes PDF | Link to Manual PDF |
1.1.3 |
N/A |
Workflow Automation PowerPacks and Synchronization PowerPacks
106 | ![]() |
105 | ![]() |
104 | ![]() |
Archived versions |
Restorepoint Synchronization PowerPack 2.0.0 | ![]() |
Restorepoint Synchronization PowerPack 1.3.0 | ![]() |
Restorepoint Synchronization PowerPack 1.2.0 | ![]() |
Restorepoint Synchronization PowerPack 1.1.0 | ![]() |
Restorepoint PowerPack 103 | ![]() |
Restorepoint PowerPack 102 | ![]() |
Restorepoint PowerPack 101 | ![]() |
Restorepoint PowerPack 100 | ![]() |
N/A |
Restorepoint Automation PowerPack 100 | ![]() |
Archived versions |
3.4.0 | ![]() |
3.3.0 | ![]() |
3.2.0 | ![]() |
Archived versions |
3.2.1 | ![]() |
3.2.0 | ![]() |
3.1.2 | ![]() |
N/A |
Archived versions |
3.4.5 | ![]() |
N/A |
3.4.4 | ![]() |
N/A |
3.4.3 | ![]() |
N/A |
Archived versions |
4.0.1 | ![]() |
N/A |
4.0.0 | ![]() |
3.0.1 | ![]() |
N/A |
Archived versions |
