Using the Devices Page
On the Devices page, you can view all of your managed devices in Skylar One and run a discovery to find more devices to monitor. You can select a device from the list on the Devices page to view detailed data on the Device Investigator page for that device.
The list of devices on the Devices page matches the list of devices on the Device Manager page (Devices > Classic Devices) in the classic Skylar One user interface.
Viewing the List of All Devices
On the Devices page, you can view all of your managed devices in Skylar One. This section explains how to get more information about a device from this page.
To go to the Devices page, click the Devices icon (Devices page icon).
The Devices page
You can use the Search field to find items in the list. You can do a basic search or an advanced search. For more information, see the topics Using Basic Search and Performing an Advanced Search.
If you do not see one of these columns, click the gear icon (gear icon) and then select Column Preferences to add or remove columns. You can also drag columns to different locations on the page or click on a column heading to sort the list by the values in that column. Skylar One retains any changes you make to the columns that appear on the page and automatically recalls those changes the next time you open the page. For more information, see the section on Editing the Settings for an Inventory Page in the Introduction to Skylar One manual.
By default, the Devices page footer displays the total number of devices discovered. If you apply a filter, the footer displays the number of devices that match your filter and the total number of devices available.
For each device, the Devices page can display the following information:
  • ID. The Device ID. This is a unique number that Skylar One automatically assigns to the device during discovery.
  • Device Name. Name of the device. For devices running SNMP or with DNS entries, the name is discovered automatically. For devices without SNMP or DNS entries, the device's IP address appears in this field.
  • IP Address. The device's IP address.
  • Class. The manufacturer and type of device. The device class is automatically assigned during discovery, at the same time as the category.
  • Category. The category assigned to the device. Categories include servers, routers, switches, firewalls, and printers, among others. The category is automatically assigned during discovery, at the same time as the device class. For more information about device categories, see the section on Managing Device Classes and Device Categories.
  • Organization. The organization to which the device is assigned.
  • State. The current condition of the device, based upon events generated by the device. The device can have one of the following States:
  • Active. Skylar One is collecting data from the device.
  • Unavailable. Skylar One cannot connect to the device. The system cannot collect data from the device until the device is available. A physical device falls back to executing the availability ping every five minutes, unless you have critical ping enabled. Component devices get their availability calculated by the component discovery Dynamic Application of the parent device.
  • User-Disabled. Skylar One is not currently collecting data from the device because a user disabled collection.
  • System-Disabled. Skylar One is not currently collecting data from the device because the system has disabled collection.
  • Scheduled Maintenance. Skylar One is not currently collecting data from the device because it is currently in scheduled maintenance mode.
  • User-Initiated-Maintenance. Skylar One is not currently collecting data from the device because a user manually put it into maintenance mode.
  • Component Vanished. The component device is not currently being reported by its root device. Skylar One cannot collect data from the device at this time.
    Depending on the circumstances, more than one collection state might appear for a single device. For example, if a device is in a scheduled maintenance mode, the Collection State might be Unavailable / Scheduled Maintenance / System-Disabled.
  • Collector Group. The collector group to which the device belongs. Collector groups are groups of Skylar One Data Collectors, which are defined on the Collector Groups page (Manage > Collector Groups).
  • SNMP Credential. The name of the SNMP credential used to monitor the device.
  • SNMP Version. The version of SNMP used to monitor the device.
  • Hostname. The fully qualified hostname for the device, for devices that are discovered and managed by hostname (instead of IP address). This column does not appear by default, but you can add it by clicking Grid Settings > Column Preferences.
  • Date Created. The date and time on which the device was created.
  • Organization ID. The unique numeric identifier of the organization to which the device is assigned.
  • Class ID. The unique numeric identifier of the device class.
  • Category ID. The unique numeric identifier of the device category assigned to the device.
  • Type. The type of device. Options include:
    • Physical. A hardware-based device with an IP address.
    • Component. An entity that runs under the control of a management device.
    • Virtual. A container for collected data.
  • Collector Group ID. The unique numeric identifier of the collector group to which the device belongs.
