SyncPacks
This page lists the SyncPacks that you can use with Skylar Automation to sync data between a specific third-party application and Skylar One:
- Skylar Compliance (Restorepoint) SyncPack
- ServiceNow SyncPacks
- Additional Third-party SyncPacks
- Related SyncPacks
For a complete list of requirements for this SyncPack, see Dependencies for Skylar Automation SyncPacks.
| SyncPack Manual | Description | SyncPack File | PowerPack File |
| Skylar Compliance (Restorepoint) | Adds Skylar One devices to Skylar Compliance when those devices are discovered in Skylar One. Updates Skylar One events with data from Skylar Compliance. | Skylar Compliance | Skylar CompliancePowerPack |
All ServiceNow SyncPacks require the latest Base Steps and ServiceNow Base SyncPacks. Some ServiceNow SyncPacks require a PowerPack with Skylar One content, such as run book automations and actions, that you will need to download and install on your Skylar One instance. Also, most ServiceNow SyncPacks require a certified (or scoped) application from the ServiceNow Store at https://store.servicenow.com.
Understanding the licensing requirements for ServiceNow integrations is crucial for informed decision-making. The table below lists the IT Operations Management (ITOM) licensing requirements for ScienceLogic integrations with ServiceNow.
ServiceNow’s ITOM licensing is further organized into different tiers. This table is not intended to help identify the suitable tier for your requirements. For any questions related to this, please contact ServiceNow.
| Scoped Application | ServiceNow Module | ITOM License Requirement |
| ScienceLogic Skylar One: Customer Service Management Integration | Customer Service Management - Cases | No |
| ScienceLogic Skylar One: Incident Automation | IT Service Management - Incident | No |
| ScienceLogic ServiceNow Integration | IT Service Management - CMDB | * Situational |
| ScienceLogic Skylar One: Service Catalog Automation | IT Service Management - Service Catalog | ** Situational |
| Service Graph Connector for ScienceLogic | IT Operations Management - CMDB | Yes |
| ScienceLogic Event Integration | IT Operations Management - Events | Yes |
* ScienceLogic is actively adding support for cloud infrastructure mappings within our integrations. To effectively leverage these features in accordance with ServiceNow best practices, you may require ITOM licensing. For questions about cloud mapping, contact your ScienceLogic representative.
** ITOM licenses are necessary only if you are implementing a CMDB using ITOM.
For a complete list of requirements for each SyncPack, see Dependencies for Skylar Automation SyncPacks.
| ServiceNow Base | Contains PowerFlow applications, steps, and other utilities that are used by all ServiceNow SyncPacks. | ServiceNow Base | |
| ServiceNow Cases | Syncs Skylar One events with ServiceNow cases, including event creation, acknowledgment, and resolution. | ServiceNow Cases | ServiceNow Base Pack PowerPack |
| ServiceNow Change Management | Places Skylar One devices into and out of maintenance mode by enabling PowerFlow to generate a Skylar One event when a maintenance-related change request occurs in ServiceNow. | ServiceNow Change Management
and ServiceNow CMDB SyncPack |
| ServiceNow CMDB | Syncs Skylar One organizations with ServiceNow companies, Skylar One devices with ServiceNow CIs, and syncs Skylar One device details with ServiceNow, along with additional syncs to keep Skylar One and ServiceNow accurate. | ServiceNow CMDB | |
| ServiceNow Events | Syncs Skylar One events with ServiceNow events, including event creation, acknowledgment, and resolution. | ServiceNow Events | ServiceNow Base Pack PowerPack |
| ServiceNow Incidents | Syncs Skylar One events with ServiceNow incidents, including event creation, acknowledgment, and resolution. | ServiceNow Incidents | ServiceNow Base Pack PowerPack |
| ServiceNow Service Catalog | Discovers devices in Skylar One from ServiceNow, places Skylar One devices into and out of maintenance mode using ServiceNow change requests. | ServiceNow Service Catalog | |
| ServiceNow Service Graph Connector | Syncs Skylar One devices, file systems, and interfaces with your ServiceNow CMDB. | ServiceNow Service Graph Connector |
All SyncPacks require the latest Base Steps SyncPack, and some of the following SyncPacks require the Skylar One Notifications Base SyncPack. Also, most SyncPacks require a PowerPack with Skylar One content, such as run book automations and actions, that you will need to download and install on your Skylar One instance.