  • Asset ID. The ID of any asset associated with the device. The asset ID displays as a hyperlink that you can click to view the asset's properties. For more information about assets, see the section on Asset Management.
  • Last Poll. The date and time at which Skylar One last polled the device.
  • Uptime. The amount of time since the device was last initialized.
  • SL Agent. Indicates whether an Skylar One agent is installed on the device. If so, you can click the Yes hyperlink to display a modal where you can update the agent's configuration.
  • Location-based columns. The following columns display information about the device's assigned location:
    • ID (Location). The unique ID of the device's location.
    • Name (Location). The name of the device's location.
    • Latitude (Location). The geographic latitude of the device's location.
    • Longitude (Location). The geographic longitude of the device's location.
    • Street (Location). The street address of the device's location.
    • City (Location). The city where the device's location is located.
    • State (Location). The state where the device's location is located.
    • Zipcode (Location). The ZIP or postal code for the device's location.
    • Country (Location). The country where the device is located.
    • Domestic Region (Location). The regional area with the country where the device is located.
    • Global Region (Location). The broader geographic region where the device is located.
    • Notes (Location). Additional information related to the device's location.
    • Description (Location). A brief description of the device's location.
    • Organizations (Location). The organizations aligned with the device's location.
If you have defined any custom attributes for your devices, you can also add those custom attributes as columns that appear on the Devices page.
Viewing Additional Data About a Device
On the Events page and the Devices page, you can click the open icon (open icon) next to an event or device to open a Device Summary modal.
On the Events page, the Device Summary modal displays only for events that are aligned with devices.
The Device Summary modal for that device contains the Tools pane, the Vitals pane, and the Logs pane:
  • Use the Tools pane to run diagnostic tools or user-initiated actions in the Activity Center, or to click custom links that open in a separate browser window. Click the search bar to search for tools, actions, or custom links that are available for the device.
  • The Vitals pane displays graph data for the past four hours of CPU usage, memory usage, and latency for that device, where relevant. To zoom in on a shorter time frame in the Vitals graph, click and drag. To return to the original time span, click the Reset zoom button.
Adding Devices With Discovery
On the Devices page, click the Add Devices button to run a guided or unguided network discovery session. A discovery session searches for devices and adds them to Skylar One for monitoring.
For more information on guided and unguided discovery, see the section on Discovering Devices.
Creating a Physical Device Without Running Discovery
Skylar One allows you to manually create physical devices without running discovery. When you do so, a device record exists in Skylar One before Skylar One can communicate with the device.
In some cases, service providers find it useful to prepopulate a Skylar One system with device records but set the status of the manually created devices to Disabled. When network and firewall work are completed, the provider can then enable the devices and use discovery to keep the device data up-to-date.
You can manually create a physical device in three ways:
  • In the user interface
  • By uploading device data via a CSV file
  • With the ScienceLogic API
To create a physical device without running discovery, go to the Devices page. Click the down arrow icon () next to the Add Devices button. Then select Create Physical Device or Create Physical Device from File.
For more information, see the section on Creating a Physical Device from the Devices Page.
Creating a Virtual Device
A virtual device is a container for collected data. You can use a virtual device to:
  • Monitor a device or application that does not support TCP/IP, SNMP, or both. You can push the device's data to Skylar One by another method (for example, email) and store the data in a virtual device.
  • Monitor multiple SNMP agents on a single device. In such a case, one of the SNMP agents (for example, a hardware agent) can be associated with the device and another SNMP agent (for example, an agent that monitors a software application) can be associated with a virtual device.
  • Isolate and monitor specific parameters separately from their originating device. For example, you might want to monitor a database and keep its data separate from the hardware data you are collecting from the host device.
You can create a virtual device on the Devices page. To do so, click the down arrow icon () next to the Add Devices button and then select Create Virtual Device.
For more information, see the section on Creating a Virtual Device from the Devices Page.
Installing an Agent
If you are using a distributed Skylar One system without the Skylar One Extended Architecture (which includes Compute Nodes, Storage Nodes, and a Management Node), you can install a Skylar One agent from the Devices page. To do so, click the down arrow next to the Add Devices button and then select Download/Install Agent.
For more information, see the section on Installing the Skylar One Agent.
Merging and Unmerging Devices
If your Skylar One system includes a physical device and a component device that both represent the same device, you can merge those devices into a single device for easier monitoring. Merging does not remove, replace, or add any data; merging just groups data together.
  • The devices and their data (device fields, values, graphs, behaviors, and other user interface elements) consolidate into a single set of data for the device.
  • You reduce the number of duplicate events and administrative tasks.
For example, you might discover a virtual machine device component representing a server, and then later discover an IP-based device from the same server. To prevent duplicate events for the same server, minimize administrative tasks, and prevent a negative impact on your licensing by inflating the number of devices being monitored by Skylar One, you can merge the virtual machine component and the corresponding IP-based device into a single device.
You cannot merge a component device with a physical device that acts as the root device for a dynamic component map (DCM) tree.
When you merge a physical device and a component device, the component device no longer appears in the user interface. The physical device appears on the pages that previously displayed the component device. For example, the physical device appears instead of the component device on the Device Components page and the Component Map page. The physical device receives all existing and future data for both devices.
Merged devices can be unmerged back into individual devices, if needed.
You can merge only two individual devices together into a single merged device. To do so, you must have user permissions that allow merging and unmerging on both devices. For more information on user access permissions, see the section on Assigning Access Hooks.
When you merge devices, active events for the component device change to "cleared." The cleared events do not become associated with the physical device. If you unmerge the devices, you cannot move the cleared events back to the component device.
When you merge devices, the log data from each device also merges. You cannot unmerge the log data later.
You can merge and unmerge devices on the Devices page. This workflow supports both individual and bulk operations. For more information, see Merging and Unmerging Devices from the Devices Page.
If you are using the classic Skylar One user interface, see Merging Individual Devices in the Classic User Interface to merge individual devices and Unmerging Individual Devices in the Classic User Interface to unmerge them. To merge or unmerge multiple devices at once in the classic Skylar One user interface, see Bulk Merging and Unmerging of Devices in the Classic User Interface.
You can merge or unmerge physical and component devices that represent the same device directly from the Devices page. You can select one device pair or several device pairs.
Merging Devices From the Devices Page
You can merge physical and component device records that represent the same device on the Merge Devices modal from the Devices page.
To open the Merge Devices modal:
  1. Go to the Devices page.
  2. Click the drop-down arrow button next to the Add Devices button and select Merge Devices. The Merge Devices modal appears.
The Merge Devices modal displays two tables: Physical Device and Component Device. Each table includes columns such as Device Name, IP Address, Device Category, Device Class, Device ID, and Organization, along with column filters to help you locate devices.
At the top of the Merge Devices modal, you can control how devices are matched using the fields displayed above the device tables. By default, the Merge Devices modal requires you to manually select physical and component devices to merge. In this mode, Skylar One does not apply matching logic and does not display comparison criteria.
Optionally, you can enable Suggested Device Matches to allow Skylar One to automatically generate suggestions for merging devices based on selected matching criteria.
When Suggested Device Matches is not enabled, the modal displays the following matching fields:
  • Name
  • IP Address
  • Organization
  • Device Class
For each field, you can manually review and select one of the following options to define how the physical device and component device values are compared:
  • Ignore. Skylar One does not evaluate this criterion when generating suggested matches.
  • Match. Skylar One suggests device pairs only when the selected values on the physical device and component device are the same.
  • Does Not Match. Skylar One suggests device pairs only when the selected values on the physical device and component device are different.
When you enable Suggested Device Matches, the Merge Devices modal switches to an assisted matching mode and displays additional options for how Skylar One generates merge suggestions. In this mode, Skylar One compares physical and component devices based on selected criteria and suggests device pairs that meet those conditions. In this mode, additional matching fields become available:
  • Collection State
  • Collection Group
When Suggested Device Matches is enabled, the Merge Devices modal automatically preselects the suggested physical-component device pairs. You can review these selections and remove individual pairs before clicking Merge.
Skylar One uses the selected fields to automatically generate suggested physical-component device pairs. Fields set to Ignore are excluded from matching. Fields set to Match or Does Not Match determine how suggested matches are generated.