For a complete list of requirements for each SyncPack, see Dependencies for Skylar One PowerFlow SyncPacks.
| Ansible | Syncs playbook and event data from Ansible Tower and Ansible CLI to a Skylar One event | Ansible | Ansible Automation PowerPack |
| AWS Incident Manager | Syncs Skylar One events with Amazon Web Services (AWS) incidents generated with AWS Incident Manager. | AWS Incident Manager
and AWS Base SyncPack |
AWS Incident Manager Automation PowerPack |
| Cherwell | Syncs Skylar One events with Cherwell Service Management (CSM) incidents, syncs Skylar One devices with CSM configuration items (CIs), syncs maintenance windows, and retires CIs from Skylar One and CSM. | Cherwell | Cherwell Integration PowerPack |
| CrowdStrike Falcon | Syncs Skylar One events and CrowdStrike Falcon detections (security events). | CrowdStrike Falcon | CrowdStrike Falcon Automation PowerPack |
| ELK Stack | Syncs jobs, pipeline jobs, and node status between AWS ELK Stack and Skylar One. | ELK Stack | ELK Stack Automation PowerPack |
| Google Cloud Platform | Syncs Google Cloud tasks, errors, and messages and Skylar One events between Google Cloud Platform and Skylar One. | Google Cloud Platform | Google Cloud Platform Automation PowerPack |
| Infoblox: Inventory | Syncs device data between Infoblox and Skylar One, and generates Skylar One events when IP address mis-matches are identified. | Infoblox: Inventory | Infoblox: Workflow Configuration PowerPack |
| Jenkins | Syncs job, pipeline job, and node events between Jenkins and Skylar One. | Jenkins | Jenkins Automation PowerPack |
| Jira Service Management | Syncs Skylar One events with Jira incidents. | Jira Service Management | Jira Service Management Automation Policies PowerPack |
| Opsgenie | Syncs Skylar One events with Opsgenie incidents. | Opsgenie | Opsgenie Incident Integration PowerPack |
| PagerDuty | Syncs Skylar One events with PagerDuty incidents. | PagerDuty | PagerDuty Incident Integration PowerPack |
| Salesforce Service Cloud | Syncs Skylar One events with Salesforce Service Cloud cases or incidents. | Salesforce Service Cloud | Salesforce Service Cloud: Synchronization Policies PowerPack |
| Slack | Syncs Skylar One events with Slack events, and gives you the option of creating a Slack channel for each new event in Slack or Skylar One. | Slack | Slack Automation PowerPack |
| ThousandEyes | Syncs Skylar One events with ThousandEyes alerts. | ThousandEyes | |
| Webex | Syncs Skylar One events with Webex incidents. | Webex | Webex Automation PowerPack |
| xMatters | Syncs Skylar One events with xMatters incidents. | xMatters | xMatters Incident Integration PowerPack |
Related SyncPacks
The following SyncPacks contain steps and other functions that might be required by many of the SyncPacks listed in the Additional Third-party SyncPacks section, above:
| Base Steps | Required for all SyncPacks. Contains a set of steps that are used in all SyncPacks. Certain SyncPacks might have a dependency on a minimum version of the this SyncPack. | Base Steps |
| Flow Control | The Flow Control SyncPack contains the "IfStep" step that enables the logical branching used by the PowerFlow builder. | This SyncPack is included with PowerFlow. |
| Skylar One Notifications Base | Contains common functions used by multiple SyncPacks that integrate with notification systems. Required by some of the SyncPacks, above, that sync with Skylar One events. | Skylar One Notifications Base |
| Skylar One PowerFlow System Utils | Contains applications, configuration objects, and steps necessary for SyncPack operation. | Skylar One PowerFlow System Utils |
For more information about core Skylar One topics, see the following pages at the ScienceLogic website:
- Autonomic IT
- Automated Root Cause Analysis
- AIOps
- Business Service Management
- Hybrid Cloud Monitoring
- Incident Management
- IT Workflow Automation
- Network Automation and Compliance
To share your feedback, click the button at bottom right or email the Documentation team at docs@sciencelogic.com. For Legal information, see the ScienceLogic Terms & Agreements page.