To merge one device pair or multiple device pairs:
  1. From the Merge Devices modal, select one or more physical-component device pairs.
  2. Review the selected pairs, then click Merge.
You can merge a single device pair or multiple device pairs in the same operation. To review previous merge activity, click View Merge Device Logs.
Unmerging Devices From the Devices Page
You can unmerge previously merged physical and component device records on the Unmerge Devices modal from the Devices page.
To open the Unmerge Devices modal:
  2. Click the drop-down arrow button next to the Add Devices button and select Unmerge Devices. The Unmerge Devices modal appears.
The Unmerge Devices modal displays two tables: Physical Device and Component Device.
  • The Physical Device table includes columns such as Device Name, IP Address, Device Category, Device Class, and Device ID.
  • The Component Device table includes columns such as Device Name, Device Category, Device Class, Device ID, Merged Date, and Merged By. These columns indicate when the device was merged and the user who performed the merge.
To unmerge one device pair or multiple device pairs:
  1. From the Unmerge Devices modal, select one or more merged device pairs.
  2. Review the selected pairs, then click Unmerge.
You can unmerge a single device pair or multiple device pairs in the same operation. To review previous merge and unmerge activity, click View Merge Device Logs.
You can click the Merge Devices button to open the Merge Devices modal.
Designating Favorite Devices
In Skylar One, you can select one or more devices to always display at the top of the Devices page. This process is called favoriting devices.
To make a device a favorite, click the Favorite Device star icon () to add the device to your favorites list. Click the icon () again to remove the favorite status.
With favorite devices, you can:
  • View your favorite devices at the top of the Devices page by default.
  • Filter devices by favorite.
Aligning a Device With a Different Organization
To align a single device with a different organization:
  1. On the Devices page, click the Actions button (actions icon) for the device and select Align Organization. The Align to Organization modal appears.
  2. In the Align to Organization modal, use the Organization drop-down list to search for and select an organization.
  3. Click the Align Organization button. The organization you selected now appears in that Info drop-down menu on the Device Investigator for that device.
You can also bulk-align multiple devices with an organization. For more information, see the section on Performing Bulk Actions on One or More Devices.
Assigning a New Icon to a Device
You can customize the appearance of the devices that appear on the Devices page by assigning an icon to a device, device class, or device category.
  2. Click the actions icon (actions icon) for that item and select Assign Icon. The Select an Icon modal appears.
  3. In the Select an Icon window, do one of the following:
    • To use an existing icon, proceed to step 7.
    • To upload a new icon from your local drive, make sure that the image file meets the following criteria, then proceed to step 4:
    • The image file must be in SVG format.
    • The file must not be larger than 40 KB.
    • The file must not be animated.
    • The file must not contain bitmaps.
  1. To start the upload process, click the Add Icon button. The Add an Icon modal appears.
  2. Complete the following fields in the Add an Icon modal:
    • In the Icon name field, enter a name for the icon you want to upload.
    • In the Add Tags field, type a short descriptor for the icon, without spaces. You can use this tag for searching later.
    • You can click the Browse or Drop area to browse for and select the icon, or you can drag and drop the icon file onto the Add an Icon modal.
  3. Click the Add Icon button. The icon appears in the Select an Icon modal.
  4. Select the icon from the list of icons and click the Select Icon button. The system assigns the icon to the device, device class, or device category.
    You can use the Search field to search for a specific icon or narrow down the list of icons.
Deleting a Device
To delete a single device on the Devices page:
  1. On the Devices page, click the Actions button (actions icon) for the device and select Delete Device.
  2. A dialog appears asking you to confirm that you want to permanently delete the device(s). To confirm, click Delete.
If you attempt to delete one or more devices that have associated asset records, you can choose to delete those associated assets at the same time.
You can also bulk-delete multiple devices. For more information, see the section on Performing Bulk Actions on One or More Devices.
Running a Device Report
From the Devices page or from the Device Investigator for a specific device, you can generate a detailed report for a single device. You can specify the information to include in the report. You can also specify the format that Skylar One uses to generate the report, such as HTML, PDF, or XLS.
To run a device report:
  1. Do one of the following:
    • On the Devices page, click the actions icon (actions icon) for a specific device and select Device Report.
    • On the Device Investigator for a specific device, click the Report button in the top navigation bar.
    The Device Report modal appears.
  2. In the Type drop-down field, select the type of report you want to generate. Your options include:
  • Notes. Includes all notes created on the Notepad Editor page.
  1. In the Format drop-down field, select the format for the report. Your options include:
  • XLS. Create the report as a Microsoft Excel spreadsheet.
Performing Bulk Actions on Multiple Devices
On the Devices page, you can select the checkboxes for one or more devices in the list and then click the Actions button to perform certain tasks on the selected devices. The following options are available when you click the Actions button:
  • Add To Device Group. Select the device groups you want to add the selected devices to and then click Add. For more information about device groups, see the section on Device Groups and Device Templates.
  • Align Device Investigator Layout. Select the layout of the Investigator tab that you want to apply to the selected devices. Then click Next. For more information about device Investigator tab layouts, see the section on Applying a Custom Device Investigator Layout to Other Devices.
    When you bulk-align a device Investigator tab layout to one or more devices, you can apply the layout to all users only if you have permission. Otherwise, the system applies the layout change only for you.
  • Align Organization. Select an organization from the drop-down field and then click Align Organization. For more information about organizations, see the section on Organizations and Users.
  • Align SNMP Read Credential. Select an SNMP read-only credential from the list and then click Align. For more information on SNMP credentials, see the section on SNMP Credentials.
  • Assign Icon. Select an icon from the list and then click Select Icon. You can also add a new icon for selection. For more information, see the section on Assigning a New Icon to a Device.
  • Change Collection State. Changes the data collection status of the device in Skylar One. Your options are:
    • Disable (toggle off). In this state, Skylar One does not poll the device. If you select this option, the data displayed about the device in Skylar One is not updated.
    • Enable (toggle on), in which Skylar One actively polls the device on a regular basis and updates the data displayed about the device.
  • Change Collector Group. Select a collector group from the list and then click Change. For more information about collector groups, see the section on Collector Groups.
  • Change User Maintenance Mode. To enable or disable user maintenance mode for the selected devices, select one of the following maintenance mode options and then click Change:
    • Enabled without Collections. This option puts the selected devices into user maintenance mode with collection disabled. The devices remain in this state until you or another user disables user maintenance mode.
    • Enabled with Collections. This option puts the selected devices into user maintenance mode with collection enabled. The devices remain in this state until you or another user disables user maintenance mode.
    • Disable. This option disables user maintenance mode for the selected devices.
    For more information about user maintenance mode, see the section on Device Maintenance.
  • Create Asset Record. Creates an asset record for each selected device. Skylar One automatically populates as many fields as possible, using retrieved data. For more information about asset records, see the section on Asset Management.
  • Delete Devices. A dialog appears asking you to confirm that you want to permanently delete the devices. To confirm, click Delete.
    If you attempt to delete one or more devices that have associated asset records, you are given the option to delete those associated assets at the same time.
  • Find Collection Label Duplicates. Displays a list of currently duplicated collection labels for the selected devices. From this modal, you can edit the presentation object that is aligned with a collection label.
    • To select a collection label, use the drop-down list in the upper left.
    • To change the aligned presentation object for one or more devices:
      • Select the radio button for the desired presentation object for the device.
      • For each additional device you want to edit, select the radio button for the desired presentation object.
      • In the Select Action menu (lower right), select Align Presentation for Device and then click the Go button.
    For more information about collection labels, see the section on Grouping Dynamic Application Data Using Collection Labels.
  • Modify By Template. Displays the Modify by Template modal, where you can select a device template to change the configuration of the selected devices. For more information, see the section on Using a Configuration Template to Edit the Configuration of One or More Individual Devices.
  • Schedule Maintenance. Displays the Schedule Editor modal, where you can schedule maintenance for the selected devices. For more information, see the section on Defining a Scheduled or Recurring Device Maintenance Window for a Single Device.
